Watch series 0 restore error please check hi i am having error in restoring watch series 0 please help [info] Using LOCAL IPSW C:\Users\shopp\Downloads\MFC_Watch1,2_4.3.2_15U70_ n28aap_Restore_42mm.ipsw [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S0 - 1st generation, n28aap, Watch1,2 [info] Extracting BuildManifest from ipsw [data] Product Version: 4.3.2 [data] Product Build: 15U70 Major: 15 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 000002942d1e8ff4 [info] Getting ApNonce in dfu mode... [data] CEC7B14FEF5251A55DE940BE6845706B170AA1F7 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [erro] Unable to find required ApSepNonce in parameters [erro] tts>Unable to add img4 tags to TSS request [erro] Unable to get SHSH blobs for this device [done] Operation finished! [info] Using LOCAL IPSW C:\Users\shopp\Downloads\MFC_Watch1,2_4.3.2_15U70_ n28aap_Restore_42mm.ipsw [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S0 - 1st generation, n28aap, Watch1,2 [info] Extracting BuildManifest from ipsw [data] Product Version: 4.3.2 [data] Product Build: 15U70 Major: 15 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 000002942d1e8ff4 [info] Getting ApNonce in dfu mode... [data] CEC7B14FEF5251A55DE940BE6845706B170AA1F7 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [erro] Unable to find required ApSepNonce in parameters [erro] tts>Unable to add img4 tags to TSS request [erro] Unable to get SHSH blobs for this device [done] Operation finished! |
i also faceing same error please support us mfs? |
MFC Software version must >= V 3.9.0.2 |
can you please share the link of 3.9.0.2 as on website i can only see 3.9.0 br |
Support section have V4.x also working , give a try plz |
