11-17-2022, 01:34 | #1 (permalink) |
No Life Poster Join Date: Sep 2008 Location: kutch, gujarat, india
Member: 852566 Status: Offline Thanks Meter: 464 | s5 restore error [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S5, n144sap, Watch5,1 [info] Extracting BuildManifest from ipsw [data] Product Version: 9.1 [data] Product Build: 20S75 Major: 20 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 000c15dc3607002e [info] Getting ApNonce in dfu mode... [data] 0D5D84961B3922E3D08632FDABCED7C9A2EB530838891A24CB 8C637238A436A6 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] CEE667C74A60688BE440A6333B7923CA95E937E1 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs Filesystem file not found! We will extract the filesystem to file iDeviceTools/MFC_Watch5,1_20S75_9.1_n14/078-58729-090.dmg [info] Extracting filesystem [info] Found ECID 000c15dc3607002e [info] Getting ApNonce in dfu mode... [data] 0D5D84961B3922E3D08632FDABCED7C9A2EB530838891A24CB 8C637238A436A6 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] CEE667C74A60688BE440A6333B7923CA95E937E1 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Getting SepNonce in dfu mode... [data] CEE667C74A60688BE440A6333B7923CA95E937E1 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [erro] TSS request failed (status=94, message=This device isn't eligible for the requested build.) [warn] The specified firmware version is either unsigned or nonexistent. Signing might be stopped! [erro] Unable to send TSS request [erro] Unable to get SHSH blobs for this device (local policy) [done] Operation finished! |
