Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iBUS Tools For Apple Watch
Old 10-07-2022, 11:23   #1 (permalink)
Member: 3019950
series (SE) 40mm Unable to watch restore
[info] Using LATEST available IPSW.
[info] using cached version data
[info] Found device in DFU mode
[info] Gettting dfu mode device ...
[info] Identified device as Apple Watch SE, n140sap, Watch5,9
[erro] Can't find major version?!
[erro] can't get URL for latest firmware
[done] Operation finished!
[info] Using LOCAL IPSW C:\Users\shopp\Downloads\MFC_Watch5,9_19U66_8.7_n1 40sap_GPS_Restore_40mm.ipsw
[info] Extracting BuildManifest from ipsw
[data] Product Version: 8.7
[data] Product Build: 19U66 Major: 19
[data] Device supports Image4: true
[info] Variant: Customer Erase Install (IPSW)
[info] This restore will erase your device data.
[info] Checking IPSW for required components...
[info] All required components found in IPSW
[info] Found ECID 001a531621a3402e
[info] Getting ApNonce in dfu mode... [data] EF9696954F8CE57C5446FC65ECFA0139D72D6817F63DB7D258 525AAFC63A366B
[info] tts>Trying to fetch new SHSH blob
[info] Getting SepNonce in dfu mode... [data] BCAB5E8AC6F0F1DB9C5E8B763FC991D2CEA01AB8
[note] Unable to find BbChipID node
[note] Unable to find BbProvisioningManifestKeyHash node
[note] Unable to find BbActivationManifestKeyHash node
[note] Unable to find BbCalibrationManifestKeyHash node
[note] Unable to find BbFactoryActivationManifestKeyHash node
[note] Unable to find BbFDRSecurityKeyHash node
[note] Unable to find BbSkeyId node
[info] Request URL set to https://gs.apple.com/TSS/controller?action=2
[info] Sending TSS request attempt 1...
[info] response successfully received
[info] tts>Received SHSH blobs
Filesystem file not found!
We will extract the filesystem to file iDeviceTools/MFC_Watch5,9_19U66_8.7_n140sap_GPS_Restore_40mm/078-33105-073.dmg
[info] Extracting filesystem
[info] Extracting iBSS.n140s.RELEASE.im4p...
[info] Personalizing IMG4 component iBSS...
[info] Sending iBSS (1162693 bytes)...
[warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable!
[info] Device ecid 001a531621a3402e disconnect detected!
[info] Waiting for device arrival (timeout 20.000000 seconds)
[info] Found device in Recovery mode
[info] Noce: ef 96 96 95 4f 8c e5 7c 54 46 fc 65 ec fa 01 39 d7 2d 68 17 f6 3d b7 d2 58 52 5a af c6 3a 36 6b
[info] Extracting iBEC.n140s.RELEASE.im4p...
[info] Personalizing IMG4 component iBEC...
[info] Sending iBEC (1162693 bytes)...
[info] device serial number is G99FVC6SQ07R
[info] Recovery Mode Environment:
[info] iBoot build-version=iBoot-7459.140.15
[info] iBoot build-style=RELEASE
[info] Sending AppleLogo...
[warn] No path for component AppleLogo in TSS, will fetch from build_identity
[info] Extracting applelogo@394~watch.im4p...
[info] Personalizing IMG4 component AppleLogo...
[info] Sending AppleLogo (10138 bytes)...
[warn] No path for component ACIBT in TSS, will fetch from build_identity
[info] Extracting BT_FW_m9.im4p...
[info] Personalizing IMG4 component ACIBT...
[info] Sending ACIBT (1846417 bytes)...
[warn] No path for component ACIWIFI in TSS, will fetch from build_identity
[info] Extracting wifi_armv7r_m9_rtkit_image.im4p...
[info] Personalizing IMG4 component ACIWIFI...
[info] Sending ACIWIFI (1906601 bytes)...
[warn] No path for component ANE in TSS, will fetch from build_identity
[info] Extracting h11_ane_fw_mercury.im4p...
[info] Personalizing IMG4 component ANE...
[info] Sending ANE (1731605 bytes)...
[warn] No path for component AOP in TSS, will fetch from build_identity
[info] Extracting aopfw-n140aop.im4p...
[info] Personalizing IMG4 component AOP...
[info] Sending AOP (2071701 bytes)...
[warn] No path for component GFX in TSS, will fetch from build_identity
[info] Extracting armfw_g11m.im4p...
[info] Personalizing IMG4 component GFX...
[info] Sending GFX (897469 bytes)...
[warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity
[info] Extracting 078-33402-075.dmg.trustcache...
[info] Personalizing IMG4 component RestoreTrustCache...
[info] Sending RestoreTrustCache (16754 bytes)...
[warn] No path for component SCE in TSS, will fetch from build_identity
[info] Extracting scefw.im4p...
[info] Personalizing IMG4 component SCE...
[info] Sending SCE (20173 bytes)...
[warn] No path for component SIO in TSS, will fetch from build_identity
[info] Extracting SmartIOFirmware_ASCv2.im4p...
[info] Personalizing IMG4 component SIO...
[info] Sending SIO (1176673 bytes)...
[warn] No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity
[info] Extracting WirelessPower.watch4.im4p...
[info] Personalizing IMG4 component WCHFirmwareUpdater...
[info] Sending WCHFirmwareUpdater (31860 bytes)...
[warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity
[info] Extracting 078-33402-075.dmg...
[info] Personalizing IMG4 component RestoreRamDisk...
[info] Sending RestoreRamDisk (88987800 bytes)...
[warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity
[info] Extracting DeviceTree.n140sap.im4p...
[info] Personalizing IMG4 component RestoreDeviceTree...
[info] Sending RestoreDeviceTree (42861 bytes)...
[warn] No path for component RestoreSEP in TSS, will fetch from build_identity
[info] Extracting sep-firmware.n140s.RELEASE.im4p...
[info] Personalizing IMG4 component RestoreSEP...
[info] Sending RestoreSEP (5463422 bytes)...
[warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity
[info] Extracting kernelcache.release.watch5...
[info] Personalizing IMG4 component RestoreKernelCache...
[info] Sending RestoreKernelCache (13479465 bytes)...
[info] About to restore device...
[info] Waiting for device...
[info] Device is now connected in restore mode...
[info] Connecting now...
[info] Connected to com.apple.mobile.restored, version 15
[info] Device 00008006-001A531621A3402E has successfully entered restore mode
[info] Hardware Information:
[info] BoardID: 40
[info] ChipID: 32774
[info] UniqueChipID: 7409703913209902
[info] ProductionMode: true
[sett] Previous restore exit status: 256
[info] Starting FDR listener thread
[info] Connecting to FDR client at port 1082
[warn] About to do ctrl handshake
[done] Ctrl handshake done (ConnPort = 49159)
[warn] Requesting NOT TO Update Baseband
[info] Checkpoint 1621 complete with code 0
[info] Checkpoint 1540 complete with code 0
[info] Checkpoint 1679 complete with code 0
[info] About to send RootTicket...
[info] Sending RootTicket now...
[info] Done sending RootTicket
[info] Checkpoint 1547 complete with code 0
[info] Waiting for NAND (28)
[info] Checkpoint 1549 complete with code 0
[info] Updating NAND Firmware (58)
[info] Checkpoint 1550 complete with code 0
[info] Checkpoint 1551 complete with code 0
[info] Checkpoint 1628 complete with code 0
[info] Checkpoint 1552 complete with code 0
[info] Checkpoint 1555 complete with code 0
[info] Checkpoint 1662 complete with code 0
[info] Sending NORData...
[info] Found firmware path Firmware/all_flash
[erro] zip_name_locate: Firmware/all_flash/manifest
[info] Getting firmware manifest from build identity
[info] Extracting LLB.n140s.RELEASE.im4p...
[info] Personalizing IMG4 component LLB...
[info] Extracting dali-ui.n140s.release.im4p...
[info] Personalizing IMG4 component Dali...
[info] Personalizing IMG4 component DeviceTree...
[info] Extracting recoverymode@394~watch.im4p...
[info] Personalizing IMG4 component RecoveryMode...
[info] Extracting iBoot.n140s.RELEASE.im4p...
[info] Personalizing IMG4 component iBoot...
[info] Personalizing IMG4 component SEP...
[info] Sending NORData now...
[info] Done sending NORData
[info] Checkpoint 1545 complete with code 0
[info] Checkpoint 1683 complete with code 0
[info] Unmounting filesystems (29)
[info] Checkpoint 1637 complete with code 0
[info] Checkpoint 1556 complete with code 0
[info] Checkpoint 1686 complete with code 0
[info] Checkpoint 1699 complete with code 0
[info] Checkpoint 1695 complete with code 0
[info] Checkpoint 1620 complete with code 0
[info] Checkpoint 1687 complete with code 0
[info] Checkpoint 1557 complete with code 0
[info] About to send FDR Trust data...
[info] Sending FDR Trust data now...
[done] sending FDR Trust Data
[info] Checkpoint 1558 complete with code 0
[info] Checkpoint 1559 complete with code 0
[info] Checkpoint 1560 complete with code 0
[info] Checking for uncollected logs (44)
[info] Checkpoint 1561 complete with code 0
[info] Connecting to FDR client at port 49159
[info] Checkpoint 1562 complete with code 0
[info] FDR 08834090 Proxy connect request to xp.apple.com:443
[info] Checkpoint 1563 complete with code 0
[info] Checkpoint 1633 complete with code 0
[erro] FDR 08834090 Unable to receive proxy payload (-3)
[info] Checkpoint 1565 complete with code 0
[info] Checkpoint 1614 complete with code 0
[info] Checkpoint 1567 complete with code 0
[info] Checkpoint 1674 complete with code 0
[info] Creating partition map (11)
[info] Checkpoint 1569 complete with code 0
[info] Checkpoint 1632 complete with code 0
[info] Checkpoint 1570 complete with code 0
[info] Checkpoint 1629 complete with code 0
[info] Checkpoint 5645 complete with code 0
[info] Creating filesystem (12)
[info] Checkpoint 1624 complete with code 0
[info] Checkpoint 1625 complete with code 0
[info] Checkpoint 1626 complete with code 0
[info] About to send filesystem...
[info] Connected to ASR
[info] Validating the filesystem
[info] Filesystem validated
[info] Sending filesystem now...
[done] sending filesystem
[info] Operation: Verifying restore (14)
[info] Checkpoint 1627 complete with code 0
[info] Checkpoint 1664 complete with code 0
[info] Checkpoint 1653 complete with code 0
[info] Checkpoint 1676 complete with code 0
[info] Checking filesystems (15)
[info] Mounting filesystems (16)
[info] Checkpoint 1574 complete with code 0
[info] Checkpoint 1634 complete with code 0
[info] Checkpoint 1655 complete with code 0
[info] Checkpoint 1658 complete with code 0
[info] Checkpoint 1575 complete with code 0
[info] Checkpoint 1690 complete with code 0
[info] Checkpoint 1691 complete with code 0
[info] Checkpoint 1618 complete with code 0
[info] Checkpoint 1588 complete with code 0
[info] Checkpoint 1661 complete with code 0
[info] Operation: Unknown operation (80)
[info] Sending IsiBootEANFirmware image list
[info] Sending IsiBootNonEssentialFirmware image list
[info] Flashing firmware (18)
[info] Checkpoint 4864 complete with code 0
[info] Sending IsEarlyAccessFirmware image list
[info] Checkpoint 4882 complete with code 0
[info] Operation: Requesting FUD data (36)
[info] Found IsFUDFirmware component ACIBT
[info] Found IsFUDFirmware component ACIWIFI
[info] Found IsFUDFirmware component ANE
[info] Found IsFUDFirmware component AOP
[info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata
[info] Found IsFUDFirmware component GFX
[info] Found IsFUDFirmware component LeapHaptics
[info] Found IsFUDFirmware component Multitouch
[info] Found IsFUDFirmware component RTP
[info] Found IsFUDFirmware component RestoreTrustCache
[info] Found IsFUDFirmware component SCE
[info] Found IsFUDFirmware component SIO
[info] Found IsFUDFirmware component StaticTrustCache
[info] Found IsFUDFirmware component SystemVolume
[info] Sending IsFUDFirmware image list
[info] Sending IsFUDFirmware for ACIBT...
[info] Sending IsFUDFirmware for ACIWIFI...
[info] Sending IsFUDFirmware for ANE...
[info] Sending IsFUDFirmware for AOP...
[info] Extracting 078-33105-073.dmg.mtree...
[info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata...
[info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata...
[info] Sending IsFUDFirmware for GFX...
[info] Extracting N140S_LeapHapticsFirmware.im4p...
[info] Personalizing IMG4 component LeapHaptics...
[info] Sending IsFUDFirmware for LeapHaptics...
[info] Extracting N140s_Multitouch.im4p...
[info] Personalizing IMG4 component Multitouch...
[info] Sending IsFUDFirmware for Multitouch...
[info] Extracting rtpfw.im4p...
[info] Personalizing IMG4 component RTP...
[info] Sending IsFUDFirmware for RTP...
[info] Sending IsFUDFirmware for RestoreTrustCache...
[info] Sending IsFUDFirmware for SCE...
[info] Sending IsFUDFirmware for SIO...
[info] Extracting 078-33105-073.dmg.trustcache...
[info] Personalizing IMG4 component StaticTrustCache...
[info] Sending IsFUDFirmware for StaticTrustCache...
[info] Extracting 078-33105-073.dmg.root_hash...
[info] Personalizing IMG4 component SystemVolume...
[info] Sending IsFUDFirmware for SystemVolume...
[info] Checkpoint 4874 complete with code 0
[info] Updating gas gauge software (47)
[info] Checkpoint 4865 complete with code 0
[info] Checkpoint 4866 complete with code 0
[info] Updating Stockholm (55)
[info] Checkpoint 4868 complete with code 0
[info] Checkpoint 4868 complete with code 18446744073709551615
[info] Checkpoint 1589 complete with code 56
[info] Checkpoint 1659 complete with code 56
[info] Checkpoint 1660 complete with code 0
[info] Checkpoint 5651 complete with code 0
[info] Checkpoint 1607 complete with code 0
[info] Status message: Ramrod firmware update failed.
Hint: The display of this model is not compatible, or you can replace the NFC module
[sett] Log is available in ErrorLog.plist
[erro] Unable to successfully restore device
[info] Checkpoint 1608 complete with code 0
[erro] Unable to restore device
[info] Removing USB\VID_05AC&PID_12AF\00008006-001A531621A3402E
Old 10-08-2022, 03:33   #2 (permalink)
Member: 2277861
Thanks Meter: 213
Old 10-08-2022, 07:32   #3 (permalink)
Member: 3019950
thanks mfc
thanks mfc for replying us
br
Page generated in 0.16819 seconds with 8 queries
