byteforce2016 | 12-29-2023 00:47 | Managed to make it update without clearing userdata: Code:
[info] Found device in Normal mode
[info] Gettting normal mode device ...
[info] Database recognized as:
Generation: Apple Watch S5
'A' Number Bootrom 3988.0.0.2.12
Bootrom A2092
Variant Watch5,1
FCC ID BCG-A2092
Internal Name N144sAP
Identifier Watch5,1
Color Aluminium Gold
Storage 40 GB
Model MWRY2
[info] changing mode from Normal to Recovery
[info] Removed (Apple, Inc.,USB\VID_05AC&PID_12AF\00008006000A65C822C3802E)
[info] Arrival (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CPFM:03_SCEP:01_BDID:10_ECID:000A65C822C3802E_IBFL:3D_SRNM:[G99CPMCEMLTJ])
[info] device serial number is G99CPMCEMLTJ
[warn] operation not defined!
[done] Operation finished!
[info] Using LATEST available file.
[erro] We don't know firmware locations for device OS type!
[info] Found device in Recovery mode
[info] Gettting dfu mode device ...
Bootrom A2092
Variant Watch5,1
FCC ID BCG-A2092
Identifier Watch5,1
Storage 40 GB
Model MWRY2
[erro] Can't find MobileDeviceSoftwareVersionsByVersion dict in version data
[erro] can't get URL for latest firmware
[info] Using local file D:\MFCBOX\iWatch Firmware\MFC_Watch5,1_20U502_9.6.3_n144sap_GPS_Restore_40mm.ipsw
Bootrom A2092
Variant Watch5,1
FCC ID BCG-A2092
Identifier Watch5,1
Storage 40 GB
Model MWRY2
[info] Extracting BuildManifest from ipsw
[data] Product Version: 9.6.3
[data] Product Build: 20U502 Major: 20
[data] Device supports Image4: true
[info] Variant: Customer Upgrade Install (IPSW)
[info] This restore will update the device without erasing user data.
[info] Checking for required components...
[info] Using ECID 000a65c822c3802e
[info] Getting ApNonce in recovery mode... [data] CBCE03FB5EA3E1D63B86207A525ACD4A04626E9CA49B8E45576823EC9453BFE1
[info] tts>Trying to fetch new SHSH blob
[info] Getting SepNonce in recovery mode... [data] 392D8D0BB5B686F21204012D8E407138C5CC4DB6
[note] Unable to find BbChipID node
[note] Unable to find BbProvisioningManifestKeyHash node
[note] Unable to find BbActivationManifestKeyHash node
[note] Unable to find BbCalibrationManifestKeyHash node
[note] Unable to find BbFactoryActivationManifestKeyHash node
[note] Unable to find BbFDRSecurityKeyHash node
[note] Unable to find BbSkeyId node
[info] Request URL set to https://gs.apple.com/TSS/controller?action=2
[info] Sending TSS request attempt 1...
[info] response successfully received
[info] tts>Received SHSH blobs
[warn] Unable to find component node for Cryptex1,SystemOS
[info] Extracting filesystem...
[info] Removed (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CPFM:03_SCEP:01_BDID:10_ECID:000A65C822C3802E_IBFL:3D_SRNM:[G99CPMCEMLTJ])
[erro] Device is in an invalid state
[erro] Unable to find device ECID
[erro] Usbmux could not find any device!
[info] Please put the device in DFU mode and try again!
[warn] Operation aborted by user!
Bootrom A2092
Variant Watch5,1
FCC ID BCG-A2092
Identifier Watch5,1
Storage 40 GB
Model MWRY2
[info] Getting ApNonce in recovery mode... [data] B8133B77797411BB488E0E231E8EF35A1767C2C98BC803F804DC9E36DA8A0FC5
[info] Getting SepNonce in recovery mode... [data] 61D371EB6CD58980F8E838A5B809250967E1C357
[info] Using cached file 'D:\MFCBOX\iWatch Firmware\MFC_Watch5,1_20U502_9.6.3_n144sap_GPS_Restore_40mm\097-48531-003.dmg'
[info] Found ECID 000a65c822c3802e
[warn] No path for component iBEC in TSS, will fetch from build_identity
[info] Personalizing IMG4 component iBEC...
[info] Sending iBEC (1182215 bytes)...
[info] Device ecid 000a65c822c3802e disconnect detected!
[info] Arrival (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CPFM:03_SCEP:01_BDID:10_ECID:000A65C822C3802E_IBFL:3C_SRNM:[G99CPMCEMLTJ])
[info] Recovery Mode Environment:
[info] iBoot build-version=iBoot-8422.140.59
[info] iBoot build-style=RELEASE
[info] Sending AppleLogo...
[warn] No path for component AppleLogo in TSS, will fetch from build_identity
[info] Personalizing IMG4 component AppleLogo...
[info] Sending AppleLogo (10155 bytes)...
[warn] No path for component ACIBT in TSS, will fetch from build_identity
[info] Personalizing IMG4 component ACIBT...
[info] Sending ACIBT (1958115 bytes)...
[warn] No path for component ACIWIFI in TSS, will fetch from build_identity
[info] Personalizing IMG4 component ACIWIFI...
[info] Sending ACIWIFI (1937295 bytes)...
[warn] No path for component ANE in TSS, will fetch from build_identity
[info] Personalizing IMG4 component ANE...
[info] Sending ANE (1771159 bytes)...
[warn] No path for component AOP in TSS, will fetch from build_identity
[info] Personalizing IMG4 component AOP...
[info] Sending AOP (1608871 bytes)...
[warn] No path for component GFX in TSS, will fetch from build_identity
[info] Personalizing IMG4 component GFX...
[info] Sending GFX (881535 bytes)...
[warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity
[info] Personalizing IMG4 component RestoreTrustCache...
[info] Sending RestoreTrustCache (17828 bytes)...
[warn] No path for component SCE in TSS, will fetch from build_identity
[info] Personalizing IMG4 component SCE...
[info] Sending SCE (20157 bytes)...
[warn] No path for component SIO in TSS, will fetch from build_identity
[info] Personalizing IMG4 component SIO...
[info] Sending SIO (1160603 bytes)...
[warn] No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity
[info] Personalizing IMG4 component WCHFirmwareUpdater...
[info] Sending WCHFirmwareUpdater (33286 bytes)...
[warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity
[info] Personalizing IMG4 component RestoreRamDisk...
[info] Sending RestoreRamDisk (94379178 bytes)...
[warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity
[info] Personalizing IMG4 component RestoreDeviceTree...
[info] Sending RestoreDeviceTree (43088 bytes)...
[warn] No path for component RestoreSEP in TSS, will fetch from build_identity
[info] Personalizing IMG4 component RestoreSEP...
[info] Sending RestoreSEP (3366288 bytes)...
[warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity
[info] Personalizing IMG4 component RestoreKernelCache...
[info] Sending RestoreKernelCache (14708216 bytes)...
[info] About to restore device...
[info] Waiting for device...
[info] Device is now connected in restore mode...
[info] Connecting now...
[info] Connected to com.apple.mobile.restored, version 15
[info] Device 00008006-000A65C822C3802E has successfully entered restore mode
[info] Hardware Information:
[info] BoardID: 16
[info] ChipID: 32774
[info] UniqueChipID: 2926660018208814
[info] ProductionMode: true
[info] Starting FDR listener thread
[info] Connecting to FDR client at port 1082
[warn] About to do ctrl handshake
[done] Ctrl handshake done (ConnPort = 49158)
[warn] Requesting NOT TO Update Baseband
[info] Checkpoint 1621 complete with code 0
[info] Checkpoint 1540 complete with code 0
[info] Checkpoint 1679 complete with code 0
[info] About to send RootTicket...
[info] Sending RootTicket now...
[done] sending RootTicket
[info] Checkpoint 1547 complete with code 0
[info] Waiting for NAND (28)
[info] Checkpoint 1549 complete with code 0
[info] Updating NAND Firmware (58)
[info] Checkpoint 1550 complete with code 0
[info] Checkpoint 1551 complete with code 0
[info] Checkpoint 1628 complete with code 0
[info] Checkpoint 1552 complete with code 0
[info] Checkpoint 1555 complete with code 0
[info] Checkpoint 1662 complete with code 0
[info] Sending NORData...
[info] Found firmware path Firmware/all_flash
[info] Getting firmware manifest from build identity
[info] Personalizing IMG4 component LLB...
[info] Personalizing IMG4 component Dali...
[info] Personalizing IMG4 component DeviceTree...
[info] Personalizing IMG4 component RecoveryMode...
[info] Personalizing IMG4 component iBoot...
[info] Personalizing IMG4 component SEP...
[info] Sending NORData now...
[done] Done sending NORData
[info] Checkpoint 1545 complete with code 0
[info] Checkpoint 1683 complete with code 0
[info] Unmounting filesystems (29)
[info] Checking filesystems (15)
[info] Checkpoint 1637 complete with code 0
[info] Checkpoint 1556 complete with code 0
[info] Checkpoint 1686 complete with code 0
[info] Checkpoint 1699 complete with code 0
[info] Checkpoint 1695 complete with code 0
[info] Checkpoint 1620 complete with code 0
[info] Checkpoint 1687 complete with code 0
[info] Checkpoint 1557 complete with code 0
[info] About to send FDR Trust data...
[info] Sending FDR Trust data now...
[done] sending FDR Trust Data
[info] Checkpoint 1558 complete with code 0
[info] Checkpoint 1559 complete with code 0
[info] Checkpoint 1560 complete with code 0
[info] Checking for uncollected logs (44)
[info] Checkpoint 1561 complete with code 0
[info] Connecting to FDR client at port 49158
[info] Checkpoint 1562 complete with code 0
[info] Checkpoint 1563 complete with code 0
[info] Checkpoint 1633 complete with code 0
[info] Checkpoint 1565 complete with code 0
[info] Checkpoint 1614 complete with code 0
[info] Checkpoint 1567 complete with code 0
[info] Checkpoint 1674 complete with code 0
[info] Checkpoint 1632 complete with code 0
[info] Checkpoint 1570 complete with code 0
[info] Checkpoint 1629 complete with code 0
[info] Checkpoint 5645 complete with code 0
[info] Creating filesystem (12)
[info] Checkpoint 1624 complete with code 0
[info] Checkpoint 1625 complete with code 0
[info] Checkpoint 1626 complete with code 0
[info] About to send filesystem...
[info] Connected to ASR
[info] Validating the filesystem
[info] Filesystem validated
[info] Sending filesystem now...
[done] sending filesystem
[info] Operation: Verifying restore (14)
[info] Checkpoint 1627 complete with code 0
[info] Checkpoint 1664 complete with code 0
[info] Checkpoint 1653 complete with code 0
[info] Checkpoint 1676 complete with code 0
[info] Mounting filesystems (16)
[info] Checkpoint 1574 complete with code 0
[info] Checkpoint 1634 complete with code 0
[info] Checkpoint 1655 complete with code 0
[info] Checkpoint 1658 complete with code 0
[info] Checkpoint 1575 complete with code 0
[info] Checkpoint 1690 complete with code 0
[info] Checkpoint 1691 complete with code 0
[info] Checkpoint 1618 complete with code 0
[info] Checkpoint 1588 complete with code 0
[info] Checkpoint 1661 complete with code 0
[info] Operation: Unknown operation (80)
[info] Sending IsiBootEANFirmware image list
[info] Sending IsiBootNonEssentialFirmware image list
[info] Flashing firmware (18)
[info] Checkpoint 4864 complete with code 0
[info] Sending IsEarlyAccessFirmware image list
[info] Checkpoint 4882 complete with code 0
[info] Operation: Requesting FUD data (36)
[info] Found IsFUDFirmware component ACIBT
[info] Found IsFUDFirmware component ACIWIFI
[info] Found IsFUDFirmware component ANE
[info] Found IsFUDFirmware component AOP
[info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata
[info] Found IsFUDFirmware component GFX
[info] Found IsFUDFirmware component LeapHaptics
[info] Found IsFUDFirmware component Multitouch
[info] Found IsFUDFirmware component RTP
[info] Found IsFUDFirmware component RestoreTrustCache
[info] Found IsFUDFirmware component SCE
[info] Found IsFUDFirmware component SIO
[info] Found IsFUDFirmware component StaticTrustCache
[info] Found IsFUDFirmware component SystemVolume
[info] Sending IsFUDFirmware image list
[info] Sending IsFUDFirmware for ACIBT...
[info] Sending IsFUDFirmware for ACIWIFI...
[info] Sending IsFUDFirmware for ANE...
[info] Sending IsFUDFirmware for AOP...
[info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata...
[info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata...
[info] Sending IsFUDFirmware for GFX...
[info] Personalizing IMG4 component LeapHaptics...
[info] Sending IsFUDFirmware for LeapHaptics...
[info] Personalizing IMG4 component Multitouch...
[info] Sending IsFUDFirmware for Multitouch...
[info] Personalizing IMG4 component RTP...
[info] Sending IsFUDFirmware for RTP...
[info] Sending IsFUDFirmware for RestoreTrustCache...
[info] Sending IsFUDFirmware for SCE...
[info] Sending IsFUDFirmware for SIO...
[info] Personalizing IMG4 component StaticTrustCache...
[info] Sending IsFUDFirmware for StaticTrustCache...
[info] Personalizing IMG4 component SystemVolume...
[info] Sending IsFUDFirmware for SystemVolume...
[info] Checkpoint 4874 complete with code 0
[info] Updating gas gauge software (47)
[info] Checkpoint 4865 complete with code 0
[info] Checkpoint 4866 complete with code 0
[info] Updating Stockholm (55)
[info] Checkpoint 4868 complete with code 0
[info] Checkpoint 4869 complete with code 0
[info] Checkpoint 4876 complete with code 0
[info] Checkpoint 4870 complete with code 0
[info] Checkpoint 4871 complete with code 0
[info] Checkpoint 4872 complete with code 0
[info] Checkpoint 4878 complete with code 0
[info] Checkpoint 4879 complete with code 0
[info] Checkpoint 4875 complete with code 0
[info] Checkpoint 4867 complete with code 0
[info] Checkpoint 4880 complete with code 0
[info] Checkpoint 4895 complete with code 0
[info] Updating SE Firmware (59)
[info] About to send BuildIdentity Dict...
[info] Sending BuildIdentityDict now...
[done] sending BuildIdentityDict
[info] About to send SE,UpdatePayload...
[info] Sending SE,UpdatePayload now...
[done] sending SE,UpdatePayload
[info] Sending SE TSS request...
[info] Received SE ticket
[info] Sending FirmwareResponse data now...
[done] sending FirmwareUpdater data
[info] Checkpoint 4873 complete with code 0
[info] Unknown operation (79)
[info] Checkpoint 4886 complete with code 0
[info] Checkpoint 1589 complete with code 0
[info] Checkpoint 1596 complete with code 0
[info] Checkpoint 5379 complete with code 0
[info] Checkpoint 4890 complete with code 0
[info] Checkpoint 4889 complete with code 0
[info] Requesting EAN Data (74)
[info] Checkpoint 5380 complete with code 0
[info] Checkpoint 4884 complete with code 0
[info] Checkpoint 1640 complete with code 0
[info] Checkpoint 1597 complete with code 0
[info] Checkpoint 1647 complete with code 0
[info] Creating Protected Volume (67)
[info] Checkpoint 1652 complete with code 0
[info] Checkpoint 1631 complete with code 0
[info] About to send KernelCache...
[warn] No path for component KernelCache in TSS, will fetch from build identity
[info] Personalizing IMG4 component KernelCache...
[info] Sending KernelCache ...
[done] Done sending KernelCache
[info] Installing kernelcache (27)
[info] Checkpoint 3584 complete with code 0
[info] About to send DeviceTree...
[warn] No path for component DeviceTree in TSS, will fetch from build identity
[info] Sending DeviceTree ...
[done] Done sending DeviceTree
[info] Installing DeviceTree (61)
[info] Checkpoint 3585 complete with code 0
[info] Checkpoint 3588 complete with code 0
[info] Checkpoint 3589 complete with code 0
[info] Checkpoint 3587 complete with code 0
[info] Checkpoint 1576 complete with code 0
[info] Fixing up /var (17)
[info] Checkpoint 3840 complete with code 0
[info] Checkpoint 3841 complete with code 0
[info] Checkpoint 3842 complete with code 0
[info] Checkpoint 3844 complete with code 0
[info] Checkpoint 3849 complete with code 0
[info] Checkpoint 1613 complete with code 0
[info] Checkpoint 1694 complete with code 0
[info] Checkpoint 1595 complete with code 0
[info] Modifying persistent boot-args (25)
[info] Checkpoint 1593 complete with code 0
[info] Checkpoint 1630 complete with code 0
[info] Checkpoint 1672 complete with code 0
[info] Checkpoint 1659 complete with code 0
[info] Checkpoint 5632 complete with code 0
[info] Checkpoint 1599 complete with code 0
[info] Checkpoint 1600 complete with code 0
[info] Checkpoint 1675 complete with code 0
[info] Checkpoint 1641 complete with code 0
[info] Checkpoint 1706 complete with code 0
[info] Checkpoint 1707 complete with code 0
[info] Checkpoint 1602 complete with code 0
[info] Checkpoint 1660 complete with code 0
[info] Checkpoint 5651 complete with code 0
[info] Checkpoint 1607 complete with code 0
[info] Status message: Restore Finished
[info] Cleaning up...
[done] Done
[info] Removed (Apple, Inc.,USB\VID_05AC&PID_12AF\00008006-000A65C822C3802E) |
