Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus FRP Tool
Old 03-23-2018, 20:35   #391 (permalink)
danieltotten35's Avatar
Member: 2812378
Thanks Meter: 95
HUAWEI MYA-L22 Reset FRP successfully done
Platform: HUAWEI
Selected model: MYA-L22
Put the phone in FastBoot Mode:
1. Remove SD and SIM cards from the phone
2. Power phone OFF
3. Press and hold "Vol-" and insert USB cable
4. Wait until the phone enter in FastBoot Mode
Searching for a phone. Please wait...
Operation was failed!
Performed by 1.1.7 Software version.
Platform: HUAWEI
2. Power phone OFF
Detected phone model: MYA-L22
Phone SN: R9KBBCB760900XXX
Connecting to server..OK
Authorizing...OK
Resetting FRP lock..
FRP lock is successfully reseted!
The Following User Says Thank You to danieltotten35 For This Useful Post:
Old 03-23-2018, 23:12   #392 (permalink)
Member: 2382052
Thanks Meter: 1,510
Thumbs up 🐙 LG MS210 Reset FRP successfully done
Welcome to Octoplus FRP Tool v.1.1.9
Platform: LG
Selected model: MS210
Put the phone into Download Mode:
1. Power phone OFF;
2. Press and hold "Vol+" button and connect USB cable.
Found phone on COM134
Reading info...
Detected phone model: LGMS210
Warning: Selected model (MS210) differs from the detected one (LGMS210)!
Mode: Emergency
Initializing..
SW version: LGMS210AT-02-V10i-310-160-APR-07-2017-ARB00+0
Android version: 7.0
Performed by 1.1.9 Software version.
Platform: LG
1. Power phone OFF;
Reading info...
Mode: Emergency
Initializing..
Reset FRP operation for MS210 will delete all user data on the phone (contacts, pictures and others)!
Do You want to continue?
Reading partition...
Writing loader...
Writing userdata...
Formating encrypt section
Restoring loader...
Perform factory reset to complete operation!
The Following User Says Thank You to maxpatri9 For This Useful Post:
Old 03-24-2018, 03:51   #393 (permalink)
Dr_Wolodya's Avatar
Member: 75408
Thanks Meter: 1,174
Reset FRP on Samsung SM-G920A (7.0) successfully done
Reset FRP on Samsung SM-G920A (7.0) successfully done:
Platform: SAMSUNG
Selected model: SM-G920A
To put SM-G920A into Download Mode, You have to perform the following steps:
1. Reconnect the battery.
2. Press and hold "Volume-" + "Home" + "Power ON" keys.
3. When phone turns on, press "Volume+" key.
Phone found.
Initializing..
PIT was read successfully.
Searching for UART interface.. COM771
Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds
Searching for device. Please wait...
Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset"
The Following User Says Thank You to Dr_Wolodya For This Useful Post:
Old 03-24-2018, 06:51   #394 (permalink)
Member: 2812378
Thanks Meter: 95
Asus Z300M Reset FRP successfully done
Platform: ASUS
Selected model: Z300M (P00C)
Put the phone into Fastboot Mode:
1. Power phone OFF;
Phone found.
Enabling "USB Debugging" mode...
Rebooting to Normal mode...
Searching for a phone (waiting for ADB device)...
Phone found.
Reading info...
Phone model: asus P00C
SW version: NRD90M
Date: Tue Dec 19 15:15:16 CST 2017
Old 03-24-2018, 08:38   #395 (permalink)
Member: 2125860
Thanks Meter: 278
Thumbs up 🐙 Samsung SM-J200G Frp Lock (Success)
Platform: SAMSUNG
Selected model: SM-J200G
Reset FRP/ Reactivation lock operation for SM-J200G will delete all user data on the phone (contacts, pictures and others)!
NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service.
Connecting to server...
Connecting to server...Ok!
Checking resource files...
Downloading resources...
All necessary resource files have been downloaded successfully.
Please put the phone into Download Mode and connect USB cable.
To put SM-J200G into Download Mode, You have to perform the following steps:
Waiting for phone...
Firmware write started.
Writing Custom section...
Custom section has been written successfully.
Firmware writing successfully completed.
The Following User Says Thank You to pandoragsm For This Useful Post:
Old 03-24-2018, 12:03   #396 (permalink)
Gsm-extreme's Avatar
Member: 659181
Thanks Meter: 7,652
HUAWEI MYA-L22 FRP successfully reseted
Platform: HUAWEI
2. Power phone OFF
Phone SN: R9KBBDB792145826
Authorizing...OK
The Following User Says Thank You to Gsm-extreme For This Useful Post:
Old 03-24-2018, 12:03   #397 (permalink)
Member: 1409573
Sonork: 100.1615416
Thanks Meter: 82
Thumbs up 🐙O.Phone Pascal FRP successfully reseted
O.phone pascal frp reseted by selected as CUBOT DINOSAUR
Platform: CUBOT
Selected model: DINOSAUR
Please, power phone OFF and connect USB cable.
Found phone on COM15
Detecting Chip Version...
HW Chip: MT6580: 6580.0000
HW Version: 8A00.CA00.0000.0000
Connecting...
Brom Version: FF
BootLoader Version: 01
Searching Download Agent...
Selected DA: MTK_AllInOne_DA_v3.3001.2017-09-06.13:15_388644, n.11
Sending Download Agent...
DA sent successfully
Initializing DA...
Synchronizing with DA...
NAND Flash: not installed
eMMC Flash: .15010046.4A323541.4202B580.9B0B53C1
eMMC Flash: Samsung: FJ25AB
DA ver: 4.2.9C
Initializing Memory Flash..
Initialization successfully completed
Sending loaders...
Loader send successfuly.
Reading Flash Info...
EMMC rpmb size: 0 Mb
EMMC boot1 size: 4 Mb
EMMC boot2 size: 4 Mb
EMMC gp1 size: 0 Mb
EMMC gp2 size: 0 Mb
EMMC gp3 size: 0 Mb
EMMC gp4 size: 0 Mb
EMMC user area size: 3728 Mb
Internal RAM size: 128 Kb
External RAM size: 512 Mb
Reading info...
Brand: O.Phone
Model: PASCAL_4.0
Device: bird6580_weg_b_l
Platform: mt6580
Android version: 5.1
Display ID: V01-P4010G-2017
Searching for signatures...
Backup saved as CUBOT_DINOSAUR_24-03-2018_16-27-49.dump file
The Following User Says Thank You to imanka For This Useful Post:
Old 03-24-2018, 12:04   #398 (permalink)
Member: 2812378
Thanks Meter: 95
ASUS P00C FRP successfully reseted
Platform: ASUS
1. Power phone OFF;
Phone found.
Phone found.
Reading info...
SW version: NRD90M
Old 03-24-2018, 14:20   #399 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 2,314
HUAWEI BAC-L21 Nova 2 Plus FRP lock is successfully reseted!
2. Power phone OFF
Platform: HUAWEI
Selected model: BAC-L21
2. Power phone OFF
Platform: HUAWEI
2. Power phone OFF
Detected phone model: BAC-L21
Phone SN: GUYDU17908005013
Phone IMEI: 864841033011505
Phone IMEI2: 864841033032014
SW version: BAC-L21C185B102
Authorizing...OK
If the device didn't reboot automatically, try to reconnect USB cable or re-boot it manually.
Thanks Octoplus team
The Following User Says Thank You to pintu_das For This Useful Post:
Old 03-24-2018, 17:42   #400 (permalink)
Member: 2382052
Thanks Meter: 1,510
Thumbs up 🐙 Samsung SM-G610M Reset FRP successfully done via UART
Platform: SAMSUNG
Selected model: SM-G610M
Searching for UART interface.. COM14
Phone found.
Rebooting phone in Upload Mode...OK
Please connect phone to USB cable..
Searching for a phone. Please wait...OK
Reading data...
Checking operation...OK
Phone found.
Resetting FRP lock (1/4 attempt)..success
Old 03-24-2018, 18:03   #401 (permalink)
Member: 2382052
Thanks Meter: 1,510
Thumbs up LG M150 Reset FRP successfully done
Platform: LG
Selected model: M150
1. Power phone OFF;
Found phone on COM145
Reading info...
Detected phone model: LG-M150
Mode: Emergency
Initializing..
SW version: LGM150AT-00-V20d-ATT-US-MAY-02-2017-ARB00+0
Reset FRP operation for M150 will delete all user data on the phone (contacts, pictures and others)!
Writing loader...
Writing userdata...
Restoring loader...
Old 03-25-2018, 07:06   #402 (permalink)
Member: 2125860
Thanks Meter: 278
Thumbs up 🐙 ASUS Zenfone 3 Max Reset FRP (Success)
Platform: ASUS
Selected model: ZC520TL (X008DC)
Please, power phone OFF, press and hold "Vol-" button and connect USB cable.
Found phone on COM45
HW Chip: MT6735: 0335.0000
HW Version: 8A00.CB00.0000.0000
Connecting...
Brom Version: 05
BootLoader Version: FE
Selected DA: MTK_AllInOne_DA_v3.3001.2017-09-06.13:15_388644, n.10
Initializing DA...
eMMC Flash: .13014E51.334A3937.5610031D.4A8CA3D1
eMMC Flash: Unknown: Q3J97V
DA ver: 4.2.9B
Sending BootLoader Info...
Sending loaders...
EMMC rpmb size: 4 Mb
EMMC gp1 size: 0 Mb
EMMC gp2 size: 0 Mb
EMMC gp3 size: 0 Mb
EMMC gp4 size: 0 Mb
EMMC user area size: 29820 Mb
External RAM size: 3072 Mb
Reading info...
Brand: asus
Model: ASUS_X008DA
Device: ASUS_X008_1
Platform: mt6737m
Display ID: NRD90M.ID_Phone-14.11.1707.49-20170726
Backup saved as ASUS_ZC520TL (X008DC)_25-03-2018_11-32-42.dump file
Old 03-25-2018, 08:16   #403 (permalink)
Member: 2812378
Thanks Meter: 95
Thumbs up HUAWEI MYA-L22 FRP successfully reseted again
Platform: HUAWEI
2. Power phone OFF
Authorizing...OK
Old 03-25-2018, 08:48   #404 (permalink)
deeptelecomzira's Avatar
Member: 2218251
Thanks Meter: 1,094
Arrow Nokia 3 ta-1032 frp remove done with one click only by octupus frp tool
NOKIA 3 TA-1032 FRP REMOVE DONE WITH ONE CLICK ONLY BY OCTUPUS FRP TOOL:
Deeptelecomzira
The Following User Says Thank You to deeptelecomzira For This Useful Post:
Old 03-25-2018, 12:19   #405 (permalink)
Member: 2812378
Thanks Meter: 95
Thumbs up ASUS P00C FRP reseted successfully
Platform: ASUS
1. Power phone OFF;
Phone found.
Phone found.
Reading info...
SW version: NRD90M
Page generated in 0.28585 seconds with 9 queries
