03-12-2019, 16:50 | #3586 (permalink) |
No Life Poster Join Date: Apr 2008 Location: South Africa
Member: 746586 Status: Offline Thanks Meter: 207 | Welcome to Octoplus FRP Tool v.1.6.6.0 Platform: HUAWEI Selected model: FIG-LA1 Put the phone in FastBoot Mode: 1. Remove SD and SIM cards from the phone 2. Power phone OFF 3. Press and hold "Vol-" and insert USB cable 4. Wait until the phone enter in FastBoot Mode Searching for a phone. Please wait... Detected phone model: FIG-LA1 Phone SN: 35PNW18713000778 Phone IMEI: 869577033849594 Phone IMEI2: 869577033878049 SW version: FIG-LA1 8.0.0.133(C185) Connecting to server..OK Authorizing...OK Resetting FRP lock.. If the device didn't reboot automatically, try to reconnect USB cable or re-boot it manually. FRP lock is successfully reseted! Performed by 1.6.6.0 Software version. |
03-13-2019, 10:40 | #3587 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,338 | Welcome to Octoplus FRP Tool v.1.6.6.0 Platform: MOBICEL Selected model: X4 Please, power phone OFF, press and hold "Vol+" button and connect USB cable. Searching for a phone. Please wait... Found phone on COM7 Connecting... Mobile Status: SPRD3 Sending preloader... Mobile Status: Spreadtrum Boot Block version 1.1 Sending mainloader... Reading info... Brand: Mobicel Model: X4 Device: X4 Android version: 8.1.0 Custom build version: Mobicel_X4_8.1_MTN_ZA_04 Internal build version: Y400BG_8.1_MCL_MTN_ZA_08 Display ID: OPM2.171019.012 release-keys Searching for signatures... Resetting FRP lock.. FRP lock is successfully reseted! Backup saved as MOBICEL_X4_13-03-2019_11-33-54.dump file Performed by 1.6.6.0 Software version. |
03-13-2019, 13:47 | #3588 (permalink) |
Member: 746586 Status: Offline Thanks Meter: 207 | HUAWEI FIG-LX1 FRP lock is successfully reseted! Welcome to Octoplus FRP Tool v.1.6.6.0 Platform: HUAWEI Selected model: FIG-LX1 Put the phone in FastBoot Mode: 1. Remove SD and SIM cards from the phone 2. Power phone OFF 3. Press and hold "Vol-" and insert USB cable 4. Wait until the phone enter in FastBoot Mode Searching for a phone. Please wait... Detected phone model: FIG-LX1 Phone SN: HBE4C18414002403 Phone IMEI: 865878037833251 Phone IMEI2: 000000000000000 SW version: FIG-LX1 8.0.0.122(C16) Connecting to server..OK Authorizing...OK Resetting FRP lock.. If the device didn't reboot automatically, try to reconnect USB cable or re-boot it manually. FRP lock is successfully reseted! Performed by 1.6.6.0 Software version. |
03-13-2019, 13:47 | #3589 (permalink) |
03-13-2019, 19:25 | #3590 (permalink) |
Freak Poster Join Date: Jun 2017 Location: SAUDI ARABIA RIYADH
Member: 2725078 Status: Offline Sonork: 1680162 Thanks Meter: 173 | Platform: HUAWEI Selected model: LDN-L21 Put the phone in FastBoot Mode: 1. Remove SD and SIM cards from the phone 2. Power phone OFF 3. Press and hold "Vol-" and insert USB cable 4. Wait until the phone enter in FastBoot Mode Searching for a phone. Please wait... Detected phone model: LDN-L21 Phone SN: 26EBB185305#### Phone IMEI: 8667810408###$ Connecting to server..OK Authorizing...OK Resetting FRP lock.. If the device didn't reboot automatically, try to reconnect USB cable or re-boot it manually. FRP lock is successfully reseted! Performed by 1.6.6.0 Software version. |
03-13-2019, 19:26 | #3591 (permalink) |
Member: 2725078 Status: Offline Sonork: 1680162 Thanks Meter: 173 | Platform: SAMSUNG Selected model: SM-N920C To put SM-N920C into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. PIT was read successfully. Searching for UART interface.. COM8 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Resetting FRP lock.. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 1.6.6.0 Software version. |
03-13-2019, 19:26 | #3592 (permalink) |
03-13-2019, 19:27 | #3593 (permalink) |
Member: 2725078 Status: Offline Sonork: 1680162 Thanks Meter: 173 | Platform: HUAWEI Selected model: CPN-L09 Put the phone in FastBoot Mode: 1. Remove SD and SIM cards from the phone 2. Power phone OFF 3. Press and hold "Vol-" and insert USB cable 4. Wait until the phone enter in FastBoot Mode Searching for a phone. Please wait... Detected phone model: CPN-L09 Phone SN: DDEBB18324200786 Phone IMEI: 864593031****** Connecting to server..OK Authorizing...OK Resetting FRP lock.. If the device didn't reboot automatically, try to reconnect USB cable or re-boot it manually. FRP lock is successfully reseted! Performed by 1.6.6.0 Software version. |
03-13-2019, 19:27 | #3594 (permalink) |
03-13-2019, 19:51 | #3595 (permalink) |
Member: 2725078 Status: Offline Sonork: 1680162 Thanks Meter: 173 | Platform: SAMSUNG Selected model: SM-J700F Reset FRP/ Reactivation lock operation for SM-J700F will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Downloading resources... All necessary resource files have been downloaded successfully. Please put the phone into Download Mode and connect USB cable. To put SM-J700F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Advanced mode! Firmware write started. Writing Custom section... Custom section has been written successfully. Firmware writing successfully completed. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 1.6.6.0 Software version. |
03-13-2019, 19:52 | #3596 (permalink) |
03-14-2019, 10:34 | #3597 (permalink) |
Member: 746586 Status: Offline Thanks Meter: 207 | LG M250Y FRP lock is successfully reseted! Welcome to Octoplus FRP Tool v.1.6.6.0 Platform: LG Selected model: M250Y Put the phone into Download Mode: 1. Power phone OFF; 2. Press and hold "Vol+" button and connect USB cable. Searching for a phone. Please wait... Found phone on COM743 Reading info... Detected phone model: LG-M250Y Mode: Emergency Initializing.. SW version: LGM250YAT-00-V10b-ZAF-XX-MAR-08-2017+0 Android version: 7.0 Platform: mt6750 Reset FRP operation for M250Y will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partition... Detecting writing method... Trying to repeat.. Resetting FRP lock.. Writing loader... Writing userdata... Formating encrypt section Restoring loader... Perform factory reset to complete operation! FRP lock is successfully reseted! Performed by 1.6.6.0 Software version. |
03-14-2019, 10:34 | #3598 (permalink) |
03-14-2019, 16:34 | #3599 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | Sony e6633 (7.1.1) Reset FRP successfully done (adb enabled from TalkBack): Code: Platform: __GENERAL RESET FRP METHODS Selected model: ADB Searching for a phone (waiting for ADB device)... Phone found. Reading info... Phone model: Sony E6633 SW version: 32.4.A.1.54 Date: Fri Aug 18 15:21:50 CST 2017 Android version: 7.1.1 Baseband 8994-FAAAANAZQ-00065-37 Resetting FRP lock.. FRP lock is successfully reseted! Performed by 1.6.7.0 Software version. |
03-14-2019, 16:53 | #3600 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Slovakia Age: 40
Member: 17405 Status: Offline Thanks Meter: 345 | Noa H2 FRP unlock successfully Welcome to Octoplus FRP Tool v.1.6.5.0 Platform: __GENERAL RESET FRP METHODS Selected model: MTK GENERAL Please, power phone OFF and connect USB cable. Searching for a phone. Please wait... Found phone on COM246 Detecting Chip Version... HW Chip: MT6737: 0335.0000 HW Version: 8A00.CB00.0000.0000 Connecting... Brom Version: FF BootLoader Version: 01 Searching Download Agent... Selected DA: MTK_AllInOne_DA_v3.3001.2018-11-07.23:57_458956, n.10 Sending Download Agent... DA sent successfully Initializing DA... Synchronizing with DA... NAND Flash: not installed eMMC Flash: .15010052.3832314D.420065A8.CEF7BD5D eMMC Flash: Samsung: R821MB DA ver: 4.2.9B Initializing Memory Flash.. Initialization successfully completed Sending loaders... Loader send successfuly. Reading Flash Info... EMMC rpmb size: 4 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 14910 Mb Internal RAM size: 128 Kb External RAM size: 2048 Mb Reading partition... Reading info... Brand: NOA Model: NOA_H2 Device: NOA_H2 Platform: mt6737m Android version: 6.0 Display ID: NOA_H2_V0.9_20170401 Searching for signatures... Resetting FRP lock.. FRP lock is successfully reseted! Backup saved as NOA_NOA_H2_14-03-2019_16-52-26.dump file Performed by 1.6.5.0 Software version. |
