Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus FRP Tool
Old 07-08-2021, 18:55   #1 (permalink)
Member: 589544
Thanks Meter: 15
Smile frp xiaomi mi mix 3 Could not write loader [Solved]
hi please help on removing frp lock for xiaomi mi mix 3 with the error Could not write loader
log file
Log file "C:\Program Files (x86)\Octoplus\Octoplus_FRP_Tool\LOG\07-07-2021_22-31-37.log" created (07/07/2021 22:31:37).
INFO : 07/07/2021 22:32:18 > Welcome to Octoplus FRP Tool v.2.0.3.0
INFO : 07/07/2021 22:38:18 > Work ID: 00000000013BD991
INFO : 07/07/2021 22:38:18 > Platform: XIAOMI
INFO : 07/07/2021 22:38:18 > Selected model: MI MIX 3
WARN : 07/07/2021 22:38:18 > Put the phone into EDL mode:
WARN : 07/07/2021 22:38:18 > 1. Attach testpoint as shown in Help manual;
WARN : 07/07/2021 22:38:18 > 2. Connect USB cable;
WARN : 07/07/2021 22:38:18 > 3. Release testpoint after 3-5 seconds.
INFO : 07/07/2021 22:38:18 > Found phone on COM4
INFO : 07/07/2021 22:38:18 > Mode: Qualcomm 9008
INFO : 07/07/2021 22:38:18 > Connecting...
INFO : 07/07/2021 22:38:20 > Reading info...
INFO : 07/07/2021 22:38:20 > QC HW ID: 0008B0E100720000
INFO : 07/07/2021 22:38:20 > QC CPU: Snapdragon 845 SDM845
INFO : 07/07/2021 22:38:21 > QC SW VER: 00000002
INFO : 07/07/2021 22:38:21 > Searching loader...
INFO : 07/07/2021 22:38:22 > Sending loaders...
ERROR : 07/07/2021 22:38:24 > Could not write loader!
INFO : 07/07/2021 22:38:24 > Performed by 2.0.3.0 Software version.
Old 07-09-2021, 08:17   #2 (permalink)
Member: 2891705
Thanks Meter: 1,266
Hello.
Select: "Device Vendor: General reset FRP methods", "Device Model: Qualcomm EDL Autodetect".
Then perform Read Info operation and post here results. We will check it.
Old 07-09-2021, 12:29   #3 (permalink)
Member: 589544
Thanks Meter: 15
same problem and same log
Old 07-09-2021, 13:04   #4 (permalink)
Member: 2891705
Thanks Meter: 1,266
We need more information about your device.
Please, post here log.
Old 07-09-2021, 18:32   #5 (permalink)
Member: 589544
Thanks Meter: 15
this is the log
INFO : 07/07/2021 23:08:31 > Platform: __GENERAL RESET FRP METHODS
INFO : 07/07/2021 23:08:31 > Selected model: QUALCOMM EDL AUTODETECT
INFO : 07/07/2021 23:08:31 > Selected port: COM4
INFO : 07/07/2021 23:08:31 > Selected port: Qualcomm HS-USB QDLoader 9008 (COM4)
INFO : 07/07/2021 23:08:31 > Mode: Qualcomm 9008
INFO : 07/07/2021 23:08:31 > Connecting...
INFO : 07/07/2021 23:08:33 > Reading info...
INFO : 07/07/2021 23:08:33 > QC Block ID: F189C4A8
INFO : 07/07/2021 23:08:33 > QC HW ID: 0008B0E100720000
INFO : 07/07/2021 23:08:33 > QC CPU: Snapdragon 845 SDM845
INFO : 07/07/2021 23:08:34 > QC HASH: 30A365E3C049DA61E20A9C23C209FAEDC8FEF6FFE4FD5B695C D7EE7390E238D9
INFO : 07/07/2021 23:08:34 > QC SW VER: 00000002
INFO : 07/07/2021 23:08:34 > Searching loader...
INFO : 07/07/2021 23:08:35 > Sending loaders...
ERROR : 07/07/2021 23:08:37 > Could not write loader!
ERROR : 07/07/2021 23:08:37 > Operation was failed!
INFO : 07/07/2021 23:08:37 > Performed by 2.0.3.0 Software version.
Old 07-10-2021, 08:30   #6 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 26,369
Hello.
We will check where can be the problem and inform you on Monday.
The Following User Says Thank You to Octopus box For This Useful Post:
Old 07-12-2021, 12:54   #7 (permalink)
Member: 2891705
Thanks Meter: 1,266
Hello.
Download this Loader.
Then select: General reset FRP methods -> Qualcomm EDL Custom and try to connect your device with this loader. After done - post here results. We will check it.
Old 07-12-2021, 21:23   #8 (permalink)
Member: 589544
Thanks Meter: 15
Work ID: 00000000014170FB
Selected model: QUALCOMM EDL CUSTOM
Please, power phone OFF put the phone in EDL mode and connect USB cable.
Found phone on COM4
Mode: Qualcomm 9008
Connecting...
Reading info...
QC SW VER: 00000002
Searching loader...
Selected QCOM loader: C:\Users\Asus\Downloads\prog_ufs_firehose_sdm845_d dr.elf
Sending loaders...
Loader send successfuly.
Reconnecting...
Chip SN: F189C4A8
Checking request..
Authentification is not available for this phone model!
Old 07-13-2021, 12:53   #9 (permalink)
Member: 2891705
Thanks Meter: 1,266
Hello.
Please, download and install this Octoplus FRP Tool Software latest test version 2.0.3.1 and repeat operation one more time. After done - post here results.
Old 07-13-2021, 14:55   #10 (permalink)
Member: 589544
Thanks Meter: 15
the link is not working
Old 07-13-2021, 15:07   #11 (permalink)
Member: 2891705
Thanks Meter: 1,266
Try to download one more time.
Old 07-13-2021, 18:14   #12 (permalink)
Member: 589544
Thanks Meter: 15
not working again, see attachment
Old 07-14-2021, 07:12   #13 (permalink)
Member: 2891705
Thanks Meter: 1,266
We added Octoplus FRP Tool Software v. 2.0.3.1 to Support Area
Please, download and install latest test Software version from Support Area (Path: /Soft/Octoplus FRP Tool/TEST SOFTWARE/install_octoplus_FRP_2.0.3.1.exe)
Then repeat operation one more time and post here results. We will check it.
To enter Support Area, press "Go to support" button on "Support & options" tab of the Software.
Old 07-14-2021, 12:25   #14 (permalink)
Member: 589544
Thanks Meter: 15
Welcome to Octoplus FRP Tool v.2.0.3.1
Work ID: 000000000143500B
Found phone on COM4
Mode: Qualcomm 9008
Connecting...
Reading info...
QC SW VER: 00000002
Searching loader...
Sending loaders...
Reconnecting...
Chip SN: F189C4A8
Checking request..
Performed by 2.0.3.1 Software version.
Old 07-14-2021, 13:08   #15 (permalink)
Member: 2891705
Thanks Meter: 1,266
Hello.
Please, selected model: MI MIX 3 and repeat Read Info operation.
Then post here results.
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.17541 seconds with 8 queries
