10-18-2021, 23:13 | #1 (permalink) |
Freak Poster Join Date: Nov 2017 Location: localhost
Member: 2781773 Status: Offline Thanks Meter: 140 | HLK-AL00 On Factory TP don't work [Solved] 2021-10-18 22:10:38 GMT ------------------------------------------------- Starting ON/OFF Factory Mode Selected phone model: HLK-AL00 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode! Checking the existence of the auto firmware file... Performing ON Factory Mode operation... Initializing remote service connection... Checking firmware package type Searching device in Upgrade mode... Detected DBAdapter Reserved Interface port Connecting to phone.. Phone connect successfully! Writing firmware partitions... Writing SHA256RSA partition... Writing CRC partition... Writing BASE_VERLIST partition... Error: Failed write BASE_VERLIST partition Warning: Switching your device to Factory Mode is not possible! Please, connect your device via Test Point and perform the desired operation. ON/OFF Factory Mode failed. Performed by 1.2.6.1 Software version. Need help |
10-19-2021, 06:58 | #2 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,139 | Hello. Unfortunately, switching your device to Factory Mode is not possible! If you have Harmony OS you need connect your device via Test Point using modify USB cable and then you can perform the desired operation. Last edited by Octopus support; 10-19-2021 at 07:11. |
10-19-2021, 07:26 | #3 (permalink) | |
Member: 2781773 Status: Offline Thanks Meter: 140 | Quote:
Device Model: HLK-AL00 Device Firmware: :HLK-AL00 10.1.0.138(C00E118R8P2) Base Firmware: :HLK-LGRP1-CHN 10.1.0.138 Custom Firmware: :HLK-AL00-CUST 10.1.0.118(C00) Preload Firmware: :HLK-AL00-PRELOAD 10.0.1.2(C00R8) | |
10-21-2021, 21:37 | #5 (permalink) |
Member: 2781773 Status: Offline Thanks Meter: 140 | To hardware TP use modify USB cable (10 kOm) when all the partitions are flashed and the tool shows Searching Fastboot devices... then need disconnect the resistance at the same time which will go into mobile fastboot mode |
The Following User Says Thank You to UM4 For This Useful Post: |
