Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iBUS Tools For Apple Watch
Old 10-26-2023, 15:38   #1 (permalink)
Member: 1144374
Thanks Meter: 64
Why this error?
[info] Using local file C:\MFC_Watch3,3_19U512_8.8.1_n121sAP_GPS_Restore_3 8mm.ipsw
[erro] We don't know firmware locations for device OS type!
[info] Found device in DFU mode
[info] Gettting dfu mode device ...
[warn] Phone model not found, please send email to [email protected], Thank you!
[info] Extracting BuildManifest from ipsw
[data] Product Version: 8.8.1
[data] Product Build: 19U512 Major: 19
[data] Device supports Image4: true
[info] Variant: Customer Erase Install (IPSW)
[info] Checking for required components...
[info] Using ECID 00060c8834380026
[info] Getting ApNonce in dfu mode... [data] 86F7BB90B7966697CB2E8A4996BC3053E252D3DC1DC948855D D290C5245C3892
[info] tts>Trying to fetch new SHSH blob
[info] Getting SepNonce in dfu mode... [data] 5B3F6F1318CF8897EDDECA18B381B1BE6ED24C47
[note] Unable to find BbChipID node
[note] Unable to find BbProvisioningManifestKeyHash node
[note] Unable to find BbActivationManifestKeyHash node
[note] Unable to find BbCalibrationManifestKeyHash node
[note] Unable to find BbFactoryActivationManifestKeyHash node
[note] Unable to find BbFDRSecurityKeyHash node
[note] Unable to find BbSkeyId node
[info] Request URL set to https://gs.apple.com/TSS/controller?action=2
[info] Sending TSS request attempt 1...
[info] response successfully received
[info] tts>Received SHSH blobs
[warn] Unable to find component node for Cryptex1,SystemOS
[info] Using cached file 'iDeviceTools\MFC_Watch3,3_19U512_8.8.1_n121sAP_GP S_Restore_38mm\078-70107-014.dmg'
[info] Found ECID 00060c8834380026
[info] Personalizing IMG4 component iBSS...
[info] Sending iBSS (773157 bytes)...
[info] Removed (Apple, Inc.,USB\VID_05AC&PID_1227\CPID:8004_CPRV:10_CPFM: 03_SCEP:01_BDID:18_ECID:00060C8834380026_IBFL:3C_S RTG:[IBOOT-2651.0.0.3.3])
[warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable!
[info] Device ecid 00060c8834380026 disconnect detected!
[info] Waiting for device arrival (timeout 20.000000 seconds)
[info] Arrival (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV: 10_CPFM:03_SCEP:01_BDID:18_ECID:00060C8834380026_I BFL:3C_SRNM:[FHLX52FDJ5X1])
[info] Found device in Recovery mode
[info] cpid:0x8004, bdid:0x0018
[info] Noce: 86 f7 bb 90 b7 96 66 97 cb 2e 8a 49 96 bc 30 53 e2 52 d3 dc 1d c9 48 85 5d d2 90 c5 24 5c 38 92
[info] Personalizing IMG4 component iBEC...
[info] Sending iBEC (773157 bytes)...
[info] Removed (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV: 10_CPFM:03_SCEP:01_BDID:18_ECID:00060C8834380026_I BFL:3C_SRNM:[FHLX52FDJ5X1])
[info] device serial number is FHLX52FDJ5X1
[info] Recovery Mode Environment:
[info] iBoot build-version=iBoot-7459.140.15
[info] iBoot build-style=RELEASE
[info] Sending AppleLogo...
[warn] No path for component AppleLogo in TSS, will fetch from build_identity
[info] Personalizing IMG4 component AppleLogo...
[info] Sending AppleLogo (8785 bytes)...
[warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity
[info] Personalizing IMG4 component RestoreTrustCache...
[info] Sending RestoreTrustCache (15624 bytes)...
[warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity
[info] Personalizing IMG4 component RestoreRamDisk...
[info] Sending RestoreRamDisk (84828514 bytes)...
[warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity
[info] Personalizing IMG4 component RestoreDeviceTree...
[info] Sending RestoreDeviceTree (32388 bytes)...
[warn] No path for component RestoreSEP in TSS, will fetch from build_identity
[info] Personalizing IMG4 component RestoreSEP...
[info] Sending RestoreSEP (2337346 bytes)...
[warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity
[info] Personalizing IMG4 component RestoreKernelCache...
[info] Sending RestoreKernelCache (14633818 bytes)...
[info] About to restore device...
[info] Waiting for device...
[info] Device is now connected in restore mode...
[info] Connecting now...
[info] Connected to com.apple.mobile.restored, version 15
[info] Device 97346ab63f7be756e078cc86c3f6691ffb56bd36 has successfully entered restore mode
[info] Hardware Information:
[info] BoardID: 24
[info] ChipID: 32772
[info] UniqueChipID: 1702628991434790
[info] ProductionMode: true
[sett] Previous restore exit status: 0x100
[info] Starting FDR listener thread
[info] Connecting to FDR client at port 1082
[warn] About to do ctrl handshake
[done] Ctrl handshake done (ConnPort = 49158)
[warn] Requesting NOT TO Update Baseband
[info] Checkpoint 1621 complete with code 0
[info] Checkpoint 1540 complete with code 0
[info] Checkpoint 1679 complete with code 0
[info] About to send RootTicket...
[info] Sending RootTicket now...
[done] sending RootTicket
[info] Checkpoint 1547 complete with code 0
[info] Waiting for NAND (28)
[info] Checkpoint 1549 complete with code 0
[info] Checkpoint 1550 complete with code 0
[info] Checkpoint 1551 complete with code 0
[info] Checkpoint 1628 complete with code 0
[info] Checkpoint 1552 complete with code 0
[info] Checkpoint 1555 complete with code 0
[info] Checkpoint 1662 complete with code 0
[info] Sending NORData...
[info] Found firmware path Firmware/all_flash
[info] Getting firmware manifest from build identity
[info] Personalizing IMG4 component LLB...
[info] Personalizing IMG4 component Dali...
[info] Personalizing IMG4 component DeviceTree...
[info] Personalizing IMG4 component RecoveryMode...
[info] Personalizing IMG4 component iBoot...
[info] Personalizing IMG4 component SEP...
[info] Sending NORData now...
[done] Done sending NORData
[info] Checkpoint 1545 complete with code 0
[info] Checkpoint 1683 complete with code 0
[info] Unmounting filesystems (29)
[info] Checkpoint 1637 complete with code 0
[info] Checkpoint 1556 complete with code 0
[info] Checkpoint 1686 complete with code 0
[info] Checkpoint 1699 complete with code 0
[info] Checkpoint 1695 complete with code 0
[info] Checkpoint 1620 complete with code 0
[info] Checkpoint 1687 complete with code 0
[info] Checkpoint 1557 complete with code 0
[info] About to send FDR Trust data...
[info] Sending FDR Trust data now...
[done] sending FDR Trust Data
[info] Checkpoint 1558 complete with code 0
[info] Checkpoint 1559 complete with code 0
[info] Checkpoint 1560 complete with code 0
[info] Checking for uncollected logs (44)
[info] Checkpoint 1561 complete with code 0
[info] Checkpoint 1562 complete with code 0
[info] Checkpoint 1563 complete with code 0
[info] Checkpoint 1633 complete with code 0
[info] Checkpoint 1565 complete with code 0
[info] Checkpoint 1614 complete with code 0
[info] Checkpoint 1567 complete with code 0
[info] Checkpoint 1674 complete with code 0
[info] Creating partition map (11)
[info] Checkpoint 1569 complete with code 0
[info] Checkpoint 1632 complete with code 0
[info] Checkpoint 1570 complete with code 0
[info] Checkpoint 1629 complete with code 0
[info] Checkpoint 5645 complete with code 0
[info] Creating filesystem (12)
[info] Checkpoint 1624 complete with code 0
[info] Checkpoint 1625 complete with code 0
[info] Checkpoint 1626 complete with code 0
[info] About to send filesystem...
[info] Connected to ASR
[info] Validating the filesystem
[info] Filesystem validated
[info] Sending filesystem now...
[done] sending filesystem
[info] Operation: Verifying restore (14)
[info] Checkpoint 1627 complete with code 0
[info] Checkpoint 1664 complete with code 0
[info] Checkpoint 1653 complete with code 0
[info] Checkpoint 1676 complete with code 0
[info] Checking filesystems (15)
[info] Mounting filesystems (16)
[info] Checkpoint 1574 complete with code 0
[info] Checkpoint 1634 complete with code 0
[info] Checkpoint 1655 complete with code 0
[info] Checkpoint 1658 complete with code 0
[info] Checkpoint 1575 complete with code 0
[info] Checkpoint 1690 complete with code 0
[info] Checkpoint 1691 complete with code 0
[info] Checkpoint 1618 complete with code 0
[info] Connecting to FDR client at port 49158
[info] FDR 0DB192F0 Proxy connect request to gg.apple.com:443
[info] FDR 0DBA14A0 Proxy connect request to skl.apple.com:443
[info] FDR 0DB5C198 Proxy connect request to skl.apple.com:443
[info] FDR 0B777A00 Proxy connect request to skl.apple.com:443
[info] FDR 0DB9E718 Proxy connect request to skl.apple.com:443
[info] Checkpoint 1588 complete with code 0
[info] Checkpoint 1661 complete with code 0
[info] Operation: Unknown operation (80)
[info] Sending IsiBootEANFirmware image list
[info] Sending IsiBootNonEssentialFirmware image list
[info] Flashing firmware (18)
[info] Checkpoint 4864 complete with code 0
[info] Sending IsEarlyAccessFirmware image list
[info] Checkpoint 4882 complete with code 0
[info] Operation: Requesting FUD data (36)
[info] Found IsFUDFirmware component ACIBT
[info] Found IsFUDFirmware component ACIWIFI
[info] Found IsFUDFirmware component AOP
[info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata
[info] Found IsFUDFirmware component Multitouch
[info] Found IsFUDFirmware component RTP
[info] Found IsFUDFirmware component RestoreTrustCache
[info] Found IsFUDFirmware component StaticTrustCache
[info] Found IsFUDFirmware component SystemVolume
[info] Sending IsFUDFirmware image list
[info] Personalizing IMG4 component ACIBT...
[info] Sending IsFUDFirmware for ACIBT...
[info] Personalizing IMG4 component ACIWIFI...
[info] Sending IsFUDFirmware for ACIWIFI...
[info] Personalizing IMG4 component AOP...
[info] Sending IsFUDFirmware for AOP...
[info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata...
[info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata...
[info] Personalizing IMG4 component Multitouch...
[info] Sending IsFUDFirmware for Multitouch...
[info] Personalizing IMG4 component RTP...
[info] Sending IsFUDFirmware for RTP...
[info] Sending IsFUDFirmware for RestoreTrustCache...
[info] Personalizing IMG4 component StaticTrustCache...
[info] Sending IsFUDFirmware for StaticTrustCache...
[info] Personalizing IMG4 component SystemVolume...
[info] Sending IsFUDFirmware for SystemVolume...
[info] Checkpoint 4874 complete with code 0
[info] Updating gas gauge software (47)
[info] Checkpoint 4865 complete with code 0
[info] Checkpoint 4866 complete with code 0
[info] Updating Stockholm (55)
[info] Checkpoint 4868 complete with code 0
[info] Checkpoint 4869 complete with code 0
[info] Checkpoint 4869 complete with code 18446744073709551615
[info] Checkpoint 1589 complete with code 18446744073709551615
[info] Checkpoint 1659 complete with code 18446744073709551615
[info] Checkpoint 1660 complete with code 0
[info] Checkpoint 5651 complete with code 0
[info] Checkpoint 1607 complete with code 0
[info] Status message: Verification Error
[sett] Log is available in ErrorLog.plist
[erro] Unable to successfully restore device
[info] Checkpoint 1608 complete with code 0
[erro] Unable to restore device
[done] Operation finished!
[info] Removed (Apple, Inc.,USB\VID_05AC&PID_12AF\97346AB63F7BE756E078CC8 6C3F6691FFB56BD36)
[info] Arrival (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV: 10_CPFM:03_SCEP:01_BDID:18_ECID:00060C8834380026_I BFL:3D_SRNM:[FHLX52FDJ5X1])
Old 10-28-2023, 14:37   #2 (permalink)
Member: 2277861
Thanks Meter: 210
About Core flex cable related part have issue , check hardware then
Page generated in 0.15429 seconds with 8 queries
