Honor 30 I can't remove huawei id [Answered] Honor 30 I can't remove huawei id Job ID: 00000000018FB89E 2023-03-19 05:44:38 Starting Reset Huawei ID Selected phone model: BMH-AN10 Selected method: Reset Huawei Id (EMUI 11) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN820_985_V3... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Writing BL2 partition... Operation in progress. Please wait for instructions... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: QLV0220504000041 Detected Android Sooner Single ADB Interface port Reading basic data... Device Model: BMH-AN10 System: BMH-N19 4.0.0.172(C10E3R4P3) Android Version: 10 Base Version: BMH-LGRP2-OVS 11.0.0.169 Custom Version: BMH-N19-CUST 11.0.0.3(C10) Preload Version: BMH-N19-PRELOAD 11.0.0.3(C10R2) C_Version: C10 D_Version: D000 FB Lock State: LOCKED User Lock State: LOCKED Downloading resource... Connecting to the credit server... Username: Default_user Checking balance... Your balance: 0 credits Sending device information... Sending firmware information... Error: Bootloader check failed. Connect your phone via Factory mode and perform the operation again. Reset Huawei ID failed. Performed by 1.3.3 Software version |
Hello Did you connect device using TP? Or did you use ON/OFF factory mode? |
I connect using TP |
Try to perform operation once again. Also, make sure that battery is connected |
