06-13-2020, 10:11 | #1 (permalink) |
Freak Poster Join Date: Nov 2011
Member: 1698387 Status: Offline Thanks Meter: 43 | Eva-l09 flashing error [Answered] Can anyone help me flash this phone? After flashing board firmware phone able to power on boot up to menu but not able to flash in upgrade mode. Tried with 2 firmwares and 2 board firmwares. Pleae help! Thanks Welcome to Octoplus Huawei Software v.1.1.9 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM1 Communications Port 2: COM3 USB Serial Port Selected file: F:/Huawei/EVA-L09/HLEVAAL10M00A085/HLEVAAL10M00A085_Download.xml Selected phone model: EVA-L09 Partial flashing mode was selected! 2020-06-13 08:59:50 GMT ------------------------------------------------- Starting Write Firmware(Board mode) Phone connect successfully Updating bootloader... Writing xloader partition.. Writing fastboot partition.. Boot board firmware files has been written successfully Rebooting to fastboot mode.. Searching Fastboot devices... Device Model: EVA-L09 System: EVA-L09C605B135 IMEI A: 869827029236045 IMEI B: 869827029236045 S/N: MWS7N17213000181 Erasing modemnvm_backup partition.. Erasing modemnvm_factory partition.. Erasing modemnvm_system partition.. Erasing misc partition.. Writing XLOADER partition... Writing PTABLE partition... Writing FASTBOOT partition... Writing DTS partition... Writing FW_LPM3 partition... Writing SENSORHUB partition... Writing FW_HIFI partition... Writing TEEOS partition... Writing RECOVERY partition... Writing CACHE partition... Writing BOOT partition... Writing TRUSTFIRMWARE partition... Writing MODEM partition... Writing MODEM_DTB partition... Writing MODEMNVM_UPDATE partition... Writing MODEM_DSP partition... Writing MODEM_OM partition... Writing MODEMNVM_IMG partition... Writing 3RDMODEM partition... Writing 3RDMODEMNVM partition... Writing 3RDMODEMNVMBKP partition... Erasing USERDATA partition.. Writing USERDATA partition... Writing SYSTEM partition... Writing 1 chunk from 3... Writing 2 chunk from 3... Writing 3 chunk from 3... Erasing OEMINFO partition.. Writing OEMINFO partition... Erasing CUST partition.. Writing CUST partition... Note: After successful reflash the phone in Board Firmware mode, for a correct work of the device, you need to reflash it in Upgrade mode! Write Firmware(Board mode) done. Performed by 1.1.9 Software version. Selected base ptable file: F:/Huawei/EVA-L09/UPDATE.APP PACKAGE_TYPE: ONLINE_UPDATE VERLIST : EVA_Global_5.0 Selected base ptable file: F:/Huawei/EVA-L09/UPDATE_cust.APP PACKAGE_TYPE: ONLINE_UPDATE VERLIST : EVA_Global_5.0 2020-06-13 09:03:51 GMT ------------------------------------------------- Starting Read Info (Fastboot Mode) Searching Fastboot devices... Error: Fastboot devices not found Read Info (Fastboot Mode) failed. Performed by 1.1.9 Software version. Selected phone model: EVA-L09 2020-06-13 09:04:19 GMT ------------------------------------------------- Starting Write Firmware(Upgrade mode) Checking firmware package type Selected writing OTA firmware file! Searching device in Upgrade mode... Error: No devices in Upgarde mode found Write Firmware(Upgrade mode) failed. Performed by 1.1.9 Software version. 2020-06-13 09:04:24 GMT ------------------------------------------------- Starting Read Info (Fastboot Mode) Searching Fastboot devices... Warning: Reading serial number failed Build Number: HLEVAAL10M00A085 Read Info (Fastboot Mode) done. Performed by 1.1.9 Software version. Selected phone model: EVA-L09 2020-06-13 09:06:06 GMT ------------------------------------------------- Starting Write Firmware(Upgrade mode) Checking firmware package type Selected writing OTA firmware file! Searching device in Upgrade mode... Connecting to phone.. Phone connect successfully! Writing firmware partitions... Writing SHA256RSA partition... Writing CRC partition... Writing CURVER partition... Writing VERLIST partition... Writing PACKAGE_TYPE partition... Writing EFI partition... Error: Failed write EFI partition Write Firmware(Upgrade mode) failed. Performed by 1.1.9 Software version. |
06-15-2020, 12:59 | #5 (permalink) |
Member: 1698387 Status: Offline Thanks Meter: 43 | No! First i tried to write firmware in upgrade mode but failed at the beginning. After some try the phone not enter to upgrade mode any more. This is why i tried to write board firmware. |
