Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iBUS Tools For Apple Watch
Old 03-04-2023, 15:41   #1 (permalink)
Member: 605628
Watch S3 restore error please help
hi i am getting error in restoring apple wach s3 please help here is the log
[info] Using LOCAL IPSW D:\IPSW\MFC_Watch3,4_19U67_8.7.1_n121bAP_GPS_Resto re_42mm.ipsw
[info] using cached version data
[info] Found device in DFU mode
[info] Gettting dfu mode device ...
[info] Identified device as Apple Watch S3, n121bap, Watch3,4
[info] Extracting BuildManifest from ipsw
[data] Product Version: 8.7.1
[data] Product Build: 19U67 Major: 19
[data] Device supports Image4: true
[info] Variant: Customer Erase Install (IPSW)
[info] This restore will erase your device data.
[info] Checking IPSW for required components...
[info] All required components found in IPSW
[info] Found ECID 00062c96386840a6
[info] Getting ApNonce in dfu mode... [data] F8AD47DC2E88BEA00462ECA6653C717920C192AF6DF34F820D D9EB41E272E375
[info] tts>Trying to fetch new SHSH blob
[info] Getting SepNonce in dfu mode... [data] 573B3FE3A1BE9A06D94A8689326DD4B8B19EA4F6
[note] Unable to find BbChipID node
[note] Unable to find BbProvisioningManifestKeyHash node
[note] Unable to find BbActivationManifestKeyHash node
[note] Unable to find BbCalibrationManifestKeyHash node
[note] Unable to find BbFactoryActivationManifestKeyHash node
[note] Unable to find BbFDRSecurityKeyHash node
[note] Unable to find BbSkeyId node
[info] Request URL set to https://gs.apple.com/TSS/controller?action=2
[info] Sending TSS request attempt 1...
[info] response successfully received
[info] tts>Received SHSH blobs
[info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,4_19U67_8.7.1_n121bAP_GPS_Restore_42mm/078-33421-074.dmg'
[info] Extracting iBSS.n121b.RELEASE.im4p...
[info] Personalizing IMG4 component iBSS...
[info] Sending iBSS (773157 bytes)...
[warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable!
[info] Device ecid 00062c96386840a6 disconnect detected!
[info] Waiting for device arrival (timeout 20.000000 seconds)
[info] Found device in Recovery mode
[info] Noce: f8 ad 47 dc 2e 88 be a0 04 62 ec a6 65 3c 71 79 20 c1 92 af 6d f3 4f 82 0d d9 eb 41 e2 72 e3 75
[info] Extracting iBEC.n121b.RELEASE.im4p...
[info] Personalizing IMG4 component iBEC...
[info] Sending iBEC (773157 bytes)...
[info] device serial number is FHLVN3YAJ5X3
[info] Recovery Mode Environment:
[info] iBoot build-version=iBoot-7459.140.15
[info] iBoot build-style=RELEASE
[info] Sending AppleLogo...
[warn] No path for component AppleLogo in TSS, will fetch from build_identity
[info] Extracting [email protected]~watch.im4p...
[info] Personalizing IMG4 component AppleLogo...
[info] Sending AppleLogo (9313 bytes)...
[warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity
[info] Extracting 078-33379-076.dmg.trustcache...
[info] Personalizing IMG4 component RestoreTrustCache...
[info] Sending RestoreTrustCache (15624 bytes)...
[warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity
[info] Extracting 078-33379-076.dmg...
[info] Personalizing IMG4 component RestoreRamDisk...
[info] Sending RestoreRamDisk (84828514 bytes)...
[warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity
[info] Extracting DeviceTree.n121bap.im4p...
[info] Personalizing IMG4 component RestoreDeviceTree...
[info] Sending RestoreDeviceTree (32394 bytes)...
[warn] No path for component RestoreSEP in TSS, will fetch from build_identity
[info] Extracting sep-firmware.n121b.RELEASE.im4p...
[info] Personalizing IMG4 component RestoreSEP...
[info] Sending RestoreSEP (2337346 bytes)...
[warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity
[info] Extracting kernelcache.release.watch3...
[info] Personalizing IMG4 component RestoreKernelCache...
[info] Sending RestoreKernelCache (14632856 bytes)...
[info] About to restore device...
[info] Waiting for device...
[info] Device is now connected in restore mode...
[info] Connecting now...
[info] Connected to com.apple.mobile.restored, version 15
[info] Device 84612453bf4914a222fe3fac052354cf9f08d42b has successfully entered restore mode
[info] Hardware Information:
[info] BoardID: 26
[info] ChipID: 32772
[info] UniqueChipID: 1737873563336870
[info] ProductionMode: true
[sett] Previous restore exit status: 0x100
[info] Starting FDR listener thread
[info] Connecting to FDR client at port 1082
[warn] About to do ctrl handshake
[done] Ctrl handshake done (ConnPort = 49159)
[warn] Requesting NOT TO Update Baseband
[info] Checkpoint 1621 complete with code 0
[info] Checkpoint 1540 complete with code 0
[info] Checkpoint 1679 complete with code 0
[info] About to send RootTicket...
[info] Sending RootTicket now...
[info] Done sending RootTicket
[info] Checkpoint 1547 complete with code 0
[info] Waiting for NAND (28)
[info] Checkpoint 1549 complete with code 0
[info] Checkpoint 1550 complete with code 0
[info] Checkpoint 1551 complete with code 0
[info] Checkpoint 1628 complete with code 0
[info] Checkpoint 1552 complete with code 0
[info] Checkpoint 1555 complete with code 0
[info] Checkpoint 1662 complete with code 0
[info] Sending NORData...
[info] Found firmware path Firmware/all_flash
[erro] zip_name_locate: Firmware/all_flash/manifest
[info] Getting firmware manifest from build identity
[info] Extracting LLB.n121b.RELEASE.im4p...
[info] Personalizing IMG4 component LLB...
[info] Extracting dali-ui.n121b.release.im4p...
[info] Personalizing IMG4 component Dali...
[info] Personalizing IMG4 component DeviceTree...
[info] Personalizing IMG4 component RecoveryMode...
[info] Extracting iBoot.n121b.RELEASE.im4p...
[info] Personalizing IMG4 component iBoot...
[info] Personalizing IMG4 component SEP...
[info] Sending NORData now...
[info] Done sending NORData
[info] Checkpoint 1545 complete with code 0
[info] Checkpoint 1683 complete with code 0
[info] Unmounting filesystems (29)
[info] Checkpoint 1637 complete with code 0
[info] Checkpoint 1556 complete with code 0
[info] Checkpoint 1686 complete with code 0
[info] Checkpoint 1699 complete with code 0
[info] Checkpoint 1695 complete with code 0
[info] Checkpoint 1620 complete with code 0
[info] Checkpoint 1687 complete with code 0
[info] Checkpoint 1557 complete with code 0
[info] About to send FDR Trust data...
[info] Sending FDR Trust data now...
[done] sending FDR Trust Data
[info] Checkpoint 1558 complete with code 0
[info] Checkpoint 1559 complete with code 0
[info] Checkpoint 1560 complete with code 0
[info] Checking for uncollected logs (44)
[info] Checkpoint 1561 complete with code 0
[info] Checkpoint 1562 complete with code 0
[info] Checkpoint 1563 complete with code 0
[info] Checkpoint 1633 complete with code 0
[info] Checkpoint 1565 complete with code 0
[info] Checkpoint 1614 complete with code 0
[info] Checkpoint 1567 complete with code 0
[info] Checkpoint 1674 complete with code 0
[info] Creating partition map (11)
[info] Checkpoint 1569 complete with code 0
[info] Checkpoint 1632 complete with code 0
[info] Checkpoint 1570 complete with code 0
[info] Checkpoint 1629 complete with code 0
[info] Checkpoint 5645 complete with code 0
[info] Creating filesystem (12)
[info] Checkpoint 1624 complete with code 0
[info] Checkpoint 1625 complete with code 0
[info] Checkpoint 1626 complete with code 0
[info] About to send filesystem...
[info] Connected to ASR
[info] Validating the filesystem
[info] Filesystem validated
[info] Sending filesystem now...
[done] sending filesystem
[info] Operation: Verifying restore (14)
[info] Checkpoint 1627 complete with code 0
[info] Checkpoint 1664 complete with code 0
[info] Checkpoint 1653 complete with code 0
[info] Checkpoint 1676 complete with code 0
[info] Checking filesystems (15)
[info] Mounting filesystems (16)
[info] Checkpoint 1574 complete with code 0
[info] Checkpoint 1634 complete with code 0
[info] Checkpoint 1655 complete with code 0
[info] Checkpoint 1658 complete with code 0
[info] Checkpoint 1575 complete with code 0
[info] Checkpoint 1690 complete with code 0
[info] Checkpoint 1691 complete with code 0
[info] Checkpoint 1618 complete with code 0
[info] Checkpoint 1588 complete with code 0
[info] Checkpoint 1661 complete with code 0
[info] Operation: Unknown operation (80)
[info] Sending IsiBootEANFirmware image list
[info] Sending IsiBootNonEssentialFirmware image list
[info] Flashing firmware (18)
[info] Checkpoint 4864 complete with code 0
[info] Sending IsEarlyAccessFirmware image list
[info] Checkpoint 4882 complete with code 0
[info] Operation: Requesting FUD data (36)
[info] Found IsFUDFirmware component ACIBT
[info] Found IsFUDFirmware component ACIWIFI
[info] Found IsFUDFirmware component AOP
[info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata
[info] Found IsFUDFirmware component Multitouch
[info] Found IsFUDFirmware component RTP
[info] Found IsFUDFirmware component RestoreTrustCache
[info] Found IsFUDFirmware component StaticTrustCache
[info] Found IsFUDFirmware component SystemVolume
[info] Sending IsFUDFirmware image list
[info] Extracting BT_FW.im4p...
[info] Personalizing IMG4 component ACIBT...
[info] Sending IsFUDFirmware for ACIBT...
[info] Extracting wifi_armv7r_m8p_rtkit_image.im4p...
[info] Personalizing IMG4 component ACIWIFI...
[info] Sending IsFUDFirmware for ACIWIFI...
[info] Extracting aopfw-m8paop.im4p...
[info] Personalizing IMG4 component AOP...
[info] Sending IsFUDFirmware for AOP...
[info] Extracting 078-33421-074.dmg.mtree...
[info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata...
[info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata...
[info] Extracting N121b_Multitouch.im4p...
[info] Personalizing IMG4 component Multitouch...
[info] Sending IsFUDFirmware for Multitouch...
[info] Extracting rtpfw.im4p...
[info] Personalizing IMG4 component RTP...
[info] Sending IsFUDFirmware for RTP...
[info] Sending IsFUDFirmware for RestoreTrustCache...
[info] Extracting 078-33421-074.dmg.trustcache...
[info] Personalizing IMG4 component StaticTrustCache...
[info] Sending IsFUDFirmware for StaticTrustCache...
[info] Extracting 078-33421-074.dmg.root_hash...
[info] Personalizing IMG4 component SystemVolume...
[info] Sending IsFUDFirmware for SystemVolume...
[info] Checkpoint 4874 complete with code 0
[info] Updating gas gauge software (47)
[info] Checkpoint 4865 complete with code 0
[info] Checkpoint 4866 complete with code 0
[info] Updating Stockholm (55)
[info] Checkpoint 4868 complete with code 0
[info] Checkpoint 4869 complete with code 0
[info] Checkpoint 4869 complete with code 18446744073709551615
[info] Checkpoint 1589 complete with code 18446744073709551615
[info] Checkpoint 1659 complete with code 18446744073709551615
[info] Checkpoint 1660 complete with code 0
[info] Checkpoint 5651 complete with code 0
[info] Checkpoint 1607 complete with code 0
[info] Status message: Verification Error
[sett] Log is available in ErrorLog.plist
[erro] Unable to successfully restore device
[info] Checkpoint 1608 complete with code 0
[erro] Unable to restore device
[done] Operation finished!
[info] device disconnect...
Old 03-04-2023, 16:52   #2 (permalink)
Member: 986038
Thanks Meter: 43
Restore via 3utool or itunse it supported to
Old 03-06-2023, 07:32   #3 (permalink)
Member: 605628
tried in itunes getting error -1
Old 03-08-2023, 10:13   #4 (permalink)
Member: 605628
[info] BoardID: 26
Any update on this please.
Old 03-10-2023, 04:32   #5 (permalink)
Member: 2277861
Thanks Meter: 153
interesting , seems you know that software can fix hardware issue
Old 03-10-2023, 05:02   #6 (permalink)
Member: 2277861
Thanks Meter: 153
The watch have core flex cable related issue, please do hardware check
The Following User Says Thank You to mfcsupport For This Useful Post:
Page generated in 0.25657 seconds with 8 queries
