01-26-2021, 09:33 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: PAKISTAN
Member: 1537135 Status: Offline Thanks Meter: 1,021 | J320F FRP lock is successfully reseted Code: Welcome to Octoplus FRP Tool v.1.9.8.0 Card S/N: 00000E47 Disable screen lock function(s) are added in test mode for OPPO F3 (CPH1609), please be careful when performing it! Work ID: 00000000007B3F25 Platform: SAMSUNG Selected model: SM-J320F Reset FRP/ Reactivation lock operation for SM-J320F will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J320F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Advanced mode! Firmware write started. Writing Custom section... Custom section has been written successfully. Firmware writing successfully completed. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 1.9.8.0 Software version. |
The Following User Says Thank You to naveedullah0044 For This Useful Post: |
