11-30-2022, 21:30 | #1 (permalink) |
Junior Member Join Date: Aug 2018 Location: Chile Age: 39
Member: 2859078 Status: Offline Thanks Meter: 2 | ELS-NX9 error remove huawei emui12 [Answered] Device Model: ELS-N29 System: ELS-N29 12.0.0.246(C605E2R3P4) Android Version: 10 Base Version: ELS-LGRP4-OVS 102.0.0.246 Custom Version: ELS-N29-CUST 102.0.0.2(C605) Preload Version: ELS-N29-PRELOAD 102.0.0.4(C605R3) C_Version: C605 D_Version: D1 Read*Info*done. |
12-01-2022, 09:11 | #2 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,138 | Hello Unfortunately, your device has high security level. Please, re-flash device with this firmware version via factory mode (ELS-NX9 102.0.0.218(C185E3R6P3) Path: /Huawei/Huawei Update firmwares (Offilne)/E-series/ELS-NX9/ Thereafter, you can perform Reset Huawei ID operation. |
06-20-2023, 09:15 | #3 (permalink) | |
Junior Member Join Date: Mar 2020 Location: slovakia
Member: 2950906 Status: Offline Thanks Meter: 0 | Quote:
pls help. | |
06-20-2023, 09:42 | #4 (permalink) | |
Member: 2891705 Status: Offline Thanks Meter: 2,138 | Hello As we can see from software log, your device has high security level, which currently not supported. Quote:
Thereafter, please send us result. All write firmware operation you do at your own risk | |
The Following User Says Thank You to Octopus support For This Useful Post: |
06-26-2023, 19:31 | #5 (permalink) |
Junior Member Join Date: Sep 2005 Location: austria Age: 41
Member: 180745 Status: Offline Thanks Meter: 12 | i have already dwongrade with the firmware on supportpage, after downgrade i chose emui 11, but during process say reconnect cable and after reconnecting not found in fastbootmode... if i choose emui 12 its works (its say during unlock you choose false emui it will not work) it finds in fastbootmode but not unlock emui 11 choose: Job ID: 00000000020CF00D 2023-06-26 18:20:31 Starting Direct Unlock Selected phone model: ELS-NX9 Selected method: Direct Unlock (EMUI12/Harmony) Warning: Please, make sure the phone`s battery is fully charged and connected, after connect the device via Factory Mode (use Hardware Test Point or "ON/OFF Factory Mode option"). Warning: Selected response: Proceed Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN990_5G_V5... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Writing BL2 partition... Operation in progress. Please wait for instructions... Bootloader Update successfully Rebooting to fastboot mode... Warning: If you use modified USB cable please reconnect cable from the mother board and press "Ok" to proceed the operation Warning: Selected response: Ok Searching Fastboot devices... Error: Fastboot devices not found Direct Unlock failed. emui 12 Choose: Job ID: 00000000020CEF37 2023-06-26 18:13:34 Starting Reset Huawei ID Selected phone model: ELS-NX9 Selected method: Reset Huawei Id (EMUI12/Harmony) Warning: Please, make sure the phone`s battery is fully charged and connected, after connect the device via Factory Mode (use Hardware Test Point or "ON/OFF Factory Mode option"). Warning: Selected response: Proceed Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN990_5G_V5... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Writing BL2 partition... Operation in progress. Please wait for instructions... Bootloader Update successfully Rebooting to fastboot mode... Warning: If you use modified USB cable please reconnect cable from the mother board and press "Ok" to proceed the operation Warning: Selected response: Ok Searching Fastboot devices... Found android device: 0123456789ABCDEF Detected Android Sooner Single ADB Interface port Reading basic data... Device Model: ELS-NX9 System: ELS-N29 11.0.0.208(C432E3R6P4) Android Version: 10 Base Version: ELS-LGRP4-OVS 102.0.0.296 Custom Version: ELS-N29-CUST 102.0.0.3(C432) Preload Version: ELS-N29-PRELOAD 102.0.0.5(C432R4) C_Version: C432 D_Version: D000 FB Lock State: LOCKED User Lock State: LOCKED Connecting to the credit server... Username: Default_user Warning: You may use an incompatible operation method for your device. Warning: Recommended method - EMUI11 Checking balance... Your balance: 0 credits Sending device information... Sending firmware information... Removing firmware protection... Connecting to server... Waiting for a response from the server... FB Lock State: UNLOCKED User Lock State: LOCKED Device Model: ELS-NX9 System: ELS-N29 11.0.0.208(C432E3R6P4) MEID: A00000B5472149 IMEI A: 860996043356011 IMEI B: 860996043367307 Writing secure data... Resetting Huawei ID... Reset Huawei ID done. Performed by 1.3.4 Software version. |
The Following User Says Thank You to ercie2 For This Useful Post: |
06-27-2023, 09:38 | #6 (permalink) | |
Member: 180745 Status: Offline Thanks Meter: 12 | Quote:
if i choose emui 12 its works (its say during unlock you choose false emui it will not work) but it finds in fastbootmode and result after process still locked if i choose emui 11 : Job ID: 00000000020CF00D 2023-06-26 18:20:31 Starting Direct Unlock Selected phone model: ELS-NX9 Selected method: Direct Unlock (EMUI12/Harmony) Warning: Please, make sure the phone`s battery is fully charged and connected, after connect the device via Factory Mode (use Hardware Test Point or "ON/OFF Factory Mode option"). Warning: Selected response: Proceed Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN990_5G_V5... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Writing BL2 partition... Operation in progress. Please wait for instructions... Bootloader Update successfully Rebooting to fastboot mode... Warning: If you use modified USB cable please reconnect cable from the mother board and press "Ok" to proceed the operation Warning: Selected response: Ok Searching Fastboot devices... Error: Fastboot devices not found Direct Unlock failed. emui 12 Choose: Job ID: 00000000020CEF37 2023-06-26 18:13:34 Starting Reset Huawei ID Selected phone model: ELS-NX9 Selected method: Reset Huawei Id (EMUI12/Harmony) Warning: Please, make sure the phone`s battery is fully charged and connected, after connect the device via Factory Mode (use Hardware Test Point or "ON/OFF Factory Mode option"). Warning: Selected response: Proceed Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN990_5G_V5... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Writing BL2 partition... Operation in progress. Please wait for instructions... Bootloader Update successfully Rebooting to fastboot mode... Warning: If you use modified USB cable please reconnect cable from the mother board and press "Ok" to proceed the operation Warning: Selected response: Ok Searching Fastboot devices... Found android device: 0123456789ABCDEF Detected Android Sooner Single ADB Interface port Reading basic data... Device Model: ELS-NX9 System: ELS-N29 11.0.0.208(C432E3R6P4) Android Version: 10 Base Version: ELS-LGRP4-OVS 102.0.0.296 Custom Version: ELS-N29-CUST 102.0.0.3(C432) Preload Version: ELS-N29-PRELOAD 102.0.0.5(C432R4) C_Version: C432 D_Version: D000 FB Lock State: LOCKED User Lock State: LOCKED Connecting to the credit server... Username: Default_user Warning: You may use an incompatible operation method for your device. Warning: Recommended method - EMUI11 Checking balance... Your balance: 0 credits Sending device information... Sending firmware information... Removing firmware protection... Connecting to server... Waiting for a response from the server... FB Lock State: UNLOCKED User Lock State: LOCKED Device Model: ELS-NX9 System: ELS-N29 11.0.0.208(C432E3R6P4) MEID: A00000B5472149 IMEI A: 860996043356011 IMEI B: 860996043367307 Writing secure data... Resetting Huawei ID... Reset Huawei ID done. Performed by 1.3.4 Software version. Report Post Reply With Quote Multi-Quote This Message Quick reply to this message The Following User Says Thank You to ercie2 For This Useful Post: Octopus support | |
06-27-2023, 11:14 | #7 (permalink) |
Member: 2891705 Status: Offline Thanks Meter: 2,138 | Please, make sure that Fastboot drivers were installed before, better re-install. Also, what the exact state of device and does device still locked be Huawei ID? |
06-27-2023, 15:50 | #8 (permalink) |
Member: 180745 Status: Offline Thanks Meter: 12 | Thank you for your quick reply. I think that the problem is in the octopus software, I've now tried 2 different pc, same problem with both. when I try to unlock huawei id witch i choose emui 11 (I flashed to emui 11) he writes fastboot and another sections during unlock process and then he tries to boot into fastboot he also gives me an instruction that I should reconnect usb again. exactly then it is no longer recognized by the software then the device! and if I select the emui 12 during unlock prozess (but my device has emui 11) it also writes fastboot and another section there the device is recognized as it should be, also in fastboot etc. the process also ends there is an error message that it Wrong emui is selected and therefore probably not unlocked. The device will not unlock. Please for solution |
