08-17-2017, 17:01 | #1 (permalink) |
Product Manager Join Date: Apr 2009 Location: BD,BH,CN
Member: 1004001 Status: Offline Sonork: WhatsApp+971506319003 Thanks Meter: 448 | Macbook EFI/Firmware & iCloud Remove Service via SN&HASH MACBOOK,iMac EFI/FIRMWARE & ICLOUD REMOVE SERVICE VIA SN&HASH Boot with Option key held to display the boot menu firmware password prompt. Press Control-Option-Command-Shift-S to reveal a 33-digit hash (mixed letters and numbers) that contains an identifier for your specific motherboard and the Atmel chip used for your system. In this hash, the first 17 digits are an identifier for the system's motherboard, and the last 16 digits are a hash for the password. Submit HASH and SN to order page. Note; Strictly Check HASH and SN twice, Because we can not refund wrong Summited orders. After you receive file you must follow next steps: Format a flash drive GUID partition scheme and Mac OS Extended format. Name it Firmware Download SCBO file to your Desktop. Open Terminal Paste the following command into the terminal window and press enter: cp ~/Desktop/SCBO-signed.bin /Volumes/Firmware/.SCBO You should get a new line, no errors. Paste the following command into the terminal window and press enter: cp ~/Desktop/SCBO-signed.bin /Volumes/Firmware/._SCBO You should get a new line, no errors. Eject the flash drive. Turn off the computer. Insert the flash drive. Turn on the computer and immediately hold down the Option key. You should see the lock symbol for a second and then it will restart to the Startup Manager. If you see a PIN lock after these steps, reset the NVRAM with Command-Option-P-R. The EFI password is now removed. After EFI is removed use your own bootable OS X and install it. First installation don't do over WiFi, no refund in case re-lock (re-lock could happen in some cases). Contact Us: UnlockCodeSide™ (The Professional Unlocker) Skype : Yousufcrack WhatsApp/Viber /Telegram: ++971506319003 Office Address: 5/86 Eastern Plaza,Sonargaon Road,Dhaka, Bangladesh Last edited by UNLOCK PARK ®; 02-06-2023 at 20:05. |
The Following 3 Users Say Thank You to UNLOCK PARK ® For This Useful Post: |
