07-20-2018, 14:30 | #20 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | @ juned5501 Try to do the next: 1. Power off the device, press and hold "Vol+" and "Vol-" and check in Windows device manager, whether "Qualcomm...9008" port has been appeared. 2. Select "Qualcomm EDL Autodetect", try to read device info and post here log. Also try to do the next: 1. Power off the device, connect to PC and check, whether "Diagnostic Mode" has been appeared in Windows Device Manager in ports section. 2. Select "Qualcomm EDL Autodetect", try to read device info and post here log. |
07-21-2018, 15:53 | #22 (permalink) | |
Freak Poster Join Date: Nov 2011 Location: rwp
Member: 1686412 Status: Offline Sonork: 100.1664625 Thanks Meter: 212 | kindly add mi max mi account permanent remove Quote:
07-21-2018, 18:56 | #23 (permalink) | |
Freak Poster Join Date: Jun 2012 Location: united kingdom
Member: 1777637 Status: Offline Sonork: 100.1616860:md Thanks Meter: 45 | Quote:
once i try both option i can hear its decetect but its not showing 9008 or diagnostic but i try both method but no luck, any other option? thanks | |
07-22-2018, 11:08 | #24 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Try also to use EDL cable. Unfortunately, at the moment we don't have Test Point for this device. Maybe someone has and will upload here Test Point picture for You. |
07-22-2018, 14:51 | #25 (permalink) |
Major Poster Join Date: Jun 2011 Location: Algeria
Member: 1596130 Status: Offline Thanks Meter: 2 | why j120H not supported Welcome to Octoplus FRP Tool v.1.3.5.0 Platform: SAMSUNG Selected model: SM-J120H To put SM-J120H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..not supported Resetting EE lock..not supported Resetting Samsung Account lock..not supported Operation was failed! Performed by 1.3.5.0 Software version. |
07-22-2018, 15:18 | #26 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Quote:
You should do the following: 1. Write regular (common) Samsung firmware. 2. Write only modem (CP) part from the Combination firmware. 3. Perform "Reset FRP" via ADB operation again. 4. Write regular firmware again back into the device. | |
07-23-2018, 15:19 | #30 (permalink) |
Insane Poster Join Date: Dec 2008
Member: 918299 Status: Offline Sonork: kader Thanks Meter: 19 | p8 pro condor Card found : S/N : C7169D0D , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 48 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:25 Reconnect Power/Cable! |
