watch s2 error apple watch s2 42. brought the watch with a constant reboot. when flashing after unpacking the file, it does not go into recording mode, as I understand it with memory? [info] Using local file C:\Users\PC\Downloads\Watch2,7_n28dap_42mm_Watch2, 4_n75ap_42mm_6.3_17U208_restore.ipsw [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 6.3 [data] Product Build: 17U208 Major: 17 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 001718aa208bad26 [info] Getting ApNonce in dfu mode... [data] 25AB76871DFD2EA8E72C0147981F4EC20303439F5B0C167266 62202B339A806F [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] F4BE2546231B32E0CAF6115CD3CE779E5C6B3B7E [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs Filesystem file not found! We will extract the filesystem to file iDeviceTools/Watch2,7_n28dap_42mm_Watch2,4_n7/038-87845-009.dmg [info] Extracting filesystem [info] Found ECID 001718aa208bad26 [info] Getting ApNonce in dfu mode... [data] 25AB76871DFD2EA8E72C0147981F4EC20303439F5B0C167266 62202B339A806F [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] F4BE2546231B32E0CAF6115CD3CE779E5C6B3B7E [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n65.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [warn] Tag not processed for iBSS! [info] Sending iBSS (747975 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 001718aa208bad26 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [erro] Unable to find required ApNonce in parameters [erro] tts>Unable to add img4 tags to TSS request [erro] Unable to get SHSH blobs for this device [erro] Unable to place device into recovery mode from Recovery mode [done] Operation finished! |
fixed drivers with 3utool. But they still do not load after loading into an apple with a slider [info] Using local file C:\Users\PC\Downloads\Watch2,7_n28dap_42mm_Watch2, 4_n75ap_42mm_6.3_17U208_restore.ipsw [info] using cached version data [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 6.3 [data] Product Build: 17U208 Major: 17 [info] device serial number is [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 001718aa208bad26 [info] Getting ApNonce in recovery mode... [data] F9F6FAC04AA8436E958BB9B66AEBAA64EA317B1CFA6C603ED1 B418CFD92C20F2 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] AC2D649C83294C54BBE638C01F1745F72BDF940D [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/Watch2,7_n28dap_42mm_Watch2,4_n7/038-87845-009.dmg' [info] Found ECID 001718aa208bad26 [info] Getting ApNonce in recovery mode... [data] F9F6FAC04AA8436E958BB9B66AEBAA64EA317B1CFA6C603ED1 B418CFD92C20F2 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] AC2D649C83294C54BBE638C01F1745F72BDF940D [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n65.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [warn] Tag not processed for iBEC! [info] Sending iBEC (747975 bytes)... [info] Device ecid 001718aa208bad26 disconnect detected! [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-5540.144.2 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [warn] Tag not processed for AppleLogo! [info] Sending AppleLogo (8706 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 038-87586-010.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (13743 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 038-87586-010.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [warn] Tag not processed for RestoreRamDisk! [info] Sending RestoreRamDisk (67956485 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n75ap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (110731 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n75.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2103233 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch2... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (11149214 bytes)... [warn] Device ecid 001718aa208bad26 disconnect not detected! It might be possible to continue! [info] Waiting for device to reconnect in Restore mode... [erro] Device failed to enter Restore mode [erro] Device did not reconnect in recovery mode. Possibly invalid iBEC. Reset device and try again. [erro] Unable to place device into restore mode [done] Operation finished! |
you have to use new version . eg , V3.9.0.2 or V4.0 |
[info] Using local file C:\Users\PC\Downloads\Watch2,7_n28dap_42mm_Watch2, 4_n75ap_42mm_6.3_17U208_restore.ipsw [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 6.3 [data] Product Build: 17U208 Major: 17 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 001718aa208bad26 [info] Getting ApNonce in dfu mode... [data] 7ADB6FA3C2EC47B9C7B4BFC5AF51CFA924CFD1C6D41A0E00D5 C731FE30A66026 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 53CDD04E95C7F111BD9B70ACADEAC8612801794C [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/Watch2,7_n28dap_42mm_Watch2,4_n75ap_42mm_6.3_17U20 8_restore/038-87845-009.dmg' [info] Found ECID 001718aa208bad26 [info] Getting ApNonce in dfu mode... [data] 7ADB6FA3C2EC47B9C7B4BFC5AF51CFA924CFD1C6D41A0E00D5 C731FE30A66026 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 53CDD04E95C7F111BD9B70ACADEAC8612801794C [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n65.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [warn] Tag not processed for iBSS! [info] Sending iBSS (747975 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 001718aa208bad26 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: 7a db 6f a3 c2 ec 47 b9 c7 b4 bf c5 af 51 cf a9 24 cf d1 c6 d4 1a 0e 00 d5 c7 31 fe 30 a6 60 26 [info] Extracting iBEC.n65.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [warn] Tag not processed for iBEC! [info] Sending iBEC (747975 bytes)... [erro] IIII [erro] IIIIIIIIIIIIIIIIII [erro] IIIIIIIIIIIIIIIIIIII [erro] IIIIIIIIIIIIIIIIII [erro] IIIIIIIIIIIIIIIIIIII [erro] IIIIIIIIIIIIIIIIII [erro] IIIIIIIIIIIIIIIIIIII [erro] IIIIIIIIIIIIIIIIII [erro] IIIIIIIIIIIIIIIIIIII [erro] IIIIIIIIIIIIIIIIII [erro] IIIIIIIIIIIIIIIIIIII [erro] IIIIIIIIIIIIIIIIII [erro] IIIIIIIIIIIIIIIIIIII [warn] Device ecid 001718aa208bad26 disconnect not detected! It might be possible to continue! [info] device serial number is [info] Recovery Mode Environment: [info] iBoot build-version= [info] iBoot build-style= [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [warn] Tag not processed for AppleLogo! [info] Sending AppleLogo (8706 bytes)... [erro] Unable to send AppleLogo component: Unable to find device [erro] Unable to send AppleLogo to device. [erro] Unable to send AppleLogo [erro] Unable to place device into restore mode [erro] IIIIIIII [done] Operation finished! |
[info] Using local file C:\Users\PC\Downloads\Watch2,7_n28dap_42mm_Watch2, 4_n75ap_42mm_6.3_17U208_restore.ipsw [info] using cached version data [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 6.3 [data] Product Build: 17U208 Major: 17 [info] device serial number is [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 001718aa208bad26 [info] Getting ApNonce in recovery mode... [data] F7BAF075E9343AAA40D3465BEE547FBF40C22780F619D66284 6DE535976B3CB1 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 0FE8D95483A3CC054A9EACCF7BD70C922D5C0B80 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/Watch2,7_n28dap_42mm_Watch2,4_n75ap_42mm_6.3_17U20 8_restore/038-87845-009.dmg' [info] Found ECID 001718aa208bad26 [info] Getting ApNonce in recovery mode... [data] F7BAF075E9343AAA40D3465BEE547FBF40C22780F619D66284 6DE535976B3CB1 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 0FE8D95483A3CC054A9EACCF7BD70C922D5C0B80 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n65.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [warn] Tag not processed for iBEC! [info] Sending iBEC (747975 bytes)... [info] Device ecid 001718aa208bad26 disconnect detected! [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-5540.144.2 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [warn] Tag not processed for AppleLogo! [info] Sending AppleLogo (8706 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 038-87586-010.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (13743 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 038-87586-010.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [warn] Tag not processed for RestoreRamDisk! [info] Sending RestoreRamDisk (67956485 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n75ap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (110731 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n75.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2103233 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch2... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (11149214 bytes)... [info] Device ecid 001718aa208bad26 disconnect detected! [erro] II [info] Waiting for device to reconnect in Restore mode... [erro] Device failed to enter Restore mode [erro] Device did not reconnect in recovery mode. Possibly invalid iBEC. Reset device and try again. [erro] Unable to place device into restore mode [done] Operation finished! |
You have watch driver issue ! |
which software version you are using ? |
i just tested V3.9.0.2 4.0B1 & 4.0B2 without the issue you said above ! A, check watch driver B, check connection between ibus ~ watch |
No, va your logs as we can saw with error at the end , so it's not normal Code: [erro] Device failed to enter Restore mode |
