12-08-2018, 14:30 | #2521 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | SM-J106H FRP lock is successfully reseted! Platform: SAMSUNG Selected model: SM-J106H Reset FRP/ Reactivation lock operation for SM-J106H will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J106H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Advanced mode! Firmware write started. Writing Custom section... Custom section has been written successfully. Firmware writing successfully completed. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 1.5.2.0 Software version. |
The Following User Says Thank You to genci titi 2002 For This Useful Post: |
12-08-2018, 14:34 | #2522 (permalink) |
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | Samsung SM-J105H FRP lock is successfully reseted! Platform: SAMSUNG Selected model: SM-J105H Reset FRP/ Reactivation lock operation for SM-J105H will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J105H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Advanced mode! Firmware write started. Writing Custom section... Custom section has been written successfully. Firmware writing successfully completed. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 1.5.2.0 Software version. Last edited by Octopus box; 12-09-2018 at 12:06. |
12-08-2018, 15:00 | #2523 (permalink) |
Major Poster Join Date: May 2017
Member: 2718432 Status: Offline Thanks Meter: 23 | 🐙 M-net power 1 FRP lock is successfully done Platform: __GENERAL RESET FRP METHODS Selected model: MTK GENERAL Please, power phone OFF and connect USB cable. Searching for a phone. Please wait... Found phone on COM39 Detecting Chip Version... HW Chip: MT6580: 6580.0000 HW Version: 8A00.CA00.0000.0000 Connecting... Brom Version: FF BootLoader Version: 01 Searching Download Agent... Selected DA: MTK_AllInOne_DA_v3.3001.2018-04-25.11:32_437806, n.11 Sending Download Agent... DA sent successfully Initializing DA... Synchronizing with DA... NAND Flash: not installed eMMC Flash: .15010046.4E36324D.4203EE5F.DA34741F eMMC Flash: Samsung: FN62MB DA ver: 4.2.9C Initializing Memory Flash.. Initialization successfully completed Sending loaders... Loader send successfuly. Reading Flash Info... EMMC rpmb size: 0 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 7456 Mb Internal RAM size: 128 Kb External RAM size: 1024 Mb Reading partition... Reading info... Brand: m-net Model: Power1 Device: m-net Platform: mt6580 Android version: 7.0 Display ID: WQ181G.JHM.MNET.HB.N.H.SSTD8S12KFK9.B18.1121.V3.07 Searching for signatures... Resetting FRP lock.. FRP lock is successfully reseted! Backup saved as m-net_Power1_08-12-2018_05-51-14.dump file Performed by 1.5.1.0 Software version. Last edited by Octopus box; 12-09-2018 at 12:12. |
The Following User Says Thank You to yalil17 For This Useful Post: |
12-08-2018, 15:23 | #2524 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Russia, Ivanovo city
Member: 2006990 Status: Offline Thanks Meter: 540 | 🐙 Huawei Honor 7C AUM-L41 Reset FRP Successfully Done Platform: HUAWEI Selected model: AUM-L41 Put the phone in FastBoot Mode: 1. Remove SD and SIM cards from the phone 2. Power phone OFF 3. Press and hold "Vol-" and insert USB cable 4. Wait until the phone enter in FastBoot Mode Searching for a phone. Please wait... Detected phone model: AUM-L41 Phone SN: *********** Phone IMEI: ************ Connecting to server..OK Authorizing...OK Resetting FRP lock.. If the device didn't reboot automatically, try to reconnect USB cable or re-boot it manually. FRP lock is successfully reseted! Performed by 1.5.0.0 Software version. Thanks Octopus Team!! Last edited by Octopus box; 12-09-2018 at 12:13. |
The Following User Says Thank You to Surtax For This Useful Post: |
12-08-2018, 15:36 | #2525 (permalink) |
No Life Poster Join Date: Nov 2005
Member: 198016 Status: Offline Sonork: 100.1602918 Thanks Meter: 408 | SAMSUNG SM-N920T Reset FRP successfully done Platform: SAMSUNG Selected model: SM-N920T To put SM-N920T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. PIT was read successfully. Searching for UART interface.. COM4 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Resetting FRP lock.. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 1.5.3.0 Software version. |
The Following User Says Thank You to louka For This Useful Post: |
12-08-2018, 15:40 | #2526 (permalink) |
Member: 2006990 Status: Offline Thanks Meter: 540 | 🐙 Xaomi Redmi 5A RESET FRP Lock successfully reseted! Welcome to Octoplus FRP Tool v.1.5.0.0 Platform: XIAOMI Selected model: REDMI 5A Put the phone into EDL mode: 1. Attach testpoint as shown in Help manual; 2. Connect USB cable; 3. Release testpoint after 3-5 seconds. Searching for a phone. Please wait... Found phone on COM40 Mode: Qualcomm 9008 Connecting... Reading info... QC HW ID: 000560E100000000 QC CPU: Snapdragon 425 MSM8917 Searching loader... Sending loaders... Loader send successfuly. Reconnecting... Checking request.. Reading partition... Reading info... Brand: Xiaomi Model: Redmi 5A Device: riva Platform: msm8937 Android version: 7.1.2 Display ID: N2G47H Searching for signatures... Resetting FRP lock.. FRP lock is successfully reseted! Rebooting phone Backup saved as XIAOMI_REDMI 5A_08-12-2018_17-39-01.dump file Performed by 1.5.0.0 Software version. Thanks Octopus Team!!!! Last edited by Octopus box; 12-10-2018 at 05:16. |
12-08-2018, 15:40 | #2527 (permalink) |
Member: 2006990 Status: Offline Thanks Meter: 540 | 🐙 Xaomi Redmi 5A RESET FRP Lock successfully reseted! Welcome to Octoplus FRP Tool v.1.5.0.0 Platform: XIAOMI Selected model: REDMI 5A Put the phone into EDL mode: 1. Attach testpoint as shown in Help manual; 2. Connect USB cable; 3. Release testpoint after 3-5 seconds. Searching for a phone. Please wait... Found phone on COM40 Mode: Qualcomm 9008 Connecting... Reading info... QC HW ID: 000560E100000000 QC CPU: Snapdragon 425 MSM8917 Searching loader... Sending loaders... Loader send successfuly. Reconnecting... Checking request.. Reading partition... Reading info... Brand: Xiaomi Model: Redmi 5A Device: riva Platform: msm8937 Android version: 7.1.2 Display ID: N2G47H Searching for signatures... Resetting FRP lock.. FRP lock is successfully reseted! Rebooting phone Backup saved as XIAOMI_REDMI 5A_08-12-2018_17-39-01.dump file Performed by 1.5.0.0 Software version. Thanks Octopus Team!!!! Last edited by Octopus box; 12-09-2018 at 12:19. |
12-08-2018, 17:10 | #2528 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Ghana Age: 31
Member: 2207285 Status: Offline Thanks Meter: 127 | 🐙 ITEL IT1556 FRP lock is successfully reseted! ITEL IT1556 FRP lock is successfully reseted! Welcome to Octoplus FRP Tool v.1.5.3.0 Platform: __GENERAL RESET FRP METHODS Selected model: SC7731 V5 Please, reconnect battery, press and hold "Vol+" or "Vol-" button and connect USB cable. Searching for a phone. Please wait... Found phone on COM17 Connecting... Mobile Status: SPRD3 Sending preloader... Mobile Status: Spreadtrum Boot Block version 1.1 Sending mainloader... Reading info... Brand: Itel Model: itel it1556 Plus Device: itel_it1556Plus Platform: sc8830 Android version: 5.1 Display ID: LMY47D release-keys Searching for signatures... Resetting FRP lock.. FRP lock is successfully reseted! Backup saved as __GENERAL RESET FRP METHODS_SC7731 V5_08-12-2018_08-07-22.dump file Performed by 1.5.3.0 Software version. Last edited by Octopus box; 12-09-2018 at 12:21. |
The Following User Says Thank You to wagonstev For This Useful Post: |
12-09-2018, 10:04 | #2529 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Bangladesh Age: 34
Member: 1217931 Status: Offline Sonork: 100.1604251 Thanks Meter: 267 | HUAWEI AUM-AL20 Reset FRP Successfully Done HUAWEI AUM-AL20 FRP Done: Welcome to Octoplus FRP Tool v.1.5.3.0 Platform: HUAWEI Selected model: AUM-AL20 Put the phone in FastBoot Mode: 1. Remove SD and SIM cards from the phone 2. Power phone OFF 3. Press and hold "Vol-" and insert USB cable 4. Wait until the phone enter in FastBoot Mode Searching for a phone. Please wait... Detected phone model: AUM-AL20 Phone SN: XUV3Y18810076042 Phone IMEI: 868102044335813 Connecting to server..OK Authorizing...OK Resetting FRP lock.. If the device didn't reboot automatically, try to reconnect USB cable or re-boot it manually. FRP lock is successfully reseted! Performed by 1.5.3.0 Software version. Last edited by Octopus box; 12-09-2018 at 12:09. |
The Following User Says Thank You to md_amin For This Useful Post: |
12-09-2018, 10:58 | #2530 (permalink) |
No Life Poster Join Date: Feb 2012
Member: 1718440 Status: Offline Thanks Meter: 620 | 🐙 HUAWEI VNS-L21 FRP Reset Done with Octoplus FRP Tool Platform: HUAWEI Selected model: VNS-L21 Put the phone in FastBoot Mode: 1. Remove SD and SIM cards from the phone 2. Power phone OFF 3. Press and hold "Vol-" and insert USB cable 4. Wait until the phone enter in FastBoot Mode Searching for a phone. Please wait... Detected phone model: VNS-L21 Phone SN: Phone IMEI: 86 Phone IMEI: 86 SW version: VNS-L21C185B360 Connecting to server..OK Authorizing...OK Resetting FRP lock.. If the device didn't reboot automatically, try to reconnect USB cable or re-boot it manually. FRP lock is successfully reseted! Performed by 1.5.3.0 Software version. Last edited by Octopus box; 12-09-2018 at 12:29. |
The Following User Says Thank You to Bell666 For This Useful Post: |
12-09-2018, 11:48 | #2532 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | 🐙 Cell C Fame Reset FRP successfully done Here is log: Last edited by Octopus box; 12-09-2018 at 12:35. |
The Following User Says Thank You to CHAUDHRAY ARSHAD For This Useful Post: |
12-09-2018, 12:23 | #2533 (permalink) |
Freak Poster Join Date: Oct 2010 Location: USA
Member: 1420095 Status: Offline Thanks Meter: 216 | Huawei VKY-L29 Reset FRP Successfully Done! Welcome to Octoplus FRP Tool v.1.5.3.0 Platform: HUAWEI Selected model: _TEST-MODE Put the phone in FastBoot Mode: 1. Remove SD and SIM cards from the phone 2. Power phone OFF 3. Press and hold "Vol-" and insert USB cable 4. Wait until the phone enter in FastBoot Mode Searching for a phone. Please wait... Detected phone model: VKY-L29 Phone SN: QYJ7N17A16001374 Phone IMEI: 86...... Phone IMEI2: 86...... SW version: VKY-L29 8.0.0.370(C636) Connecting to server..OK Authorizing...OK Resetting FRP lock.. If the device didn't reboot automatically, try to reconnect USB cable or re-boot it manually. FRP lock is successfully reseted! Performed by 1.5.3.0 Software version. |
The Following User Says Thank You to himig_natin For This Useful Post: |
12-09-2018, 13:22 | #2534 (permalink) |
Member: 198016 Status: Offline Sonork: 100.1602918 Thanks Meter: 408 | HUAWEI SCL-U31 Reset FRP Successfully Done Welcome to Octoplus FRP Tool v.1.5.3.0 Platform: HUAWEI Selected model: SCL-U31 Put the phone in FastBoot Mode: 1. Remove SD and SIM cards from the phone 2. Power phone OFF 3. Press and hold "Vol-" and insert USB cable 4. Wait until the phone enter in FastBoot Mode Searching for a phone. Please wait... Detected phone model: SCL-U31 Phone SN: 8BG7N16303004084 Connecting to server..OK Authorizing...OK Resetting FRP lock.. If the device didn't reboot automatically, try to reconnect USB cable or re-boot it manually. FRP lock is successfully reseted! Performed by 1.5.3.0 Software version. |
12-10-2018, 08:17 | #2535 (permalink) |
Freak Poster Join Date: Oct 2013 Location: Bangladesh
Member: 2049143 Status: Offline Sonork: not use Thanks Meter: 270 | 🐙 Symphony V140 Reset FRP successfully done Platform: __GENERAL RESET FRP METHODS Selected model: MTK CUSTOM Selected Download Agent: C:\Users\GSM\Downloads\Compressed\v140MTK_AllInOne _DA_SP\MTK_AllInOne_DA_SP.bin Please, power phone OFF (press and hold "Vol+" or "Vol-" button) and connect USB cable. Searching for a phone. Please wait... Found phone on COM8 Detecting Chip Version... HW Chip: MT6580: 6580.0000 HW Version: 8A00.CA00.0000.0000 Connecting... Brom Version: FF BootLoader Version: 01 Searching Download Agent... Selected DA: MTK_AllInOne_DA_v3.3001.00.00, n.14 Sending Download Agent... DA sent successfully Initializing DA... Synchronizing with DA... NAND Flash: not installed eMMC Flash: .90014A48.38473461.32A53765.80483507 eMMC Flash: Hynix: H8G4a2 DA ver: 4.2.9C Initializing Memory Flash.. Initialization successfully completed Sending loaders... Loader send successfuly. Reading Flash Info... EMMC rpmb size: 4 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 7456 Mb Internal RAM size: 128 Kb External RAM size: 1024 Mb Reading partition... Reading info... Brand: Symphony Model: V140 Device: V140 Android version: 8.1.0 Display ID: O11019 release-keys Searching for signatures... Resetting FRP lock.. FRP lock is successfully reseted! Backup saved as Symphony_V140_10-12-2018_13-13-46.dump file Performed by 1.5.3.0 Software version. Last edited by Octopus box; 12-10-2018 at 08:58. |
The Following User Says Thank You to khorsed_pabna For This Useful Post: |
