05-02-2024, 12:00 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: djerba
Member: 1269161 Status: Offline Thanks Meter: 119 | how unlock this frp [Answered] i need to unlock frp in jny-lx1 System: JNY-L21 12.0.0.220(C185E4R4P2) Code: Job ID: 00000000018E4C4F 2024-05-02 10:15:21 Starting Reset FRP Selected phone model: JNY-LX1 Selected method: Reset Frp (EMUI12/Harmony) Warning: Please, make sure the phone`s battery is fully charged and connected, after connect the device via Factory Mode (use Hardware Test Point or "ON/OFF Factory Mode option"). Warning: Selected response: Proceed Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN810_V3... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Operation in progress. Please wait for instructions... Bootloader Update successfully Rebooting to fastboot mode... Warning: If you use modified USB cable please reconnect cable from the mother board and press "Ok" to proceed the operation Warning: Selected response: Ok Searching Fastboot devices... Found android device: UT7VMG2088020707 Detected Android Sooner Single ADB Interface port Reading basic data... Device Model: JNY-LX1 System: JNY-L21 12.0.0.220(C185E4R4P2) Android Version: 10 Base Version: JNY-LGRP2-OVS 102.0.0.220 Custom Version: JNY-L21-CUST 102.0.0.4(C185) Preload Version: JNY-L21-PRELOAD 102.0.0.2(C185R4) C_Version: C185 D_Version: D000 FB Lock State: LOCKED User Lock State: LOCKED Connecting to the credit server... Username: Default_user Checking balance... Your balance: 1 credits Sending device information... Sending firmware information... Removing firmware protection... Reset FRP failed. Performed by 1.3.4 Software version. thx |
05-04-2024, 13:35 | #4 (permalink) |
Member: 1269161 Status: Offline Thanks Meter: 119 | another phone with failed process !!! any problem !!!?? failed huawei id remove Code: Welcome to Octoplus Huawei Software v.1.3.4 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM1 Port de communication 2: COM3 Intel(R) Active Management Technology - SOL 3: COM44 USB Serial Port 4: COM11 RIM Virtual Serial Port v2 5: COM12 RIM Virtual Serial Port v2 6: COM39 USB Serial Port Job ID: 0000000001E48EAA 2024-05-04 12:23:52 Starting Read Info Selected phone model: PPA-LX2 Searching Fastboot devices... Found android device: CNXNU20C07210504 Detected Android Sooner Single ADB Interface port Reading basic data... Device Model: PPAH-L22 System: PPAH-L22 10.1.1.277(C185E8R3P1) Android Version: 10 Base Version: PPAH-LGRP2-OVS 10.1.1.277 Custom Version: PPAH-L22-CUST 10.1.1.8(C185) Preload Version: PPAH-L22-PRELOAD 10.1.1.1(C185R3) C_Version: C185 D_Version: D000 Read Info done. Performed by 1.3.4 Software version. Job ID: 00000000018E715D 2024-05-04 12:24:15 Starting Reset Huawei ID Selected phone model: PPA-LX2 Warning: Please, make sure the phone`s battery is fully charged and connected, after connect the device via Factory Mode (use Hardware Test Point or "ON/OFF Factory Mode option"). Warning: Selected response: Proceed Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN710A_V3... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Operation in progress. Please wait for instructions... Bootloader Update successfully Rebooting to fastboot mode... Warning: If you use modified USB cable please reconnect cable from the mother board and press "Ok" to proceed the operation Warning: Selected response: Ok Searching Fastboot devices... Found android device: CNXNU20C07210504 Detected Android Sooner Single ADB Interface port Reading basic data... Device Model: PPA-LX2 System: PPAH-L22 10.1.1.277(C185E8R3P1) Android Version: 10 Base Version: PPAH-LGRP2-OVS 10.1.1.277 Custom Version: PPAH-L22-CUST 10.1.1.8(C185) Preload Version: PPAH-L22-PRELOAD 10.1.1.1(C185R3) C_Version: C185 D_Version: D000 FB Lock State: LOCKED User Lock State: LOCKED Connecting to the credit server... Username: Default_user Checking balance... Your balance: 1 credits Sending device information... Sending firmware information... Removing firmware protection... Reset Huawei ID failed. Performed by 1.3.4 Software version. |
