02-10-2021, 14:27 | #32 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Gambia
Member: 1440837 Status: Offline Sonork: 3535 Thanks Meter: 47 | Work ID: 0000000000903A42 Platform: OPPO Selected model: A91 (CPH2021) Please, power phone OFF, press and hold "Vol+" and "Vol-" buttons and connect USB cable. Searching for a phone. Please wait... Found phone on COM49 Port name: MediaTek USB Port_V1632 (COM49) Detecting Chip Version... HW Chip: MT6771: 0788.0000 HW Version: 8A00.CA00.0000.0000 Connecting... Target Config: 00E5 Brom Version: 05 BootLoader Version: FE Disabling protection... Phone was not found! Installing driver... Please, disconnect the phone, then try to perform operation again! Operation was failed! Performed by 1.9.9.0 Software version. |
02-10-2021, 15:07 | #33 (permalink) |
Insane Poster Join Date: Jun 2013 Age: 40
Member: 1958785 Status: Offline Sonork: yyyy Thanks Meter: 4 | preloader, auth aun dowmload agent hi team thank for your work. where i can find the this files? preloader, auth and dowmload agent? I suppose that each processor needs its file, but are they easily accessible? |
02-10-2021, 15:25 | #35 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,434 | Hello. Anyone who encountered the problem of running the latest software version 1.9.9, please install the latest test version from Support Area (FRP/TEST SOFTWARE/) or install this driver and check if the problem is solved. Sorry for the inconvenience. |
The Following 5 Users Say Thank You to Octopus box For This Useful Post: |
02-10-2021, 16:02 | #36 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,346 | Very Good update from @Octopus Developers, i've installed Last Version w/o "Libusb-Win32" and haven't any issue, tested in Win7 32 Bit how photo below: Team Please do also for "Redmi7" isn't Supported FRP becouse say how below: Anyway Very thanks for Oppo w/o Auth and the other Models BR Allumts |
02-10-2021, 16:03 | #37 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,434 | Quote:
Please download and install latest test software version 1.9.9.1 from the Support Area (FRP/TEST SOFTWARE/). Then repeat operation once again. Quote:
02-10-2021, 16:53 | #38 (permalink) |
Freak Poster Join Date: Jul 2009 Location: In The World
Member: 1068286 Status: Offline Thanks Meter: 182 | Operation not done with REDMI 6 !!! Welcome to Octoplus FRP Tool v.1.9.9.0 Card S/N: 1000000000 Work ID: 00000000009074D4 Platform: XIAOMI Selected model: REDMI 6 Please, select one of the options for "Reset Mi Account" operation or press Ok to continue... Go to "Wi-Fi Settings" and forget connected Wi-Fi network or perform Wipe Data from recovery Please, power phone OFF, press and hold "Vol+" button and connect USB cable. Searching for a phone. Please wait... Found phone on COM7 Port name: MTK USB Port (COM7) Detecting Chip Version... HW Chip: MT6765: 0766.0000 HW Version: 8A00.CA00.0000.0000 Connecting... Target Config: 00E7 Brom Version: 05 BootLoader Version: FE Disabling protection... Phone was not found! Installing driver... Please, disconnect the phone, then try to perform operation again! Operation was failed! Performed by 1.9.9.0 Software version. |
02-10-2021, 17:05 | #39 (permalink) | |
Member: 1068286 Status: Offline Thanks Meter: 182 | Xiaomi Redmi 6 Resetting Mi Account Done Quote:
Job Done Big Thanks Welcome to Octoplus FRP Tool v.1.9.9.1 Card S/N: 100000000 Work ID: 000000000090783A Platform: XIAOMI Selected model: REDMI 6 Please, select one of the options for "Reset Mi Account" operation or press Ok to continue... Go to "Wi-Fi Settings" and forget connected Wi-Fi network or perform Wipe Data from recovery Please, power phone OFF, press and hold "Vol+" button and connect USB cable. Searching for a phone. Please wait... Found phone on COM7 Port name: MTK USB Port (COM7) Detecting Chip Version... HW Chip: MT6765: 0766.0000 HW Version: 8A00.CA00.0000.0000 Connecting... Target Config: 00E7 Brom Version: 05 BootLoader Version: FE Disabling protection... Reconnecting... Detecting Chip Version... HW Chip: MT6765: 0766.0000 HW Version: 8A00.CA00.0000.0000 Target Config: 00E0 Searching Download Agent... Selected DA: MTK_AllInOne_DA_v3.3001.2018/04/19.10:40_426269, n.0 Sending Download Agent... DA sent successfully Initializing DA... Synchronizing with DA... Mobile Status: SYNC Mobile Status: brom Sending BootLoader Info... Initializing Memory Flash.. Initialization successfully completed Sending loaders... Mobile Status: SYNC Reading Flash Info... EMMC rpmb size: 4 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 29820 Mb eMMC Flash: .15010047.4436424D.4201A1F6.075B652B eMMC Flash: Samsung: GD6BMB Internal RAM size: 256 Kb External RAM size: 768 Mb Reading partition... Reading info... Brand: xiaomi Manufacturer: Xiaomi Model: Redmi 6 Device: cereus Android version: 8.1.0 Display ID: O11019 Resetting Mi Account... On Your device detected FRP Lock! Reset it? Reading MI part... Formatting MI section Resetting FRP lock.. Backup saved as xiaomi_Redmi 6_10-02-2021_16-59-12.dump file Please power phone ON and enable "USB Debugging" then press "OK" button! If operation wasn't completed, then Your device get re-locked and credits aren't refundable! Searching for a phone (waiting for ADB / Fastboot device)... Please, press "OK" button on the phone to allow USB debugging.. Phone found. Reading info... Phone model: Xiaomi Redmi 6 SW version: O11019 Date: Sat Mar 16 06:10:11 WIB 2019 Android version: 8.1.0 Baseband MOLY.LR12A.R2.MP.V24.32.P122 Disabling Mi Services... Mi Account is successfully reseted! Performed by 1.9.9.1 Software version. | |
The Following User Says Thank You to XxTQxX For This Useful Post: |
02-10-2021, 19:25 | #40 (permalink) |
Freak Poster Join Date: Feb 2016 Location: ZIMBABWE
Member: 2534995 Status: Offline Thanks Meter: 93 | please add Huawei P Smart 2019 FRP Model : POT-LX1AF Device Firmware : :POT-LX1AF 10.0.0.263(C185E4R1P |
The Following User Says Thank You to mapopeemma For This Useful Post: |
02-11-2021, 06:56 | #44 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Negeri Para Penipu
Member: 142211 Status: Offline Thanks Meter: 90 | Redmi 9 lancelot FRP Couldn't find loader! INFO : 10/02/2021 13:56:30 > Platform: XIAOMI INFO : 10/02/2021 13:56:30 > Selected model: REDMI 9 WARN : 10/02/2021 13:56:30 > Please, power phone OFF and connect USB cable. INFO : 10/02/2021 13:56:31 > Searching for a phone. Please wait... INFO : 10/02/2021 13:56:35 > Found phone on COM16 INFO : 10/02/2021 13:56:35 > Port name: MediaTek USB Port_V1632 (COM16) INFO : 10/02/2021 13:56:35 > Detecting Chip Version... INFO : 10/02/2021 13:56:35 > HW Chip: MT6768: 0707.0000 INFO : 10/02/2021 13:56:35 > HW Version: 8A00.CA00.0000.0000 INFO : 10/02/2021 13:56:35 > Connecting... INFO : 10/02/2021 13:56:35 > Target Config: 00E7 WARN : 10/02/2021 13:56:35 > Brom Version: 05 INFO : 10/02/2021 13:56:35 > BootLoader Version: FE INFO : 10/02/2021 13:56:35 > Disabling protection... INFO : 10/02/2021 13:56:35 > Reconnecting... INFO : 10/02/2021 13:56:35 > Detecting Chip Version... INFO : 10/02/2021 13:56:35 > HW Chip: MT6768: 0707.0000 INFO : 10/02/2021 13:56:35 > HW Version: 8A00.CA00.0000.0000 INFO : 10/02/2021 13:56:35 > Target Config: 00E0 INFO : 10/02/2021 13:56:35 > Searching Download Agent... INFO : 10/02/2021 13:56:39 > Selected DA: MTK_AllInOne_DA_Octoplus_v1.1, n.0 INFO : 10/02/2021 13:56:39 > Sending Download Agent... INFO : 10/02/2021 13:56:40 > DA sent successfully INFO : 10/02/2021 13:56:40 > Initializing DA... INFO : 10/02/2021 13:56:40 > Synchronizing with DA... INFO : 10/02/2021 13:56:40 > Mobile Status: SYNC INFO : 10/02/2021 13:56:40 > Mobile Status: brom INFO : 10/02/2021 13:56:40 > Sending BootLoader Info... INFO : 10/02/2021 13:56:40 > Couldn't find loader! ERROR : 10/02/2021 13:56:40 > Operation was failed! INFO : 10/02/2021 13:56:40 > Performed by 1.9.9.0 Software version. |
