iphone 6 activation error 1 Attachment(s) any solution change sn/ wifi mac |
some one tell me change nand correct value i dont know which value plz guide may thankx |
Your question is not clear , what is your main purpose and what are you trying. Tip : You should use original values for the devices with the baseband If you are trying to unlock i cloud It will not work because there is Baseband ID in calculating UDID related to IMEI but if you have replaced the NAND and looking for activating with device original IDs - Check your device original WIFI , Bluetooth and SN number if you lost them request through some GSX services . Best Regards |
thankx for urs reply 1 Attachment(s) thankx for urs reply i got iphone 6 after reset "could not activate phone iphone" some one tell me change mac address i remove nand write default boot now getting error 4014 now write oraginal value from backup still getting error 4014 any help???? |
from phone backup 1 Attachment(s) read from phone ...after write same value still error no 4014 |
#Select the boot #modify the details with your original device #Write Boot #Done |
vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
