06-03-2020, 20:28 | #1 (permalink) |
Freak Poster Join Date: Mar 2019
Member: 2898079 Status: Offline Thanks Meter: 6 | octoplus credits deducted but didnt remove FRP [Answered] INFO : 3/6/2020 13:07:55 > Platform: LG INFO : 3/6/2020 13:07:55 > Selected model: M400F WARN : 3/6/2020 13:07:55 > Put the phone into Download Mode: WARN : 3/6/2020 13:07:55 > 1. Power phone OFF; WARN : 3/6/2020 13:07:55 > 2. Press and hold "Vol+" button and connect USB cable. INFO : 3/6/2020 13:07:55 > Searching for a phone. Please wait... INFO : 3/6/2020 13:07:57 > Found phone on COM20 INFO : 3/6/2020 13:07:57 > Reading info... INFO : 3/6/2020 13:07:58 > Detected phone model: LG-M400F INFO : 3/6/2020 13:07:58 > Mode: Emergency INFO : 3/6/2020 13:07:58 > Initializing.. INFO : 3/6/2020 13:07:59 > Performed by 1.8.7.0 Software version. INFO : 3/6/2020 13:07:59 > INFO : 3/6/2020 13:08:49 > Platform: LG INFO : 3/6/2020 13:08:49 > Selected model: M400F WARN : 3/6/2020 13:08:49 > Put the phone into Download Mode: WARN : 3/6/2020 13:08:49 > 1. Power phone OFF; WARN : 3/6/2020 13:08:49 > 2. Press and hold "Vol+" button and connect USB cable. INFO : 3/6/2020 13:08:49 > Searching for a phone. Please wait... INFO : 3/6/2020 13:08:54 > Found phone on COM20 INFO : 3/6/2020 13:08:54 > Reading info... INFO : 3/6/2020 13:08:54 > Detected phone model: LG-M400F INFO : 3/6/2020 13:08:54 > Mode: Emergency INFO : 3/6/2020 13:08:54 > Initializing.. INFO : 3/6/2020 13:08:57 > SW version: LGM400FAT-01-V10a-704-01-FEB-26-2019+7 INFO : 3/6/2020 13:08:57 > Android version: 7.0 INFO : 3/6/2020 13:08:57 > Platform: mt6750 WARN : 3/6/2020 13:08:57 > Reset FRP operation for M400F will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? INFO : 3/6/2020 13:09:01 > Reading partition... INFO : 3/6/2020 13:09:01 > Detecting writing method... INFO : 3/6/2020 13:09:01 > Trying to repeat.. INFO : 3/6/2020 13:09:07 > Trying third method... INFO : 3/6/2020 13:09:08 > Trying third method... INFO : 3/6/2020 13:09:08 > Searching for signatures... INFO : 3/6/2020 13:09:08 > Connecting to server... INFO : 3/6/2020 13:09:08 > Checking smart card... INFO : 3/6/2020 13:09:11 > Username: M6xKg9g INFO : 3/6/2020 13:09:11 > Authorizing... INFO : 3/6/2020 13:09:12 > Checking balance... WARN : 3/6/2020 13:09:12 > Your balance: 150 credits. INFO : 3/6/2020 13:09:12 > Checking operation... INFO : 3/6/2020 13:09:13 > Operation successfully checked. INFO : 3/6/2020 13:09:13 > Sending device information... INFO : 3/6/2020 13:09:14 > Get credits, needed for current operation... WARN : 3/6/2020 13:09:14 > Your balance: 150 credits. Need: 100 credits. INFO : 3/6/2020 13:09:16 > Backup saved as LG_M400F_03-06-2020_13-09-16.dump file INFO : 3/6/2020 13:09:16 > Removing write protection... INFO : 3/6/2020 13:10:07 > Reconnecting... WARN : 3/6/2020 13:10:07 > Please, perform the following steps: 1. Disconnect cable. 2. Reconnect battery. 3. Put phone into Download mode manually. 4. Connect the cable then press "Ok" button. INFO : 3/6/2020 13:10:54 > Found phone on COM20 INFO : 3/6/2020 13:10:54 > Initializing.. INFO : 3/6/2020 13:10:57 > Reading partition... INFO : 3/6/2020 13:10:57 > Resetting FRP lock.. INFO : 3/6/2020 13:10:57 > Restore write protection... INFO : 3/6/2020 13:11:52 > Reconnecting... WARN : 3/6/2020 13:11:52 > Please, perform the following steps: 1. Disconnect cable. 2. Reconnect battery. 3. Put phone into Download mode manually. 4. Connect the cable then press "Ok" button. INFO : 3/6/2020 13:12:16 > Found phone on COM20 INFO : 3/6/2020 13:12:16 > Initializing.. INFO : 3/6/2020 13:12:18 > Reading partition... INFO : 3/6/2020 13:12:18 > Restore write protection... INFO : 3/6/2020 13:13:13 > Reconnecting... WARN : 3/6/2020 13:13:14 > Please, perform the following steps: 1. Disconnect cable. 2. Reconnect battery. 3. Put phone into Download mode manually. 4. Connect the cable then press "Ok" button. INFO : 3/6/2020 13:14:42 > Found phone on COM20 INFO : 3/6/2020 13:14:42 > Initializing.. INFO : 3/6/2020 13:14:44 > Reading partition... INFO : 3/6/2020 13:14:45 > Restore write protection... INFO : 3/6/2020 13:15:40 > Reconnecting... WARN : 3/6/2020 13:15:41 > Please, perform the following steps: 1. Disconnect cable. 2. Reconnect battery. 3. Put phone into Download mode manually. 4. Connect the cable then press "Ok" button. Last edited by Adrian9; 06-03-2020 at 20:35. |
06-04-2020, 07:55 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
How about to accept update from Software!? You're using outdated Software version, repeat operation with the latest Software version Last edited by Octopus box; 06-12-2020 at 08:03. | |
06-12-2020, 10:25 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | We've already added credits back to your account |
