[ SERIAL + WIFI + BT ] For UNLOCK ICLOUD (( ALL MODELS SUPPORTED )) (VERIFY 24h) [ SERIAL + WIFI + BT ] FOR IPAD NAND REPAIR (( ALL MODELS SUPPORTED )) (VERIFY 24h) This not unlock service. We will give you new serial with BT and WiFi adress to unlock your ipad by hardware. i will send the info instant when im online ((VERIFY TIME IS 1-24h ONLY !!!) ____________________________ NOTE : try to put your icloud id as fast as you write the serial on your ipad IF owner of the device make it ON then if you restore your device it will be relocked to icloud and you have to buy new serial and we are not responsible for this DISCLAIMER : AFTER RESET IPAD IT MAY RELOCK WE ARE NOT RESPONSIBLE FOR THIS BETTER YOU PUT ICLOUD ID DIRECTLY ONCE YOU GET THE SN AND WRITE IT ON YOUR DEVICE .. THIS MAY PROTECT RELOCK ISSUE AFTER RESTORE now service back with all models supported we are main provider in market send your Serials now XpertsGsm Server |
We updated the verification policy now you can verify activation error within 1-7 days and FMI ON within 24 hours thanks and good day |
hi suport ipad pro a9x ? hi is iPad pro supported ? |
i have ipad pro 12'' with 4g sim is that ipad supported ? or only wifi model ? |
1.If your device is a cellular version ( 4g - lte ) , You need to cut off the gsm baseband to make it be the wifi only . 2. Dismantle the IC Nand Flash and using box edit write new Full set serial by ( Navi pro -IPbox .WL...ect) 3.Restore your divice , activate it with itunes 4. Enjoy your iDevice |
cuando dices que si restablece se bloquea de nuevo quiere decir que es como un bypass?? |
we said this : NOTE : try to put your icloud id as fast as you write the serial on your ipad IF owner of the device make it ON then if you restore your device it will be relocked to icloud and you have to buy new serial and we are not responsible for this |
