08-30-2021, 19:02 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | Serie 2 42 mm demo not done [info] Updated version data. [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 6.3 [data] Product Build: 17U208 Major: 17 [info] device serial number is FH7TWCPLHJLJ [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 001b2329046a1326 [info] Getting ApNonce in recovery mode... [data] D53211CF7721E4F2FC6504D7FDA7BE015B40D585D9FF95F833 8A8163EE85B071 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] C1B96B435C3ABFD6BADD5CCEC9461C829A9B3D4B [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs Filesystem file not found! We will extract the filesystem to file iDeviceTools/Watch2,7_n28dap_42mm_Watch2,4_n75ap_42mm_6.3_17U20 8_restore (1)/038-87845-009.dmg [info] Extracting filesystem [info] Found ECID 001b2329046a1326 [info] Getting ApNonce in recovery mode... [data] D53211CF7721E4F2FC6504D7FDA7BE015B40D585D9FF95F833 8A8163EE85B071 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] C1B96B435C3ABFD6BADD5CCEC9461C829A9B3D4B [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n65.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (747975 bytes)... [info] Device ecid 001b2329046a1326 disconnect detected! [info] Recovery Mode Environment: [info] iBoot build-version= [info] iBoot build-style= [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (8706 bytes)... [erro] Unable to send AppleLogo component: Unable to upload data to device [erro] Unable to send AppleLogo to device. [erro] Unable to send AppleLogo [erro] Unable to place device into restore mode [done] Operation finished! [info] Using LATEST available IPSW. [info] using cached version data [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [erro] Can't find major version?! [erro] can't get URL for latest firmware [done] Operation finished! [info] Using LATEST available IPSW. [info] using cached version data [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [erro] Can't find major version?! [erro] can't get URL for latest firmware [done] Operation finished! [info] Using LOCAL IPSW E:\APPLE WATCH SOFTWARE\Watch2,7_n28dap_42mm_Watch2,4_n75ap_42mm_ 6.3_17U208_restore (1).ipsw [info] using cached version data [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 6.3 [data] Product Build: 17U208 Major: 17 [info] device serial number is FH7TWCPLHJLJ [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 001b2329046a1326 [info] Getting ApNonce in recovery mode... [data] D53211CF7721E4F2FC6504D7FDA7BE015B40D585D9FF95F833 8A8163EE85B071 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] C1B96B435C3ABFD6BADD5CCEC9461C829A9B3D4B [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/Watch2,7_n28dap_42mm_Watch2,4_n75ap_42mm_6.3_17U20 8_restore (1)/038-87845-009.dmg' [info] Found ECID 001b2329046a1326 [info] Getting ApNonce in recovery mode... [data] D53211CF7721E4F2FC6504D7FDA7BE015B40D585D9FF95F833 8A8163EE85B071 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] C1B96B435C3ABFD6BADD5CCEC9461C829A9B3D4B [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n65.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (747975 bytes)... [info] Device ecid 001b2329046a1326 disconnect detected! [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-5540.144.2 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (8706 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 038-87586-010.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (13743 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 038-87586-010.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (67956485 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n75ap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (110731 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n75.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2103233 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch2... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (11149214 bytes)... [info] Device ecid 001b2329046a1326 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device d1d31facacea07ee4d87d4b4a357ccc3e31aaf48 has successfully entered restore mode [info] Hardware Information: [info] BoardID: 14 [info] ChipID: 32770 [info] UniqueChipID: 7638483445879590 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49161) [warn] Requesting Update Baseband [erro] TZ0RequiredCapacity: 0x600000 [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send RootTicket... [info] Sending RootTicket now... [info] Done sending RootTicket [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Waiting for NAND (28) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n65.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n75.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n75ap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@132~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n65.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n75.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n75.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Unmounting filesystems (29) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Checking filesystems (15) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Connecting to FDR client at port 49161 [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Connecting to FDR client at port 49161 [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Unmounting filesystems (29) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Creating partition map (11) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Creating filesystem (12) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Checking filesystems (15) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Creating Protected Volume (67) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch2... [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [info] Done sending KernelCache[info] Installing kernelcache (27) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n75ap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [info] Done sending DeviceTree[info] Installing DeviceTree (61) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Flashing firmware (18) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting aopfw-m8aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting N75_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 038-87586-010.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 038-87845-009.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating gas gauge software (47) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating gas gauge software (47) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating Stockholm (55) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating SE Firmware (59) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Fixing up /var (17) [info] Creating system key bag (50) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Connecting to FDR client at port 49161 [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Modifying persistent boot-args (25) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Unmounting filesystems (29) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! |
08-30-2021, 19:36 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | As i check the restore working fine . if you power on the device again that reverse back to demo , which mean the watch with different hardware , usually this called DEV Type, so it's not able to convert to normal |
08-30-2021, 20:28 | #3 (permalink) | |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | Quote:
Serial Number: FH7TWCPL Activation Status: Activated Warranty Status: Out Of Warranty Telephone Technical Support: Expired Repairs and Service Coverage: Expired Repairs and Service Expiration Date: 1 Jan 1985 AppleCare Eligible: No Valid Purchase Date: Yes Registered Device: Yes Replaced by Apple: No Loaner Device: No | |
08-30-2021, 20:39 | #4 (permalink) |
Member: 79315 Status: Offline Thanks Meter: 6,024 | i am interesting to let u make test ! A, Backup this watch syscfg B, Take another same model watch also backup syscfg C, Write the other watch syscfg to this demo watch Well, this need doing by Diag function maybe can make it work, but not sure , i never test |
