03-17-2021, 08:47 | #1 (permalink) |
Junior Member Join Date: May 2009 Location: Miramar, Florida USA
Member: 1027157 Status: Offline Thanks Meter: 4 | Hisense u963 frp remove fail [Solved] Welcome to Octoplus FRP Tool v.1.9.9.2 Card S/N: 00086E84 Work ID: 0000000000BF8594 Platform: HISENSE Selected model: U963 Please, power phone OFF, press and hold "Vol-" button and connect USB cable. Searching for a phone. Please wait... Found phone on COM65 Connecting... Mobile Status: SPRD3 Sending preloader... Operation was failed! Performed by 1.9.9.2 Software version. I tried downgrading to version 1.9.5 but I get card version error. Please need or a fix/solution thank you |
The Following User Says Thank You to noelb2 For This Useful Post: |
03-17-2021, 17:25 | #3 (permalink) |
Member: 1027157 Status: Offline Thanks Meter: 4 | Hi I did that several times and I also follow the instructions by holding Vol- then connect usb. it finds diagnostics port then fail. I tried up to 6 handset and I get the same error. HELP HELP HELP PLEASE!!!! |
03-17-2021, 20:31 | #4 (permalink) | |
No Life Poster Join Date: Feb 2018 Location: Nigeria
Member: 2812901 Status: Offline Thanks Meter: 493 | Quote:
https://forum.gsmhosting.com/vbb/f10...wered-2953914/ | |
The Following User Says Thank You to Oyetunde Semiu For This Useful Post: |
03-17-2021, 20:33 | #5 (permalink) |
Member: 2812901 Status: Offline Thanks Meter: 493 | Download and install 1.9.7 from above link and repeat operation and post results |
03-18-2021, 10:36 | #6 (permalink) |
Member: 1027157 Status: Offline Thanks Meter: 4 | Hi thanks for your help but I get the same error as before. these are ATT U963 do you think the bootloaders are locked? Work ID: 0000000000C0F92E Platform: HISENSE Selected model: U963 Selected port: COM2 Please, power phone OFF, press and hold "Vol-" button and connect USB cable. Searching for a phone. Please wait... Found phone on COM2 Connecting... Mobile Status: SPRD3 Sending preloader... Operation was failed! Performed by 1.9.7.0 Software version. |
03-18-2021, 18:33 | #7 (permalink) | |
Member: 1027157 Status: Offline Thanks Meter: 4 | Quote:
Hi thanks a million for your help. I downgrade to the v1.9.7 and i chose the model above mine which U962 and tick the "manual select" box, click the Reset FRP and it work. the combination of the file and the older model thanks again!! Work ID: 0000000000C1A2FA Platform: HISENSE Selected model: U962 Selected port: COM62 Please, power phone OFF, press and hold "Vol-" button and connect USB cable. Searching for a phone. Please wait... Found phone on COM62 Connecting... Mobile Status: SPRD3 Sending preloader... Mobile Status: Spreadtrum Boot Block version 1.1 Sending mainloader... Reading info... Brand: Hisense Model: Hisense U963 Device: HS7331CSC Platform: sc8830 Android version: 6.0 Display ID: MRA58K release-keys Searching for signatures... Resetting FRP lock.. FRP lock is successfully reseted! Performed by 1.9.7.0 Software version. | |
The Following 3 Users Say Thank You to noelb2 For This Useful Post: |
