Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iBUS Tools For Apple Watch
Old 11-27-2021, 14:25   #1 (permalink)
Member: 2998969
Thanks Meter: 5
Watch serie 5 gps 44 successful restore
I do it without any problem
The Following User Says Thank You to reza666h For This Useful Post:
Old 11-27-2021, 14:27   #2 (permalink)
Member: 2998969
Thanks Meter: 5
[info] Using LOCAL IPSW C:\MFC\MFC_Watch5,2_8.1_19R570_n144bap_GPS_Restore _44mm.ipsw
[info] using cached version data
[info] Found device in Recovery mode
[info] Gettting dfu mode device ...
[info] Identified device as Apple Watch S5, n144bap, Watch5,2
[info] Extracting BuildManifest from ipsw
[data] Product Version: 8.1
[data] Product Build: 19R570 Major: 19
[info] device serial number is G99ZPSWZMLTQ
[data] Device supports Image4: true
[info] Variant: Customer Erase Install (IPSW)
[info] This restore will erase your device data.
[info] Checking IPSW for required components...
[info] All required components found in IPSW
[info] Found ECID 0016650a2e47002e
[info] Getting ApNonce in recovery mode... [data] DEF770936E30AE46932EF2F3391B3489A18F4D4B4A9C5060FA FA8624F27096FC
[info] tts>Trying to fetch new SHSH blob
[info] Getting SepNonce in recovery mode... [data] 1A7355BADA7390433D78039FC6160FDEE05DBF43
[note] Unable to find BbChipID node
[note] Unable to find BbProvisioningManifestKeyHash node
[note] Unable to find BbActivationManifestKeyHash node
[note] Unable to find BbCalibrationManifestKeyHash node
[note] Unable to find BbFactoryActivationManifestKeyHash node
[note] Unable to find BbFDRSecurityKeyHash node
[note] Unable to find BbSkeyId node
[info] Request URL set to https://gs.apple.com/TSS/controller?action=2
[info] Sending TSS request attempt 1...
[info] response successfully received
[info] tts>Received SHSH blobs
[info] Using cached filesystem from 'iDeviceTools/MFC_Watch5,2_8.1_19R570_n144bap_GPS_Restore_44mm/018-59294-083.dmg'
[warn] No path for component iBEC in TSS, will fetch from build_identity
[info] Extracting iBEC.n144b.RELEASE.im4p...
[info] Personalizing IMG4 component iBEC...
[info] Sending iBEC (1119396 bytes)...
[info] Device ecid 0016650a2e47002e disconnect detected!
[info] Recovery Mode Environment:
[info] iBoot build-version=iBoot-7429.40.94
[info] iBoot build-style=RELEASE
[info] Sending AppleLogo...
[warn] No path for component AppleLogo in TSS, will fetch from build_identity
[info] Extracting applelogo@448~watch.im4p...
[info] Personalizing IMG4 component AppleLogo...
[info] Sending AppleLogo (10947 bytes)...
[warn] No path for component ACIBT in TSS, will fetch from build_identity
[info] Extracting BT_FW_m9.im4p...
[info] Personalizing IMG4 component ACIBT...
[info] Sending ACIBT (1845621 bytes)...
[warn] No path for component ACIWIFI in TSS, will fetch from build_identity
[info] Extracting wifi_armv7r_m9_rtkit_image.im4p...
[info] Personalizing IMG4 component ACIWIFI...
[info] Sending ACIWIFI (1905197 bytes)...
[warn] No path for component ANE in TSS, will fetch from build_identity
[info] Extracting h11_ane_fw_mercury.im4p...
[info] Personalizing IMG4 component ANE...
[info] Sending ANE (1731589 bytes)...
[warn] No path for component AOP in TSS, will fetch from build_identity
[info] Extracting aopfw-watch5aop.im4p...
[info] Personalizing IMG4 component AOP...
[info] Sending AOP (2006165 bytes)...
[warn] No path for component GFX in TSS, will fetch from build_identity
[info] Extracting armfw_g11m.im4p...
[info] Personalizing IMG4 component GFX...
[info] Sending GFX (881085 bytes)...
[warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity
[info] Extracting 018-59313-088.dmg.trustcache...
[info] Personalizing IMG4 component RestoreTrustCache...
[info] Sending RestoreTrustCache (16710 bytes)...
[warn] No path for component SCE in TSS, will fetch from build_identity
[info] Extracting scefw.im4p...
[info] Personalizing IMG4 component SCE...
[info] Sending SCE (20345 bytes)...
[warn] No path for component SIO in TSS, will fetch from build_identity
[info] Extracting SmartIOFirmware_ASCv2.im4p...
[info] Personalizing IMG4 component SIO...
[info] Sending SIO (1176673 bytes)...
[warn] No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity
[info] Extracting WirelessPower.watch4.im4p...
[info] Personalizing IMG4 component WCHFirmwareUpdater...
[info] Sending WCHFirmwareUpdater (31828 bytes)...
[warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity
[info] Extracting 018-59313-088.dmg...
[info] Personalizing IMG4 component RestoreRamDisk...
[info] Sending RestoreRamDisk (88321176 bytes)...
[warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity
[info] Extracting DeviceTree.n144bap.im4p...
[info] Personalizing IMG4 component RestoreDeviceTree...
[info] Sending RestoreDeviceTree (42870 bytes)...
[warn] No path for component RestoreSEP in TSS, will fetch from build_identity
[info] Extracting sep-firmware.n144b.RELEASE.im4p...
[info] Personalizing IMG4 component RestoreSEP...
[info] Sending RestoreSEP (5463422 bytes)...
[warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity
[info] Extracting kernelcache.release.watch5...
[info] Personalizing IMG4 component RestoreKernelCache...
[info] Sending RestoreKernelCache (13155867 bytes)...
[info] Waiting for device to reconnect in Restore mode...
[info] About to restore device...
[info] Waiting for device...
[info] Device is now connected in restore mode...
[info] Connecting now...
[info] Connected to com.apple.mobile.restored, version 15
[info] Device 00008006-0016650A2E47002E has successfully entered restore mode
[info] Hardware Information:
[info] BoardID: 18
[info] ChipID: 32774
[info] UniqueChipID: 6303543888117806
[info] ProductionMode: true
[info] Starting FDR listener thread
[info] Connecting to FDR client at port 1082
[warn] About to do ctrl handshake
[done] Ctrl handshake done (ConnPort = 49157)
[warn] Requesting NOT TO Update Baseband
[info] Checkpoint 1621 complete with code 0
[info] Checkpoint 1540 complete with code 0
[info] Checkpoint 1679 complete with code 0
[info] About to send RootTicket...
[info] Sending RootTicket now...
[info] Done sending RootTicket
[info] Checkpoint 1547 complete with code 0
[info] Waiting for NAND (28)
[info] Checkpoint 1549 complete with code 0
[info] Updating NAND Firmware (58)
[info] Checkpoint 1550 complete with code 0
[info] Checkpoint 1551 complete with code 0
[info] Checkpoint 1628 complete with code 0
[info] Checkpoint 1552 complete with code 0
[info] Checkpoint 1555 complete with code 0
[info] Checkpoint 1662 complete with code 0
[info] Sending NORData...
[info] Found firmware path Firmware/all_flash
[erro] zip_name_locate: Firmware/all_flash/manifest
[info] Getting firmware manifest from build identity
[info] Extracting LLB.n144b.RELEASE.im4p...
[info] Personalizing IMG4 component LLB...
[info] Extracting dali-ui.n144b.release.im4p...
[info] Personalizing IMG4 component Dali...
[info] Personalizing IMG4 component DeviceTree...
[info] Extracting recoverymode@448~watch.im4p...
[info] Personalizing IMG4 component RecoveryMode...
[info] Extracting iBoot.n144b.RELEASE.im4p...
[info] Personalizing IMG4 component iBoot...
[info] Personalizing IMG4 component SEP...
[info] Sending NORData now...
[info] Done sending NORData
[info] Checkpoint 1545 complete with code 0
[info] Checkpoint 1683 complete with code 0
[info] Unmounting filesystems (29)
[info] Checkpoint 1637 complete with code 0
[info] Checkpoint 1556 complete with code 0
[info] Checkpoint 1686 complete with code 0
[info] Checkpoint 1697 complete with code 0
[info] Checkpoint 1695 complete with code 0
[info] Checkpoint 1620 complete with code 0
[info] Checkpoint 1687 complete with code 0
[info] Checkpoint 1557 complete with code 0
[info] About to send FDR Trust data...
[info] Sending FDR Trust data now...
[done] sending FDR Trust Data
[info] Checkpoint 1558 complete with code 0
[info] Checkpoint 1559 complete with code 0
[info] Checkpoint 1560 complete with code 0
[info] Checking for uncollected logs (44)
[info] Checkpoint 1561 complete with code 0
[info] Checkpoint 1562 complete with code 0
[info] Connecting to FDR client at port 49157
[info] Checkpoint 1563 complete with code 0
[info] Checkpoint 1633 complete with code 0
[info] Checkpoint 1565 complete with code 0
[info] Checkpoint 1614 complete with code 0
[info] Checkpoint 1567 complete with code 0
[info] Checkpoint 1674 complete with code 0
[info] Creating partition map (11)
[info] Checkpoint 1569 complete with code 0
[info] Checkpoint 1632 complete with code 0
[info] Checkpoint 1570 complete with code 0
[info] Checkpoint 1629 complete with code 0
[info] Checkpoint 5645 complete with code 0
[info] Creating filesystem (12)
[info] Checkpoint 1624 complete with code 0
[info] Checkpoint 1625 complete with code 0
[info] Checkpoint 1626 complete with code 0
[info] About to send filesystem...
[info] Connected to ASR
[info] Validating the filesystem
[info] Filesystem validated
[info] Sending filesystem now...
[done] sending filesystem
[info] Operation: Verifying restore (14)
[info] Checkpoint 1627 complete with code 0
[info] Checkpoint 1664 complete with code 0
[info] Checkpoint 1653 complete with code 0
[info] Checkpoint 1676 complete with code 0
[info] Checking filesystems (15)
[info] Mounting filesystems (16)
[info] Checkpoint 1574 complete with code 0
[info] Checkpoint 1634 complete with code 0
[info] Checkpoint 1655 complete with code 0
[info] Checkpoint 1658 complete with code 0
[info] Checkpoint 1575 complete with code 0
[info] Checkpoint 1690 complete with code 0
[info] Checkpoint 1691 complete with code 0
[info] Checkpoint 1618 complete with code 0
[info] Checkpoint 1588 complete with code 0
[info] Checkpoint 1661 complete with code 0
[info] Operation: Updating AppleTCON (81)
[info] Sending IsiBootEANFirmware image list
[info] Sending IsiBootNonEssentialFirmware image list
[info] Flashing firmware (18)
[info] Checkpoint 4864 complete with code 0
[info] Sending IsEarlyAccessFirmware image list
[info] Checkpoint 4882 complete with code 0
[info] Operation: Requesting FUD data (36)
[info] Found IsFUDFirmware component ACIBT
[info] Found IsFUDFirmware component ACIWIFI
[info] Found IsFUDFirmware component ANE
[info] Found IsFUDFirmware component AOP
[info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata
[info] Found IsFUDFirmware component GFX
[info] Found IsFUDFirmware component LeapHaptics
[info] Found IsFUDFirmware component Multitouch
[info] Found IsFUDFirmware component RTP
[info] Found IsFUDFirmware component RestoreTrustCache
[info] Found IsFUDFirmware component SCE
[info] Found IsFUDFirmware component SIO
[info] Found IsFUDFirmware component StaticTrustCache
[info] Found IsFUDFirmware component SystemVolume
[info] Sending IsFUDFirmware image list
[info] Sending IsFUDFirmware for ACIBT...
[info] Sending IsFUDFirmware for ACIWIFI...
[info] Sending IsFUDFirmware for ANE...
[info] Sending IsFUDFirmware for AOP...
[info] Extracting 018-59294-083.dmg.mtree...
[info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata...
[info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata...
[info] Sending IsFUDFirmware for GFX...
[info] Extracting N144B_LeapHapticsFirmware.im4p...
[info] Personalizing IMG4 component LeapHaptics...
[info] Sending IsFUDFirmware for LeapHaptics...
[info] Extracting N144b_Multitouch.im4p...
[info] Personalizing IMG4 component Multitouch...
[info] Sending IsFUDFirmware for Multitouch...
[info] Extracting rtpfw.im4p...
[info] Personalizing IMG4 component RTP...
[info] Sending IsFUDFirmware for RTP...
[info] Sending IsFUDFirmware for RestoreTrustCache...
[info] Sending IsFUDFirmware for SCE...
[info] Sending IsFUDFirmware for SIO...
[info] Extracting 018-59294-083.dmg.trustcache...
[info] Personalizing IMG4 component StaticTrustCache...
[info] Sending IsFUDFirmware for StaticTrustCache...
[info] Extracting 018-59294-083.dmg.root_hash...
[info] Personalizing IMG4 component SystemVolume...
[info] Sending IsFUDFirmware for SystemVolume...
[info] Checkpoint 4874 complete with code 0
[info] Updating gas gauge software (47)
[info] Checkpoint 4865 complete with code 0
[info] Checkpoint 4866 complete with code 0
[info] Updating Stockholm (55)
[info] Checkpoint 4868 complete with code 0
[info] Checkpoint 4869 complete with code 0
[info] Checkpoint 4870 complete with code 0
[info] Checkpoint 4871 complete with code 0
[info] Checkpoint 4872 complete with code 0
[info] Checkpoint 4878 complete with code 0
[info] Checkpoint 4879 complete with code 0
[info] Checkpoint 4875 complete with code 0
[info] Checkpoint 4867 complete with code 0
[info] Checkpoint 4880 complete with code 0
[info] Updating SE Firmware (59)
[info] Extracting Stockholm5.RELEASE.sefw...
[info] Sending SE TSS request...
[info] Received SE ticket
[info] Sending FirmwareResponse data now...
[info] Done sending FirmwareUpdater data
[info] Checkpoint 4873 complete with code 0
[info] Unknown operation (80)
[info] Checkpoint 4886 complete with code 0
[info] Checkpoint 1589 complete with code 0
[info] Checkpoint 1596 complete with code 0
[info] Checkpoint 5379 complete with code 0
[info] Unknown operation (75)
[info] Checkpoint 5380 complete with code 0
[info] Checkpoint 4884 complete with code 0
[info] Checkpoint 1640 complete with code 0
[info] Checkpoint 1597 complete with code 0
[info] Checkpoint 1647 complete with code 0
[info] Resizing Main Filesystem Partition (68)
[info] Checkpoint 1652 complete with code 0
[info] Checkpoint 1631 complete with code 0
[info] About to send KernelCache...
[warn] No path for component KernelCache in TSS, will fetch from build identity
[info] Personalizing IMG4 component KernelCache...
[info] Sending KernelCache ...
[info] Done sending KernelCache[info] Installing kernelcache (27)
[info] Checkpoint 3584 complete with code 0
[info] About to send DeviceTree...
[warn] No path for component DeviceTree in TSS, will fetch from build identity
[info] Sending DeviceTree ...
[info] Done sending DeviceTree[info] Installing DeviceTree (61)
[info] Checkpoint 3585 complete with code 0
[info] Checkpoint 3588 complete with code 0
[info] Checkpoint 3589 complete with code 0
[info] Checkpoint 3587 complete with code 0
[info] Checkpoint 1576 complete with code 0
[info] Fixing up /var (17)
[info] Creating system key bag (50)
[info] Checkpoint 3840 complete with code 0
[info] Checkpoint 3841 complete with code 0
[info] Checkpoint 3844 complete with code 0
[info] Checkpoint 3849 complete with code 0
[info] Checkpoint 1613 complete with code 0
[info] Checkpoint 1694 complete with code 0
[info] Checkpoint 1595 complete with code 0
[info] Modifying persistent boot-args (25)
[info] Checkpoint 1593 complete with code 0
[info] Checkpoint 1630 complete with code 0
[info] Checkpoint 1672 complete with code 0
[info] Checkpoint 1659 complete with code 0
[info] Checkpoint 5632 complete with code 0
[info] Checkpoint 1599 complete with code 0
[info] Checkpoint 1600 complete with code 0
[info] Checkpoint 1675 complete with code 0
[info] Checkpoint 1641 complete with code 0
[info] Checkpoint 1602 complete with code 0
[info] Checkpoint 1660 complete with code 0
[info] Checkpoint 5651 complete with code 0
[info] Checkpoint 1607 complete with code 0
[info] Status message: Restore Finished
[info] Cleaning up...
[done] Done
[done] Operation finished!
The Following 2 Users Say Thank You to reza666h For This Useful Post:
Page generated in 0.17851 seconds with 8 queries
