clt-l09 p 20 pro board software [Answered] I have neckens to have the board software for this CLT-L09 P20 Pro model I can't update Job ID: 0000000001B976A6 2022-11-28 13:04:02 Starting Write Firmware(Factory mode) Selected phone model: CLT-L09 PACKAGE_TYPE: OFFLINE_UPDATE VERLIST : CLT_Global-CUST 9.0.0(C999) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: LCL0218528002851 Device Model: CLT-L09 System: CLT-L09 8.1.0.161(C432) Writing VERSION partition... Error: Erasing PRELOAD partition failed Writing PRELOAD partition... Warning: Writing PRELOAD partition failed Connecting to server... Writing PRELOAD partition... Warning: Failed to read download size response Warning: Writing PRELOAD partition failed Error: Writing PRELOAD partition failed Error: Erasing USERDATA partition failed Writing USERDATA partition... Writing 1 chunk from 4... Warning: Failed to write download size Warning: Writing USERDATA partition failed Writing USERDATA partition... Writing 1 chunk from 4... Warning: Failed to write download size Warning: Writing USERDATA partition failed Error: Writing USERDATA partition failed Write Firmware(Factory mode) done. Performed by 1.3.3 Software version. |
Hello Why did you decide to re-flash device? Also, please explain in more detail the state of device |
https://androidhost.ru/Xap -bigger version https://androidhost.ru/4Zg -seme version as our phone try |
Found COM ports: 1: COM8 USB Serial Port Job ID: 0000000001B9F059 2022-11-29 15:23:57 Starting Write Firmware(Factory mode) Selected phone model: CLT-L09 Selected base ptable file: F:/smart clip/octopusbox/software/huawei/update firware offline/serie c/CLT-L09/Huawei P20 Pro CLT-L09 hw eu HLRCF Charlotte-L09C 9.1.0.380(C432E8R1P11T8) Firmware EMUI9.1.0 05015ANN [androidhost.ru]/Software/dload/CLT-L09_hw_eu/update_CLT-L09_hw_eu.app PACKAGE_TYPE: OFFLINE_UPDATE VERLIST : CLT_Global-CUST 9.0.0(C999) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing XLOADER partition... Writing UCE partition... Canceling... Please be patient! Error: Failed write UCE partition Write Firmware(Factory mode) canceled. Performed by 1.3.3 Software version. Job ID: 0000000001BEC235 2022-11-29 15:34:03 Starting Write Firmware(Factory mode) Selected phone model: CLT-L09 PACKAGE_TYPE: OFFLINE_UPDATE VERLIST : CLT_Global-CUST 9.0.0(C999) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Canceling... Please be patient! Write Firmware(Factory mode) canceled. Performed by 1.3.3 Software version. Job ID: 0000000001B9F18E 2022-11-29 15:35:14 Starting Write Firmware(Factory mode) Selected phone model: CLT-L09 PACKAGE_TYPE: OFFLINE_UPDATE VERLIST : CLT_Global-CUST 9.0.0(C999) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: LCL0218528002851 Warning: oem get-build-number failed Device Model: CLT-L09 Warning: oem get-build-number failed Error: Erasing VERSION partition failed Error: Writing VERSION partition failed Error: Erasing PRELOAD partition failed Error: Writing PRELOAD partition failed Error: Erasing USERDATA partition failed Canceling... Please be patient! Write Firmware(Factory mode) canceled. Performed by 1.3.3 Software version. Job ID: 0000000001B9F1AC 2022-11-29 15:36:24 Starting Write Firmware(Factory mode) Selected phone model: CLT-L09 Error: Please select download xml firmware file! PACKAGE_TYPE: OFFLINE_UPDATE VERLIST : CLT_Global-CUST 9.0.0(C999) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: LCL0218528002851 Device Model: CLT-L09 System: CLT-L09 8.1.0.161(C432) Writing VERSION partition... Error: Erasing PRELOAD partition failed Writing PRELOAD partition... Warning: Writing PRELOAD partition failed Connecting to server... Writing PRELOAD partition... Warning: Failed to read download size response Warning: Writing PRELOAD partition failed Error: Writing PRELOAD partition failed Error: Erasing USERDATA partition failed Writing USERDATA partition... Writing 1 chunk from 4... Warning: Failed to write download size Warning: Writing USERDATA partition failed Writing USERDATA partition... Writing 1 chunk from 4... Warning: Failed to write download size Warning: Writing USERDATA partition failed Error: Writing USERDATA partition failed Write Firmware(Factory mode) done. Performed by 1.3.3 Software version. |
Hello What the state of device right now? |
