Again Huawei Mate 10 lite RNE-L21 Reset FRP problem help [Answered] same model same problem same error read info Platform: HUAWEI Selected model: RNE-L21 Put the phone in FastBoot Mode: 1. Remove SD and SIM cards from the phone 2. Power phone OFF 3. Press and hold "Vol-" and insert USB cable 4. Wait until the phone enter in FastBoot Mode Searching for a phone. Please wait... Detected phone model: RNE-L21 Phone SN: FFY5T18411018260 Phone IMEI: 869676033300929 Phone IMEI2: 869676033336931 SW version: RNE-L21 8.0.0.332(C185) Performed by 1.4.0.0 Software version. fastboot mode error Platform: HUAWEI Selected model: RNE-L21 Put the phone in FastBoot Mode: 1. Remove SD and SIM cards from the phone 2. Power phone OFF 3. Press and hold "Vol-" and insert USB cable 4. Wait until the phone enter in FastBoot Mode Searching for a phone. Please wait... Detected phone model: RNE-L21 Phone SN: FFY5T18411018260 Phone IMEI: 869676033300929 Phone IMEI2: 869676033336931 SW version: RNE-L21 8.0.0.332(C185) Connecting to server..OK Authorizing...OK Resetting FRP lock.. Operation was failed! Performed by 1.4.0.0 Software version. by selecting EML-L22 adb error Platform: HUAWEI Selected model: EML-L22 Please, press "OK" button on the phone to allow USB debugging.. Please, reboot the phone (don't disconnect cable), then perform Reset FRP ADB operation again! Performed by 1.4.0.0 Software version help needed for this model :mad::mad: |
Hello. Please, send us latest logx file. We will research where can be the problem and inform You about possible solution |
https://www.4shared.com/archive/oOkr...17-48-09.html? |
8.0 oreo are not support frp reset from octuplus only 7.1.1. tested.8.0 tested via manually bypass reset. search google 8.0 reset bypass.. |
Hello. Please try to perform Hard reset operation, then repeat Reset FRP operation again. |
tried bypass it with all methode on youtube but not done :mad: |
What is the exact state of your device? We have tested Reset FRP operation on this device and everything works correctly. |
set is working it is asking for email address |
Have you Octopus Huawei tool activated ? If yes try to unlock bootloader |
