11-05-2022, 08:26 | #1 (permalink) |
Junior Member Join Date: Oct 2007
Member: 605628 Status: Offline Thanks Meter: 0 | Watch S3 retore error file corrupt or server issue please check ProductType:Apple Watch S3 Starting ... Using LOCAL IPSW C:\Users\SHOPPETITE\Downloads\MFC_Watch3,4_19U67_8 .7.1_n121bAP_GPS_Restore_42mm.ipsw Loading version data from Apple Server Updated version data. Found device in DFU mode Gettting dfu mode device ... Identified device as Apple Watch S3, n121bap, Watch3,4 Extracting BuildManifest from ipsw File C:\Users\SHOPPETITE\Downloads\MFC_Watch3,4_19U67_8 .7.1_n121bAP_GPS_Restore_42mm.ipsw not recognized by server! File size: 2780952569 Please check if the file you downloaded is complete! Aborting operation! Firmware file might be corrupt. Unable to extract BuildManifest from C:\Users\SHOPPETITE\Downloads\MFC_Watch3,4_19U67_8 .7.1_n121bAP_GPS_Restore_42mm.ipsw. Failed Operation finished! Waiting for program to exit ... Br. |
11-05-2022, 12:56 | #3 (permalink) | |
Freak Poster Join Date: Oct 2008 Location: chenai,india
Member: 883886 Status: Offline Sonork: 1664059 Thanks Meter: 111 | Quote:
plz upload firmware MFC_Watch3,4_19U67_8.7.1_n121bAP_GPS_Restore_42mm. ipsw | |
11-08-2022, 18:35 | #8 (permalink) |
Junior Member Join Date: Aug 2017
Member: 2745694 Status: Offline Thanks Meter: 0 | Have a problem downloading 8.7.1 for any series 3, when try to download it google drive shows me this error Sorry, you can't view or download this file at this time. Too many users have viewed or downloaded this file recently. Please try accessing the file again later. If the file you are trying to access is particularly large or is shared with many people, it may take up to 24 hours to be able to view or download the file. If you still can't access a file after 24 hours, contact your domain administrator. |
11-08-2022, 22:45 | #10 (permalink) |
Insane Poster Join Date: Jan 2010 Location: Dominican Republic
Member: 1208406 Status: Offline Thanks Meter: 12 | [info] Using LOCAL IPSW C:\Users\carlo\Downloads\MFC_Watch3,3_19U67_8.7.1_ n121sAP_GPS_Restore_38mm.ipsw [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121sap, Watch3,3 [info] Extracting BuildManifest from ipsw [data] Product Version: 8.7.1 [data] Product Build: 19U67 Major: 19 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 001c73341ea10026 [info] Getting ApNonce in dfu mode... [data] 4842472790A88D389C3E1022522FAA96F334BC44E7D125FB7E 1519EB635C237D [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 976DC3992FE3D4830FDB48751D37B73226BF1CAC [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs Filesystem file not found! We will extract the filesystem to file iDeviceTools/MFC_Watch3,3_19U67_8.7.1_n121sAP_GPS_Restore_38mm/078-33080-074.dmg [info] Extracting filesystem [info] Found ECID 001c73341ea10026 [info] Getting ApNonce in dfu mode... [data] 4842472790A88D389C3E1022522FAA96F334BC44E7D125FB7E 1519EB635C237D [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 976DC3992FE3D4830FDB48751D37B73226BF1CAC [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n121s.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (773157 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 001c73341ea10026 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: 48 42 47 27 90 a8 8d 38 9c 3e 10 22 52 2f aa 96 f3 34 bc 44 e7 d1 25 fb 7e 15 19 eb 63 5c 23 7d [info] Extracting iBEC.n121s.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (773157 bytes)... [info] Device ecid 001c73341ea10026 disconnect detected! [info] device serial number is GJ9Z42Q3J5WY [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-7459.140.15 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (8785 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 078-33379-076.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15624 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 078-33379-076.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (84828514 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n121sap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (32388 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n121s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2337346 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (14632856 bytes)... [info] Device ecid 001c73341ea10026 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device f3d0032ee7d23395f5695d306d40c9869883db62 has successfully entered restore mode [info] Hardware Information: [info] BoardID: 24 [info] ChipID: 32772 [info] UniqueChipID: 8007967037259814 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49171) [warn] Requesting NOT TO Update Baseband [info] Checkpoint 1621 complete with code 0 [info] Checkpoint 1540 complete with code 0 [info] Checkpoint 1679 complete with code 0 [info] About to send RootTicket... [info] Sending RootTicket now... [info] Done sending RootTicket [info] Checkpoint 1547 complete with code 0 [info] Waiting for NAND (28) [info] Checkpoint 1549 complete with code 0 [info] Checkpoint 1550 complete with code 0 [info] Checkpoint 1551 complete with code 0 [info] Checkpoint 1628 complete with code 0 [info] Checkpoint 1552 complete with code 0 [info] Checkpoint 1555 complete with code 0 [info] Checkpoint 1662 complete with code 0 [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121s.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121s.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@115~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121s.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121s.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Checkpoint 1545 complete with code 0 [info] Checkpoint 1683 complete with code 0 [info] Unmounting filesystems (29) [info] Checkpoint 1637 complete with code 0 [info] Checkpoint 1556 complete with code 0 [info] Checkpoint 1686 complete with code 0 [info] Checkpoint 1699 complete with code 0 [info] Checkpoint 1695 complete with code 0 [info] Checkpoint 1620 complete with code 0 [info] Checkpoint 1687 complete with code 0 [info] Checkpoint 1557 complete with code 0 [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checkpoint 1558 complete with code 0 [info] Checkpoint 1559 complete with code 0 [info] Checkpoint 1560 complete with code 0 [info] Checking for uncollected logs (44) [info] Checkpoint 1561 complete with code 0 [info] Checking for uncollected logs (44) [info] Checkpoint 1562 complete with code 0 [info] Connecting to FDR client at port 49171 [info] Checkpoint 1563 complete with code 0 [info] Checkpoint 1633 complete with code 0 [info] Unmounting filesystems (29) [info] Checkpoint 1565 complete with code 0 [info] Checkpoint 1614 complete with code 0 [info] Checkpoint 1567 complete with code 0 [info] Checkpoint 1674 complete with code 0 [info] Creating partition map (11) [info] Checkpoint 1569 complete with code 0 [info] Checkpoint 1632 complete with code 0 [info] Checkpoint 1570 complete with code 0 [info] Checkpoint 1629 complete with code 0 [info] Checkpoint 5645 complete with code 0 [info] Creating filesystem (12) [info] Checkpoint 1624 complete with code 0 [info] Checkpoint 1625 complete with code 0 [info] Checkpoint 1626 complete with code 0 [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Checkpoint 1627 complete with code 0 [info] Checkpoint 1664 complete with code 0 [info] Checkpoint 1653 complete with code 0 [info] Checkpoint 1676 complete with code 0 [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Checkpoint 1574 complete with code 0 [info] Checkpoint 1634 complete with code 0 [info] Checkpoint 1655 complete with code 0 [info] Checkpoint 1658 complete with code 0 [info] Checkpoint 1575 complete with code 0 [info] Checkpoint 1690 complete with code 0 [info] Checkpoint 1691 complete with code 0 [info] Checkpoint 1618 complete with code 0 [info] Checkpoint 1588 complete with code 0 [info] Checkpoint 1661 complete with code 0 [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Checkpoint 4864 complete with code 0 [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Checkpoint 4882 complete with code 0 [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Found IsFUDFirmware component SystemVolume [info] Sending IsFUDFirmware image list [info] Extracting BT_FW.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m8p_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting aopfw-m8paop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting 078-33080-074.dmg.mtree... [info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata... [info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata... [info] Extracting N121s_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 078-33379-076.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 078-33080-074.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Extracting 078-33080-074.dmg.root_hash... [info] Personalizing IMG4 component SystemVolume... [info] Sending IsFUDFirmware for SystemVolume... [info] Checkpoint 4874 complete with code 0 [info] Updating gas gauge software (47) [info] Checkpoint 4865 complete with code 0 [info] Updating gas gauge software (47) [info] Checkpoint 4866 complete with code 0 [info] Updating Stockholm (55) [info] Checkpoint 4868 complete with code 0 [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Found IsFUDFirmware component SystemVolume [info] Sending IsFUDFirmware image list [info] Extracting 078-33080-074.dmg.mtree... [info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata... [info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata... [info] Extracting 078-33379-076.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 078-33080-074.dmg.root_hash... [info] Personalizing IMG4 component SystemVolume... [info] Sending IsFUDFirmware for SystemVolume... [info] Checkpoint 4869 complete with code 0 [info] Checkpoint 4870 complete with code 0 [info] Checkpoint 4871 complete with code 0 [info] Checkpoint 4872 complete with code 0 [info] Checkpoint 4878 complete with code 0 [info] Checkpoint 4879 complete with code 0 [info] Checkpoint 4875 complete with code 0 [info] Checkpoint 4867 complete with code 0 [info] Checkpoint 4880 complete with code 0 [info] Updating SE Firmware (59) [info] Extracting Stockholm4.RELEASE.sefw... [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received SE ticket [info] Sending FirmwareResponse data now... [info] Done sending FirmwareUpdater data [info] Checkpoint 4873 complete with code 0 [info] Unknown operation (79) [info] Checkpoint 4886 complete with code 0 [info] Checkpoint 1589 complete with code 0 [info] Checkpoint 1596 complete with code 0 [info] Checkpoint 5379 complete with code 0 [info] Checkpoint 4889 complete with code 0 [info] Checkpoint 4890 complete with code 0 [info] Requesting EAN Data (74) [info] Checkpoint 5380 complete with code 0 [info] Checkpoint 4884 complete with code 0 [info] Checkpoint 1640 complete with code 0 [info] Checkpoint 1597 complete with code 0 [info] Checkpoint 1647 complete with code 0 [info] Creating Protected Volume (67) [info] Checkpoint 1652 complete with code 0 [info] Checkpoint 1631 complete with code 0 [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [info] Done sending KernelCache[info] Installing kernelcache (27) [info] Checkpoint 3584 complete with code 0 [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n121sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [info] Done sending DeviceTree[info] Installing DeviceTree (61) [info] Checkpoint 3585 complete with code 0 [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121s.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121s.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@115~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121s.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121s.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Checkpoint 3588 complete with code 0 [info] Checkpoint 3589 complete with code 0 [info] Checkpoint 3587 complete with code 0 [info] Checkpoint 1576 complete with code 0 [info] Fixing up /var (17) [info] Creating system key bag (50) [info] Checkpoint 3840 complete with code 0 [info] Checkpoint 3841 complete with code 0 [info] Checkpoint 3844 complete with code 0 [info] Connecting to FDR client at port 49171 [info] Checkpoint 3849 complete with code 0 [info] Checkpoint 1613 complete with code 0 [info] Checkpoint 1694 complete with code 0 [info] Checkpoint 1595 complete with code 0 [info] Modifying persistent boot-args (25) [info] Checkpoint 1593 complete with code 0 [info] Checkpoint 1630 complete with code 0 [info] Checkpoint 1672 complete with code 0 [info] Checkpoint 1659 complete with code 0 [info] Checkpoint 5632 complete with code 0 [info] Checkpoint 1599 complete with code 0 [info] Checkpoint 1600 complete with code 0 [info] Checkpoint 1675 complete with code 0 [info] Checkpoint 1641 complete with code 0 [info] Unmounting filesystems (29) [info] Checkpoint 1602 complete with code 0 [info] Checkpoint 1660 complete with code 0 [info] Checkpoint 5651 complete with code 0 [info] Checkpoint 1607 complete with code 0 [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! [info] device disconnect... [info] device arrival... found |
11-09-2022, 15:11 | #13 (permalink) |
Junior Member Join Date: Nov 2021 Location: espaņa Age: 43
Member: 3001029 Status: Offline Thanks Meter: 0 | Hola , yo intento restaurar un apple watch serie 3 gps lte , pero se me queda al 99,9% no finaliza y al final se me ha puesto el signo de exclamacion en rojo , que puedoo hacer para recuperar , tengo ibus y ultimo firmware disponible en web , el apple watch esta en version 8.3 y sin enlazar |
11-10-2022, 02:53 | #14 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | As i check this post calitox already done , and looks everything fine Other user may need check your permission in your dashboard on mfcbox.com , i.e. mfc /imf c/ ibus related activates |
