01-22-2019, 19:25 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: PL Age: 44
Member: 477842 Status: Offline Thanks Meter: 80 | LG H870 G6 FRP reset, Brick ? [Solved] Here is log Welcome to Octoplus FRP Tool v.1.5.9.0 Platform: LG Selected model: H870 Put the phone into EDL mode: 1. Attach testpoint as shown in Help manual; 2. Connect USB cable; 3. Release testpoint after 3-5 seconds. Searching for a phone. Please wait... Found phone on COM34 Reading info... Detected phone model: LG-H870 Mode: Emergency Initializing.. SW version: LGH870AT-00-V20h-260-06-NOV-26-2018+0 Android version: 8.0.0 Platform: msm8996 Reading partition... Reading BOOT... ID: 0005F0E100310000 Operation is not safe and exist risk to damage the device! Do You want to continue? Backup saved as LG_H870_22-01-2019_19-05-34.dump file Rebooting to Qualcomm 9008 mode... Searching for a phone. Please wait... "Qualcomm HS-USB QDLoader 9008" device not found. Please, don't disconnect cable, this can damage your device! Install "Qualcomm USB Driver" then press "Ok" button. After that phone goes to QUSB_BULK mode in Windows 10 Device Mannager and I tick CANCEL operation Operation was canceled Performed by 1.5.9.0 Software version. How to repair this piece of LG ? |
01-23-2019, 07:42 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. What is exact state of your phone, what device appear in Windows Device Manager, when You connect the phone to PC? |
01-24-2019, 08:28 | #5 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | @at-kom Please install Qualcomm USB Driver, then repeat the Reset FRP operation again, post here results. Quote:
01-24-2019, 13:23 | #7 (permalink) | |
Member: 477842 Status: Offline Thanks Meter: 80 | Quote:
I connect LG H870 to PC and automatic install drivers, Then Phone is installed: Qualcomm HS-USB QDLoader 9008 (COM37) on Windows Mannager. When I try to RESET FRP (Qualcomm 9008) with Octoplus FRP Tool I have : Platform: LG Selected model: H870 Put the phone into EDL mode: 1. Attach testpoint as shown in Help manual; 2. Connect USB cable; 3. Release testpoint after 3-5 seconds. Searching for a phone. Please wait... Connecting... Backup saved as LG_H870_24-01-2019_13-23-06.dump file Operation was failed! Performed by 1.5.9.0 Software version. | |
01-25-2019, 08:57 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | @at-kom Please contact us to Skype, we will check where can be the problem. Our contacts You can find in our profile. |
01-28-2019, 17:31 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please, try to do the next: 1. To reboot the phone, press and hold Vol- , Vol + and Power butto for about 10 sec. 2. Connect phone to PC, after repeat Reset FRP via 9008 mode again. 3. Then restore your device from the backup "LG_H870_22-01-2019_19-05-34.dump" 4. Post here full Software log. |
The Following 3 Users Say Thank You to Octopus box For This Useful Post: |
02-01-2019, 08:22 | #12 (permalink) |
Member: 477842 Status: Offline Thanks Meter: 80 | So It was my mistake, why ? To repair your phone U need backup (first time readed from phone in Octoplus FRP program) and. 1. In phone do the reset procedure : (Vol - ,Vol+ , Power Button , together, tick 15sec) then put USB TYPE C , cable to phone and connect it to Windows. Windows recognized : Qualcomm HS-USB QDloader 9008 (if not , you must uninstall driver from Windows, and install correct drivers QualcommUSBDriver.zip) 2.In FRP Octoplus Program , tick for backup file and use the first (largest) file. 3.Chose correct COM PORT in Octoplus FRP program tab 4.USE RESET FRP (QUALCOMM 9008) and do the reset procedure. here is my log : Welcome to Octoplus FRP Tool v.1.6.1.0 Platform: LG Selected model: H870 Opening "LG_H870_22-01-2019_19-05-34.dump"... Restore device from backup file? Put the phone into EDL mode: 1. Attach testpoint as shown in Help manual; 2. Connect USB cable; 3. Release testpoint after 3-5 seconds. Searching for a phone. Please wait... Connecting... Reading info... QC HW ID: 0005F0E100310000 QC CPU: Snapdragon 821 MSM8996AC Pro Searching loader... Sending loaders... Loader send successfuly. Reconnecting... Checking request.. Checking request.. Reading partition... Reading info... Brand: lge Model: LG-H870 Device: lucye Platform: msm8996 Android version: 8.0.0 Display ID: OPR1.170623.032 Restoring BOOT... Rebooting phone Backup saved as LG_H870_01-02-2019_08-01-24.dump file FRP lock is successfully reseted! Performed by 1.6.1.0 Software version. And now phone reset and work fine without google account . Thank to the best Octoplus TEAM Best regards TelfonGSM |
The Following 2 Users Say Thank You to at-kom For This Useful Post: |
04-11-2019, 17:14 | #13 (permalink) |
No Life Poster Join Date: May 2014
Member: 2188956 Status: Offline Thanks Meter: 29 | where are you loading the dump file for restore? I selected my dump file in the select software, then i select dump file, then i hit write firmware and get error. Platform: LG Selected model: H871 Put the phone into Download Mode: 1. Power phone OFF; 2. Press and hold "Vol+" button and connect USB cable. Searching for a phone. Please wait... No diagnostic ports found! Performed by 1.6.9.0 Software version. |
04-12-2019, 07:57 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Did You follow the procedure correctly? 1. To reboot the phone, press and hold Vol- , Vol + and Power butto for about 10 sec. 2. Connect phone to PC, after repeat Reset FRP via 9008 mode again. 3. Then restore your device from the backup "LG_H870_22-01-2019_19-05-34.dump" 4. Post here full Software log. |
12-21-2020, 18:09 | #15 (permalink) |
Freak Poster Join Date: Aug 2014 Location: Nigeria Lagos
Member: 2243791 Status: Offline Thanks Meter: 9 | please help ..after octopus remove frp . phone dead Work ID: 00000000004B9F11 Platform: LG Selected model: US997 Put the phone into EDL mode: 1. Attach testpoint as shown in Help manual; 2. Connect USB cable; 3. Release testpoint after 3-5 seconds. Searching for a phone. Please wait... Connecting... Reading info... QC HW ID: 0005F0E100310000 QC CPU: Snapdragon 821 MSM8996AC Pro QC SW VER: 00000000 Searching loader... Sending loaders... Loader send successfuly. Reconnecting... Chip SN: 476C5206 Checking request.. Checking request.. Reading partition... Reading info... Brand: lge Model: LGUS997 Device: lucye Platform: msm8996 Android version: 8.0.0 Display ID: OPR1.170623.032 Firmware version: 190420940e75c Resetting FRP lock.. Searching for signatures... Rebooting phone Backup saved as lge_LGUS997_21-12-2020_08-55-58.dump file FRP lock is successfully reseted! Performed by 1.9.8.0 Software version. |
