02-25-2021, 15:13 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | DUB-LX1 After Flash XML File Now eRcpovery Problem [Solved] Welcome to Octoplus Huawei Software v.?1.2.4? To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode Performed by ?1.2.4? Software version. grade/rawprogram0.xml file Selected rawprogram file: D:/Huawei/DUB-LX1/Huawei Y7 2019 DUB-LX1_8.1.0_143_(185)_EDL_Unbrick_downgrade/DUB-LX1_8.1.0_143_(185)_EDL_Unbrick_downgrade/patch0.xml Selected rawprogram file: D:/Huawei/DUB-LX1/Huawei Y7 2019 DUB-LX1_8.1.0_143_(185)_EDL_Unbrick_downgrade/DUB-LX1_8.1.0_143_(185)_EDL_Unbrick_downgrade/rawprogram0.xml Selected patch file: D:/Huawei/DUB-LX1/Huawei Y7 2019 DUB-LX1_8.1.0_143_(185)_EDL_Unbrick_downgrade/DUB-LX1_8.1.0_143_(185)_EDL_Unbrick_downgrade/patch0.xml Selected firehose file: D:/Huawei/DUB-LX1/Huawei Y7 2019 DUB-LX1_8.1.0_143_(185)_EDL_Unbrick_downgrade/DUB-LX1_8.1.0_143_(185)_EDL_Unbrick_downgrade/prog_emmc_firehose.mbn Selected Full flashing mode! Job ID: 0000000000A38A69 2021-02-25 12:10:38 GMT ------------------------------------------------- Starting Write Firmware(Factory mode) Selected phone model: ?DUB-LX1? Warning: Please, before firmware write, disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Android-based devices). Dont run any other programs or attach new devices to your computer during the flashing procedure! Don’t turn off phone and don’t disconnect cable during firmware write. Please, follow these simple instructions to avoid phone damage Connecting to phone.. Please, reconnect battery, connect USB cable with attached Test Point on your phone! Sending loader prog_emmc_firehose.mbn... Loader send successfully Reconnecting, please wait.. Writing. Please wait... Writing RPM partition... Writing TZ partition... Writing SBL1 partition... Writing APDP partition... Writing MSADP partition... Writing KEYMASTER partition... Writing DEVCFG partition... Writing ABOOT partition... Writing MODEM partition... Writing KERNEL partition... Writing RAMDISK partition... Writing RECOVERY_RAMDISK partition... Writing RECOVERY_VENDOR partition... Writing ERECOVERY_KERNEL partition... Writing ERECOVERY_RAMDISK partition... Writing ERECOVERY_VENDOR partition... Writing SYSTEM partition... Writing CACHE partition... Writing ODM partition... Writing VENDOR partition... Writing PRODUCT partition... Writing USERDATA partition... Writing GPT_MAIN0 partition... Writing GPT_BACK0 partition... Patching. Please wait... Patch done successfully Write Firmware(Factory mode) done. Performed by ?1.2.4? Software version. |
03-02-2021, 11:15 | #3 (permalink) |
Member: 1444462 Status: Offline Thanks Meter: 1,337 | all the problem has been solved Welcome to Octoplus Huawei Software v.1.2.4 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: Job ID: 0000000000AA288D 2021-03-02 09:53:25 GMT ------------------------------------------------- Starting Connect Selected phone model: DUB-LX1 Detected DBAdapter Reserved Interface port Connecting to server... Authorization is successful Device Model: DUB-LX1 Boot: Chipset-sdm450 8.2.0.33(00UW)_SBL1 System: System 8.2.0.036(04A0) MEID: 00000000000000 PESN: 00000000 IMEI A: 86XXXXXXXXXXXXX Bluetooth MAC: 1C:B7:96:EC:8A:45 WiFi MAC: 1C:B7:96:EC:85:5B S/N: DYN6R19826002175 Board S/N: 6R5PGV198R070459 Vendor Code: vodacom Country Code: za Connect done. Performed by 1.2.4 Software version. 2021-03-02 09:54:07 GMT ------------------------------------------------- Starting Repair Info Selected phone model: DUB-LX1 New IMEI A: 86XXXXXXXXXXXXXXX Repairing IMEI A... Resetting your device Repair Info done. Performed by 1.2.4 Software version. |
The Following User Says Thank You to ..::GMSR::.. For This Useful Post: |
