Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iBUS Tools For Apple Watch
Old 09-13-2021, 13:28   #1 (permalink)
aligsmpak's Avatar
Member: 31610
Thanks Meter: 5
s5 44mm flashing error
[info] Using LOCAL IPSW G:\iphone\mfc\MFC_Watch5,4_7.6.1_18U70_n146bap_GPS _Cellular_Restore_44mm.ipsw
[info] Updated version data.
[warn] Incorrect driver detected! Please wait to update the drivers!
[erro] Alternative driver is not installed! Please install it first and reboot your computer!
[info] Found device in Recovery mode
[info] Gettting dfu mode device ...
[info] Identified device as Apple Watch S5, n146bap, Watch5,4
[info] Extracting BuildManifest from ipsw
[data] Product Version: 7.6.1
[data] Product Build: 18U70 Major: 18
[info] device serial number is G99ZJ06AMLF1
[data] Device supports Image4: true
[info] Variant: Customer Erase Install (IPSW)
[info] This restore will erase your device data.
[info] Checking IPSW for required components...
[info] All required components found in IPSW
[info] Found ECID 000331281aeb002e
[info] Getting ApNonce in recovery mode... [data] A631E55353FD90014362DC2F2A6B7FF7CA464655445A81F5ED C24A4E31A0183D
[info] tts>Trying to fetch new SHSH blob
[info] Getting SepNonce in recovery mode... [data] 20A96C2ACBA2282DE6E3D6EAB1EA40F184BE33B0
[note] Unable to find BbCalibrationManifestKeyHash node
[note] Unable to find BbFactoryActivationManifestKeyHash node
[note] Unable to find BbSkeyId node
[info] Request URL set to https://gs.apple.com/TSS/controller?action=2
[info] Sending TSS request attempt 1...
[info] response successfully received
[info] tts>Received SHSH blobs
[info] Using cached filesystem from 'iDeviceTools/MFC_Watch5,4_7.6.1_18U70_n146bap_GPS_Cellular_Rest ore_44mm/018-33214-073.dmg'
[warn] No path for component iBEC in TSS, will fetch from build_identity
[info] Extracting iBEC.n146b.RELEASE.im4p...
[info] Personalizing IMG4 component iBEC...
[info] Sending iBEC (1135828 bytes)...
[info] Device ecid 000331281aeb002e disconnect detected!
[info] Recovery Mode Environment:
[info] iBoot build-version=iBoot-6723.140.2
[info] iBoot build-style=RELEASE
[info] Sending AppleLogo...
[warn] No path for component AppleLogo in TSS, will fetch from build_identity
[info] Extracting applelogo@448~watch.im4p...
[info] Personalizing IMG4 component AppleLogo...
[info] Sending AppleLogo (10948 bytes)...
[warn] No path for component ACIBT in TSS, will fetch from build_identity
[info] Extracting BT_FW_m9.im4p...
[info] Personalizing IMG4 component ACIBT...
[info] Sending ACIBT (1786649 bytes)...
[warn] No path for component ACIWIFI in TSS, will fetch from build_identity
[info] Extracting wifi_armv7r_m9_rtkit_image.im4p...
[info] Personalizing IMG4 component ACIWIFI...
[info] Sending ACIWIFI (1861405 bytes)...
[warn] No path for component ANE in TSS, will fetch from build_identity
[info] Extracting h11_ane_fw_mercury.im4p...
[info] Personalizing IMG4 component ANE...
[info] Sending ANE (1730909 bytes)...
[warn] No path for component AOP in TSS, will fetch from build_identity
[info] Extracting aopfw-watch5aop.im4p...
[info] Personalizing IMG4 component AOP...
[info] Sending AOP (1870997 bytes)...
[warn] No path for component GFX in TSS, will fetch from build_identity
[info] Extracting armfw_g11m.im4p...
[info] Personalizing IMG4 component GFX...
[info] Sending GFX (848101 bytes)...
[warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity
[info] Extracting 018-33330-074.dmg.trustcache...
[info] Personalizing IMG4 component RestoreTrustCache...
[info] Sending RestoreTrustCache (16358 bytes)...
[warn] No path for component SCE in TSS, will fetch from build_identity
[info] Extracting scefw.im4p...
[info] Personalizing IMG4 component SCE...
[info] Sending SCE (20341 bytes)...
[warn] No path for component SIO in TSS, will fetch from build_identity
[info] Extracting SmartIOFirmware_ASCv2.im4p...
[info] Personalizing IMG4 component SIO...
[info] Sending SIO (1160145 bytes)...
[warn] No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity
[info] Extracting WirelessPower.watch4.im4p...
[info] Personalizing IMG4 component WCHFirmwareUpdater...
[info] Sending WCHFirmwareUpdater (31700 bytes)...
[warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity
[info] Extracting 018-33330-074.dmg...
[info] Personalizing IMG4 component RestoreRamDisk...
[info] Sending RestoreRamDisk (82728088 bytes)...
[warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity
[info] Extracting DeviceTree.n146bap.im4p...
[info] Personalizing IMG4 component RestoreDeviceTree...
[info] Sending RestoreDeviceTree (44187 bytes)...
[warn] No path for component RestoreSEP in TSS, will fetch from build_identity
[info] Extracting sep-firmware.n146b.RELEASE.im4p...
[info] Personalizing IMG4 component RestoreSEP...
[info] Sending RestoreSEP (5283198 bytes)...
[warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity
[info] Extracting kernelcache.release.watch5...
[info] Personalizing IMG4 component RestoreKernelCache...
[info] Sending RestoreKernelCache (12124925 bytes)...
[info] About to restore device...
[info] Waiting for device...
[info] Device is now connected in restore mode...
[info] Connecting now...
[info] Connected to com.apple.mobile.restored, version 15
[info] Device 00008006-000331281AEB002E has successfully entered restore mode
[info] Hardware Information:
[info] BoardID: 22
[info] ChipID: 32774
[info] UniqueChipID: 898473250193454
[info] ProductionMode: true
[sett] Previous restore exit status: 0x100
[info] Starting FDR listener thread
[info] Connecting to FDR client at port 1082
[warn] About to do ctrl handshake
[done] Ctrl handshake done (ConnPort = 49161)
[warn] Requesting NOT TO Update Baseband
[warn] Unknown message type received. Saving to UnknownMessageType.plist
[info] About to send RootTicket...
[info] Sending RootTicket now...
[info] Done sending RootTicket
[info] Waiting for NAND (28)
[info] Updating NAND Firmware (58)
[info] Sending NORData...
[info] Found firmware path Firmware/all_flash
[erro] zip_name_locate: Firmware/all_flash/manifest
[info] Getting firmware manifest from build identity
[info] Extracting LLB.n146b.RELEASE.im4p...
[info] Personalizing IMG4 component LLB...
[info] Extracting dali-ui.n146b.release.im4p...
[info] Personalizing IMG4 component Dali...
[info] Personalizing IMG4 component DeviceTree...
[info] Extracting recoverymode@448~watch.im4p...
[info] Personalizing IMG4 component RecoveryMode...
[info] Extracting iBoot.n146b.RELEASE.im4p...
[info] Personalizing IMG4 component iBoot...
[info] Personalizing IMG4 component SEP...
[info] Sending NORData now...
[info] Done sending NORData
[info] Unmounting filesystems (29)
[info] About to send FDR Trust data...
[info] Sending FDR Trust data now...
[done] sending FDR Trust Data
[info] Checking for uncollected logs (44)
[info] Creating partition map (11)
[info] Creating filesystem (12)
[info] About to send filesystem...
[info] Connected to ASR
[info] Validating the filesystem
[info] Filesystem validated
[info] Sending filesystem now...
[done] sending filesystem
[info] Operation: Verifying restore (14)
[info] Checking filesystems (15)
[info] Mounting filesystems (16)
[info] Connecting to FDR client at port 49161
[info] FDR 0ABA4EB8 Proxy connect request to gg.apple.com:443
[info] FDR 0ABA4ED0 Proxy connect request to skl.apple.com:443
[info] FDR 103360C8 Proxy connect request to skl.apple.com:443
[info] FDR 10336278 Proxy connect request to skl.apple.com:443
[info] Operation: Unknown operation (80)
[info] Sending IsiBootEANFirmware image list
[info] Sending IsiBootNonEssentialFirmware image list
[erro] FDR 103360C8 Sending proxy payload failed: No error. Sent 0 of 31 bytes.
[info] Flashing firmware (18)
[info] Sending IsEarlyAccessFirmware image list
[info] Operation: Requesting FUD data (36)
[info] Found IsFUDFirmware component ACIBT
[info] Found IsFUDFirmware component ACIWIFI
[info] Found IsFUDFirmware component ANE
[info] Found IsFUDFirmware component AOP
[info] Found IsFUDFirmware component GFX
[info] Found IsFUDFirmware component LeapHaptics
[info] Found IsFUDFirmware component Multitouch
[info] Found IsFUDFirmware component RTP
[info] Found IsFUDFirmware component RestoreTrustCache
[info] Found IsFUDFirmware component SCE
[info] Found IsFUDFirmware component SIO
[info] Found IsFUDFirmware component StaticTrustCache
[info] Sending IsFUDFirmware image list
[info] Sending IsFUDFirmware for ACIBT...
[info] Sending IsFUDFirmware for ACIWIFI...
[info] Sending IsFUDFirmware for ANE...
[info] Sending IsFUDFirmware for AOP...
[info] Sending IsFUDFirmware for GFX...
[info] Extracting N146B_LeapHapticsFirmware.im4p...
[info] Personalizing IMG4 component LeapHaptics...
[info] Sending IsFUDFirmware for LeapHaptics...
[info] Extracting N146b_Multitouch.im4p...
[info] Personalizing IMG4 component Multitouch...
[info] Sending IsFUDFirmware for Multitouch...
[info] Extracting rtpfw.im4p...
[info] Personalizing IMG4 component RTP...
[info] Sending IsFUDFirmware for RTP...
[info] Sending IsFUDFirmware for RestoreTrustCache...
[info] Sending IsFUDFirmware for SCE...
[info] Sending IsFUDFirmware for SIO...
[info] Extracting 018-33214-073.dmg.trustcache...
[info] Personalizing IMG4 component StaticTrustCache...
[info] Sending IsFUDFirmware for StaticTrustCache...
[info] Updating gas gauge software (47)
[info] Updating Stockholm (55)
[info] Status message: Verification Error
[sett] Log is available in ErrorLog.plist
[erro] Unable to successfully restore device
[erro] Unable to restore device
[warn] Lockdown error: -8
[done] Operation finished!
[info] Removing USB\VID_05AC&PID_12AF\00008006-000331281AEB002E
Old 09-13-2021, 16:26   #2 (permalink)
Member: 2277861
Thanks Meter: 206
hello,
Please check this logs for the details ErrorLog.plist , and as i check , you are not using the final software version !
The Following User Says Thank You to mfcsupport For This Useful Post:
Old 09-16-2021, 23:18   #3 (permalink)
Member: 2988950
What would be the final version of the product, could you put a link I have the same problem as the partner
Old 09-17-2021, 02:36   #4 (permalink)
Member: 2277861
Thanks Meter: 206
you can get the latest version information from this link :
https://forum.gsmhosting.com/vbb/f93...59/index5.html
Old 09-20-2021, 21:29   #5 (permalink)
Member: 2745694
Hi, also have an issue with restoring AW 5 40mm Demo
I’ve restored it successfully done, finished
But when I try to connect it to my iphone it goes to DEMO mode again
I use latest software and 7.6.1
AW is LTE version
Please, help me
Old 09-20-2021, 21:29   #6 (permalink)
Member: 2745694
AW is LTE version
Please, help me
Old 09-21-2021, 04:26   #7 (permalink)
Member: 2277861
Thanks Meter: 206
AW is LTE version
Please, help me
About this situation , there is nothing can do , that's because the demo device have different hardware , which only for DEV
Old 09-23-2021, 00:26   #8 (permalink)
Member: 2988950
[QUOTE=mfcsupport;14454266]you can get the latest version information from this link :
hello I have accessed the link you sent me and when I download version 3.7 fixed it tells me that the file has been deleted I cannot download it.
Old 09-23-2021, 05:53   #9 (permalink)
Member: 2277861
Thanks Meter: 206
Read carefully from this page
https://www.mfcbox.com/downloads/mfc...aller-download
Page generated in 0.23024 seconds with 8 queries
