05-26-2020, 12:11 | #1 (permalink) |
No Life Poster Join Date: Jan 2010
Member: 1212133 Status: Offline Thanks Meter: 58 | ALE-L21 - P8 lite - how to flash [Answered] What is the procedure? The phone bootloops. Thanks |
05-26-2020, 12:34 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. If You can put your device into Upgrade Mode, then try to reflash it, if You can't do that. Then try to read out information about firmware version and revision via FastBoot Mode, after try to write correct firmware with same revision or higher firmware version, after that You will able to reflash your deviec via Upgrade Mode, what we recommend You to do, after. |
05-26-2020, 15:39 | #3 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | But how can I read out the information about the firmware version? I tried C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot getvar all getvar:all FAILED (remote: Command not allowed) finished. total time: 0.005s Thanks for help |
05-26-2020, 22:51 | #4 (permalink) | |
No Life Poster Join Date: Nov 2017 Location: Russian
Member: 2778414 Status: Offline Thanks Meter: 342 | Quote:
C:\Program Files (x86)\Minimal ADB and Fastboot> fastboot devices | |
05-27-2020, 07:55 | #5 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | Thanks for help. It looks like this C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot devices W3D7N17905001517 fastboot but where can I see( from that ) the information about firmware I should use for flashing? Thanks for reply |
05-27-2020, 08:24 | #7 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | I use Octoplus Huawei 1.1.8 but on Write Firmware tab there is no Read info button. Read info button is on Unlock tab . Did you mean that ? And in which mode must be phone started? In fastboot mode the Read info button is not active. |
05-27-2020, 09:07 | #8 (permalink) |
Member: 2778414 Status: Offline Thanks Meter: 342 | fastboot oem get-build-number fastboot oem get-psid fastboot oem get-product-model fastboot getvar vendorcountry |
The Following User Says Thank You to solgeo For This Useful Post: |
05-27-2020, 10:48 | #9 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | @solgeo: Thank you for your help.Now I know what version of firmware to use. But the phone can not be started in UPGRADE/download mode ( Vol+ and Vol- and USB cable). The phone hangs on Huawei logo. I can start in fastboot mode only and it can not be flashed from fastboot mode because bootloader is locked. Can you please let me know how to continue? To flash a Bootloader image somehow?? Thanks |
05-27-2020, 11:39 | #10 (permalink) | |
C:\Program Files (x86)\Minimal ADB and Fastboot> fastboot oem get-build-number fastboot oem get-psid fastboot oem get-product-model fastboot getvar vendorcountry | |
05-27-2020, 12:12 | #11 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | Thanks . I flashed it Device Model: ALE-L21 System: ALE-L21C432B628 IMEI A: 865868037610106 S/N: W3D7N17905001517 Extracting firmware partitions... Partitions has been extracted successfully Checking firmware compatibility Firmware is not compatible Selected firmware is not compatible with your device revision. Writing of this firmware may lead to phone damage! Error: Command not allowed Writing MODEMIMAGE partition... Warning: Writing MODEMIMAGE partition failed Connecting to server... Writing MODEMIMAGE partition... Writing MODEMNVM1 partition... Writing MCUIMAGE partition... Writing HIFI partition... Writing DSP partition... Writing DTIMAGE partition... Writing TEEOS partition... Writing TRUSTFIRMWARE partition... Writing SECURETYSTORAGE partition... Writing NVME partition... Writing FASTBOOT1 partition... Writing FASTBOOT partition... Writing RECOVERY partition... Writing RECOVERY2 partition... Writing BOOT partition... Writing SYSTEM partition... Writing 1 chunk from 6... Writing 2 chunk from 6... Writing 3 chunk from 6... Writing 4 chunk from 6... Writing 5 chunk from 6... Writing 6 chunk from 6... Writing CACHE partition... Erasing USERDATA partition.. Writing USERDATA partition... Write Firmware(Fastboot mode) done. Performed by 1.1.8 Software version. But it still does not start . It restarts and also not Upgrade mode can not start - only logo that restarts. Any further idea? Thanks |
05-27-2020, 13:07 | #13 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | I downloaded the board firmware from Octopus support ALE-L21_HL3ALICEMAA001079_Board Software_null_null_Android 5.0.2_EMUI 3.1_05021SJN IN which mode must be the phone connected to a computer so that I can flash the Board firmware? Is there any description or HOW-TO? Thanks for help |
05-27-2020, 13:51 | #14 (permalink) | |
05-28-2020, 10:28 | #15 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | Thanks for reply. I successfully flashed board firmware Starting Write Firmware(Board mode) Phone connect successfully Updating bootloader... Writing xloader partition.. Writing fastboot partition.. Boot board firmware files has been written successfully Rebooting to fastboot mode.. Searching Fastboot devices... Warning: Reading product model failed Warning: Reading serial number failed Warning: oem get-build-number failed Erasing modemnvbkup partition.. Erasing modemnvreserved partition.. Erasing cust partition.. Writing ptable partition... Writing fastboot1 partition... Writing fastboot partition... Writing mcuimage partition... Erasing nvme partition.. Writing nvme partition... Writing modemimage partition... Writing modemnvm1 partition... Writing modemnvm2 partition... Writing modemnvm3 partition... Writing dsp partition... Writing hifi partition... Writing modemlog partition... Writing recovery partition... Writing splash2 partition... Erasing oeminfo partition.. Writing oeminfo partition... Writing boot partition... Writing dtimage partition... Writing cache partition... Writing system partition... Writing 1 chunk from 3... Writing 2 chunk from 3... Writing 3 chunk from 3... Writing userdata partition... Writing efuse partition... Writing trustfirmware partition... Writing teeos partition... Writing securetystorage partition... Note: After successful reflash the phone in Board Firmware mode, for a correct work of the device, you need to reflash it in Upgrade mode! Write Firmware(Board mode) done. Performed by 1.1.8 Software version. but still I can not start UPGRADE mode.( Vol- and Vol + and USB cable) There is a bootloop. When I start the phone it finishes with FASTBOOT mode Do you have any next idea? Thanks |
