09-17-2021, 17:18 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | Serie 3 flash error [info] Updating gas gauge software (47) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating gas gauge software (47) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating Stockholm (55) [erro] Could not read data (-256). Aborting. [erro] Unable to restore device [info] device disconnect... [done] Operation finished! |
09-17-2021, 20:33 | #2 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | [info] Using LOCAL IPSW C:\Users\maximo espinal\Downloads\MFC_Watch3,1_7.6.1_18U70_n111sap _GPS_Cellular_Restore_38mm.ipsw [info] using cached version data [warn] Incorrect driver detected! Please wait to update the drivers! [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n111sap, Watch3,1 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.6.1 [data] Product Build: 18U70 Major: 18 [info] device serial number is FHLW49FNJ6DW [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 001e646a18f8e0a6 [info] Getting ApNonce in recovery mode... [data] C55FD50AA81A2AA0B6D3EF4455EB58773B33A39BF8B4523B7E B67AC9B6E72C63 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 5FB8301C8024B96A8230FBA5B0A3CB1CD8015C8D [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,1_7.6.1_18U70_n111sap_GPS_Cellular_Rest ore_38mm/018-33270-073.dmg' [info] Found ECID 001e646a18f8e0a6 [info] Getting ApNonce in recovery mode... [data] C55FD50AA81A2AA0B6D3EF4455EB58773B33A39BF8B4523B7E B67AC9B6E72C63 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 5FB8301C8024B96A8230FBA5B0A3CB1CD8015C8D [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n111s.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (773156 bytes)... [info] Device ecid 001e646a18f8e0a6 disconnect detected! [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.140.2 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (8784 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 018-33332-074.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15228 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 018-33332-074.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (78807906 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n111sap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (33382 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n111s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2361886 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (13383720 bytes)... [info] Device ecid 001e646a18f8e0a6 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device a4a263e1300599708b37a46648cb427cf7e9d0f0 has successfully entered restore mode [info] Hardware Information: [info] BoardID: 28 [info] ChipID: 32772 [info] UniqueChipID: 8554656149594278 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49161) [warn] Requesting NOT TO Update Baseband [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send RootTicket... [info] Sending RootTicket now... [info] Done sending RootTicket [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Waiting for NAND (28) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n111s.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n111s.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n111sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@115~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n111s.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n111s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n111s.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Unmounting filesystems (29) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Checking for uncollected logs (44) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Unmounting filesystems (29) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Creating partition map (11) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Creating filesystem (12) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Connecting to FDR client at port 49161 [info] FDR 0C55A398 Proxy connect request to gg.apple.com:443 [info] Connecting to FDR client at port 49161 [info] FDR 0FECBEF0 Proxy connect request to skl.apple.com:443 [info] Connecting to FDR client at port 49161 [info] FDR 10F4DA68 Proxy connect request to skl.apple.com:443 [erro] FDR 0C55A398 Unable to receive proxy payload (-3) [info] Connecting to FDR client at port 49161 [info] FDR 0C54AE58 Proxy connect request to skl.apple.com:443 [info] Connecting to FDR client at port 49161 [info] FDR 0C53B560 Proxy connect request to skl.apple.com:443 [erro] FDR 0FECBEF0 Unable to receive proxy payload (-3) [erro] FDR 10F4DA68 Unable to receive proxy payload (-3) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m8p_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting aopfw-m8paop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting N111s_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 018-33332-074.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 018-33270-073.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating gas gauge software (47) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating gas gauge software (47) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating Stockholm (55) [erro] FDR 0C54AE58 Unable to receive proxy payload (-3) [erro] FDR 0C53B560 Unable to receive proxy payload (-3) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating Stockholm (55) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating Stockholm (55) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating Stockholm (55) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating Stockholm (55) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating Stockholm (55) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Status message: Ramrod firmware update failed. Hint: The display of this model is not compatible, or you can replace the NFC module [sett] Log is available in ErrorLog.plist [erro] Unable to successfully restore device [warn] Unknown message type received. Saving to UnknownMessageType.plist [erro] Unable to restore device [done] Operation finished! [info] device disconnect... |
