08-25-2021, 00:20 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | SERIE 4 FLASH DONE x 2 Incorrect driver detected! Please wait to update the drivers! Found device in DFU mode Identified device as Apple Watch S4, n131bap, Watch4,2 Finished Read Info ! Operation finished! Starting ... Using LOCAL IPSW C:\Users\maximo espinal\Downloads\MFC_Watch4,2_7.6.1_18U70_n131bap _GPS_Restore_44mm.ipsw using cached version data Found device in DFU mode Gettting dfu mode device ... Identified device as Apple Watch S4, n131bap, Watch4,2 Extracting BuildManifest from ipsw Product Version: 7.6.1 Product Build: 18U70 Major: 18 Device supports Image4: true Variant: Customer Erase Install (IPSW) This restore will erase your device data. Checking IPSW for required components... All required components found in IPSW Found ECID 001a18263a39002e Getting ApNonce in dfu mode... 0CA25126165A9AA656589DD96E496B5AB5F1DD9CC7907ACA75 A5ACCDCC1C3FD6 tts>Trying to fetch new SHSH blob Getting SepNonce in dfu mode... 18ABA12C3AA5677F6349C703C67A79064F14D75B Unable to find BbChipID node Unable to find BbProvisioningManifestKeyHash node Unable to find BbActivationManifestKeyHash node Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbFDRSecurityKeyHash node Unable to find BbSkeyId node Sending TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received tts>Received SHSH blobs Using cached filesystem from 'iDeviceTools/MFC_Watch4,2_7.6.1_18U70_n131bap_GPS_Restore_44mm/018-33199-073.dmg' Found ECID 001a18263a39002e Getting ApNonce in dfu mode... 0CA25126165A9AA656589DD96E496B5AB5F1DD9CC7907ACA75 A5ACCDCC1C3FD6 tts>Trying to fetch new SHSH blob Getting SepNonce in dfu mode... 18ABA12C3AA5677F6349C703C67A79064F14D75B Unable to find BbChipID node Unable to find BbProvisioningManifestKeyHash node Unable to find BbActivationManifestKeyHash node Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbFDRSecurityKeyHash node Unable to find BbSkeyId node Sending TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received tts>Received SHSH blobs Extracting iBSS.n131b.RELEASE.im4p... Personalizing IMG4 component iBSS... Sending iBSS (1128932 bytes)... If device does not disconnect automatically you can try to disconnect and reconnect the cable! Device ecid 001a18263a39002e disconnect detected! Waiting for device arrival (timeout 20.000000 seconds) Found device in Recovery mode Noce: tts>Trying to fetch new SHSH blob Getting SepNonce in recovery mode... device serial number is FHLYR4KYKDH0 Unable to find BbChipID node Unable to find BbProvisioningManifestKeyHash node Unable to find BbActivationManifestKeyHash node Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbFDRSecurityKeyHash node Unable to find BbSkeyId node Sending TSS request... Unable to find required ApSepNonce in parameters tts>Unable to add img4 tags to TSS request Unable to get SHSH blobs for this device Unable to place device into recovery mode from Recovery mode Failed Operation finished! Starting ... Using LOCAL IPSW C:\Users\maximo espinal\Downloads\MFC_Watch4,2_7.6.1_18U70_n131bap _GPS_Restore_44mm.ipsw using cached version data Found device in Recovery mode Gettting dfu mode device ... Identified device as Apple Watch S4, n131bap, Watch4,2 Extracting BuildManifest from ipsw Product Version: 7.6.1 Product Build: 18U70 Major: 18 device serial number is FHLYR4KYKDH0 Device supports Image4: true Variant: Customer Erase Install (IPSW) This restore will erase your device data. Checking IPSW for required components... All required components found in IPSW Found ECID 001a18263a39002e Getting ApNonce in recovery mode... 0CA25126165A9AA656589DD96E496B5AB5F1DD9CC7907ACA75 A5ACCDCC1C3FD6 tts>Trying to fetch new SHSH blob Getting SepNonce in recovery mode... 18ABA12C3AA5677F6349C703C67A79064F14D75B Unable to find BbChipID node Unable to find BbProvisioningManifestKeyHash node Unable to find BbActivationManifestKeyHash node Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbFDRSecurityKeyHash node Unable to find BbSkeyId node Sending TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received tts>Received SHSH blobs Using cached filesystem from 'iDeviceTools/MFC_Watch4,2_7.6.1_18U70_n131bap_GPS_Restore_44mm/018-33199-073.dmg' Found ECID 001a18263a39002e Getting ApNonce in recovery mode... 0CA25126165A9AA656589DD96E496B5AB5F1DD9CC7907ACA75 A5ACCDCC1C3FD6 tts>Trying to fetch new SHSH blob Getting SepNonce in recovery mode... 18ABA12C3AA5677F6349C703C67A79064F14D75B Unable to find BbChipID node Unable to find BbProvisioningManifestKeyHash node Unable to find BbActivationManifestKeyHash node Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbFDRSecurityKeyHash node Unable to find BbSkeyId node Sending TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received tts>Received SHSH blobs No path for component iBEC in TSS, will fetch from build_identity Extracting iBEC.n131b.RELEASE.im4p... Personalizing IMG4 component iBEC... Sending iBEC (1128932 bytes)... Device ecid 001a18263a39002e disconnect detected! Recovery Mode Environment: iBoot build-version=iBoot-6723.140.2 iBoot build-style=RELEASE Sending AppleLogo... No path for component AppleLogo in TSS, will fetch from build_identity Extracting applelogo@448~watch.im4p... Personalizing IMG4 component AppleLogo... Sending AppleLogo (10948 bytes)... No path for component ACIBT in TSS, will fetch from build_identity Extracting BT_FW_m9.im4p... Personalizing IMG4 component ACIBT... Sending ACIBT (1786649 bytes)... No path for component ACIWIFI in TSS, will fetch from build_identity Extracting wifi_armv7r_m9_rtkit_image.im4p... Personalizing IMG4 component ACIWIFI... Sending ACIWIFI (1861405 bytes)... No path for component ANE in TSS, will fetch from build_identity Extracting h11_ane_fw_mercury.im4p... Personalizing IMG4 component ANE... Sending ANE (1730909 bytes)... No path for component AOP in TSS, will fetch from build_identity Extracting aopfw-watch4aop.im4p... Personalizing IMG4 component AOP... Sending AOP (1735829 bytes)... No path for component GFX in TSS, will fetch from build_identity Extracting armfw_g11m.im4p... Personalizing IMG4 component GFX... Sending GFX (848101 bytes)... No path for component RestoreTrustCache in TSS, will fetch from build_identity Extracting 018-33330-074.dmg.trustcache... Personalizing IMG4 component RestoreTrustCache... Sending RestoreTrustCache (16358 bytes)... No path for component SCE in TSS, will fetch from build_identity Extracting scefw.im4p... Personalizing IMG4 component SCE... Sending SCE (20341 bytes)... No path for component SIO in TSS, will fetch from build_identity Extracting SmartIOFirmware_ASCv2.im4p... Personalizing IMG4 component SIO... Sending SIO (1160145 bytes)... No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity Extracting WirelessPower.watch4.im4p... Personalizing IMG4 component WCHFirmwareUpdater... Sending WCHFirmwareUpdater (31700 bytes)... No path for component RestoreRamDisk in TSS, will fetch from build_identity Extracting 018-33330-074.dmg... Personalizing IMG4 component RestoreRamDisk... Sending RestoreRamDisk (82728088 bytes)... No path for component RestoreDeviceTree in TSS, will fetch from build_identity Extracting DeviceTree.n131bap.im4p... Personalizing IMG4 component RestoreDeviceTree... Sending RestoreDeviceTree (39643 bytes)... No path for component RestoreSEP in TSS, will fetch from build_identity Extracting sep-firmware.n131b.RELEASE.im4p... Personalizing IMG4 component RestoreSEP... Sending RestoreSEP (5283198 bytes)... No path for component RestoreKernelCache in TSS, will fetch from build_identity Extracting kernelcache.release.watch4... Personalizing IMG4 component RestoreKernelCache... Sending RestoreKernelCache (11754634 bytes)... Device ecid 001a18263a39002e disconnect detected! About to restore device... Waiting for device... Device is now connected in restore mode... Connecting now... Connected to com.apple.mobile.restored, version 15 Device 00008006-001A18263A39002E has successfully entered restore mode Hardware Information: BoardID: 10 ChipID: 32774 UniqueChipID: 7344901859115054 ProductionMode: true Starting FDR listener thread Connecting to FDR client at port 1082 About to do ctrl handshake Ctrl handshake done (ConnPort = 49159) Requesting NOT TO Update Baseband About to send RootTicket... Sending RootTicket now... Done sending RootTicket Waiting for NAND (28) Updating NAND Firmware (58) Sending NORData... Found firmware path Firmware/all_flash zip_name_locate: Firmware/all_flash/manifest Getting firmware manifest from build identity Extracting LLB.n131b.RELEASE.im4p... Personalizing IMG4 component LLB... Extracting applelogo@448~watch.im4p... Personalizing IMG4 component AppleLogo... Extracting dali-ui.n131b.release.im4p... Personalizing IMG4 component Dali... Extracting DeviceTree.n131bap.im4p... Personalizing IMG4 component DeviceTree... Extracting recoverymode@448~watch.im4p... Personalizing IMG4 component RecoveryMode... Extracting WirelessPower.watch4.im4p... Personalizing IMG4 component WCHFirmwareUpdater... Extracting iBoot.n131b.RELEASE.im4p... Personalizing IMG4 component iBoot... Extracting sep-firmware.n131b.RELEASE.im4p... Personalizing IMG4 component RestoreSEP... Extracting sep-firmware.n131b.RELEASE.im4p... Personalizing IMG4 component SEP... Sending NORData now... Done sending NORData Unmounting filesystems (29) About to send FDR Trust data... Sending FDR Trust data now... sending FDR Trust Data Checking for uncollected logs (44) Connecting to FDR client at port 49159 FDR 0FDCFC78 Proxy connect request to iphonesubmissions.apple.com:443 Connecting to FDR client at port 49159 Unmounting filesystems (29) Creating partition map (11) Creating filesystem (12) About to send filesystem... Connected to ASR Validating the filesystem Filesystem validated Sending filesystem now... FDR 0FDCFC78 Unable to receive proxy payload (-3) sending filesystem Operation: Verifying restore (14) Unmounting filesystems (29) Checking filesystems (15) Mounting filesystems (16) Operation: Unknown operation (80) Sending IsiBootEANFirmware image list Sending IsiBootNonEssentialFirmware image list Flashing firmware (18) Operation: Unknown operation (80) Sending IsEarlyAccessFirmware image list Sending IsiBootEANFirmware image list Sending IsiBootNonEssentialFirmware image list Operation: Requesting FUD data (36) Found IsFUDFirmware component ACIBT Found IsFUDFirmware component ACIWIFI Found IsFUDFirmware component ANE Found IsFUDFirmware component AOP Found IsFUDFirmware component GFX Found IsFUDFirmware component LeapHaptics Found IsFUDFirmware component Multitouch Found IsFUDFirmware component RTP Found IsFUDFirmware component RestoreTrustCache Found IsFUDFirmware component SCE Found IsFUDFirmware component SIO Found IsFUDFirmware component StaticTrustCache Sending IsFUDFirmware image list Extracting BT_FW_m9.im4p... Personalizing IMG4 component ACIBT... Sending IsFUDFirmware for ACIBT... Extracting wifi_armv7r_m9_rtkit_image.im4p... Personalizing IMG4 component ACIWIFI... Sending IsFUDFirmware for ACIWIFI... Extracting h11_ane_fw_mercury.im4p... Personalizing IMG4 component ANE... Sending IsFUDFirmware for ANE... Extracting aopfw-watch4aop.im4p... Personalizing IMG4 component AOP... Sending IsFUDFirmware for AOP... Extracting armfw_g11m.im4p... Personalizing IMG4 component GFX... Sending IsFUDFirmware for GFX... Extracting N131B_LeapHapticsFirmware.im4p... Personalizing IMG4 component LeapHaptics... Sending IsFUDFirmware for LeapHaptics... Extracting N131b_Multitouch.im4p... Personalizing IMG4 component Multitouch... Sending IsFUDFirmware for Multitouch... Extracting rtpfw.im4p... Personalizing IMG4 component RTP... Sending IsFUDFirmware for RTP... Extracting 018-33330-074.dmg.trustcache... Personalizing IMG4 component RestoreTrustCache... Sending IsFUDFirmware for RestoreTrustCache... Extracting scefw.im4p... Personalizing IMG4 component SCE... Sending IsFUDFirmware for SCE... Extracting SmartIOFirmware_ASCv2.im4p... Personalizing IMG4 component SIO... Sending IsFUDFirmware for SIO... Extracting 018-33199-073.dmg.trustcache... Personalizing IMG4 component StaticTrustCache... Sending IsFUDFirmware for StaticTrustCache... Updating gas gauge software (47) Updating Stockholm (55) Operation: Requesting FUD data (36) Found IsFUDFirmware component ACIBT Found IsFUDFirmware component ACIWIFI Found IsFUDFirmware component ANE Found IsFUDFirmware component AOP Found IsFUDFirmware component GFX Found IsFUDFirmware component LeapHaptics Found IsFUDFirmware component Multitouch Found IsFUDFirmware component RTP Found IsFUDFirmware component RestoreTrustCache Found IsFUDFirmware component SCE Found IsFUDFirmware component SIO Found IsFUDFirmware component StaticTrustCache Sending IsFUDFirmware image list Updating SE Firmware (59) Extracting Stockholm5.RELEASE.sefw... Unable to find BbChipID node Unable to find BbProvisioningManifestKeyHash node Unable to find BbActivationManifestKeyHash node Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbFDRSecurityKeyHash node Unable to find BbSkeyId node Sending SE TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received Received SE ticket Sending FirmwareResponse data now... Done sending FirmwareUpdater data Unknown operation (81) Creating Protected Volume (67) About to send KernelCache... No path for component KernelCache in TSS, will fetch from build identity Extracting kernelcache.release.watch4... Personalizing IMG4 component KernelCache... Sending KernelCache ... Done sending KernelCacheInstalling kernelcache (27) About to send DeviceTree... No path for component DeviceTree in TSS, will fetch from build identity Extracting DeviceTree.n131bap.im4p... Personalizing IMG4 component DeviceTree... Sending DeviceTree ... Done sending DeviceTreeInstalling DeviceTree (61) Sending NORData... Found firmware path Firmware/all_flash zip_name_locate: Firmware/all_flash/manifest Getting firmware manifest from build identity Extracting LLB.n131b.RELEASE.im4p... Personalizing IMG4 component LLB... Extracting applelogo@448~watch.im4p... Personalizing IMG4 component AppleLogo... Extracting dali-ui.n131b.release.im4p... Personalizing IMG4 component Dali... Extracting DeviceTree.n131bap.im4p... Personalizing IMG4 component DeviceTree... Extracting recoverymode@448~watch.im4p... Personalizing IMG4 component RecoveryMode... Extracting WirelessPower.watch4.im4p... Personalizing IMG4 component WCHFirmwareUpdater... Extracting iBoot.n131b.RELEASE.im4p... Personalizing IMG4 component iBoot... Extracting sep-firmware.n131b.RELEASE.im4p... Personalizing IMG4 component RestoreSEP... Extracting sep-firmware.n131b.RELEASE.im4p... Personalizing IMG4 component SEP... Sending NORData now... Done sending NORData Fixing up /var (17) Creating system key bag (50) Connecting to FDR client at port 49159 Modifying persistent boot-args (25) Requesting EAN Data (74) Unmounting filesystems (29) Status message: Restore Finished Restore Finished Cleaning up... Done Operation finished! Removing USB\VID_05AC&PID_12AF\00008006-001A18263A39002E Waiting for program to exit ... |
The Following 2 Users Say Thank You to maxpatri9 For This Useful Post: |
