01-26-2021, 15:45 | #1 (permalink) |
No Life Poster Join Date: Jan 2012 Location: YOUR HEART
Member: 1712884 Status: Offline Thanks Meter: 857 | huawei aum-l29 unknown device [Answered] Code: 2021-01-26 08:54:53.876 Loading application settings 2021-01-26 08:54:53.892 Refreshing serial ports list 2021-01-26 08:54:54.039 Found COM ports: 2021-01-26 08:54:54.039 1: COM1 Communications Port 2021-01-26 08:54:54.226 Welcome to Octoplus Huawei Software v.1.2.3 2021-01-26 08:54:54.226 2021-01-26 08:54:54.226 To enable 'Manufacture' mode dial 2021-01-26 08:54:54.227 - for Qualcomm and Hisilicon based models: *#*#2846579#*#* 2021-01-26 08:54:54.227 ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode 2021-01-26 08:54:54.227 - for MTK based models: *#*#14789632#*#* 2021-01-26 08:54:54.228 ProjectMenu > Background Settings > USB Port Settings > Debug Mode 2021-01-26 08:54:54.228 2021-01-26 08:54:54.228 To enable 'Fastboot' mode 2021-01-26 08:54:54.228 1. Power off the phone. Remove SD and SIM cards 2021-01-26 08:54:54.228 2. Press 'Vol-' and insert USB cable 2021-01-26 08:54:54.228 3. Wait until phone enters 'Fastboot' mode 2021-01-26 08:54:54.228 2021-01-26 08:54:54.228 To enable 'Upgrade' mode 2021-01-26 08:54:54.229 1. Power off the phone. Remove SD and SIM cards 2021-01-26 08:54:54.229 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 2021-01-26 08:54:54.229 3. Wait until phone enters 'Upgrade mode' 2021-01-26 08:54:54.319 Refreshing serial ports list 2021-01-26 08:54:54.411 Found COM ports: 2021-01-26 08:54:54.411 1: COM1 Communications Port 2021-01-26 08:54:54.486 Init finished 2021-01-26 08:55:20.860 Selected download file: D:/Software/AUM-AL20-BD_1.0.0.50_Download.xml 2021-01-26 08:55:26.258 Selected firehose file: D:/Software/bootloaderimage/prog_emmc_firehose.mbn 2021-01-26 08:55:28.731 Selected phone model: AUM-L29 2021-01-26 08:55:29.845 Full flashing mode was selected! 2021-01-26 08:55:30.008 Connected to log server. 2021-01-26 08:55:31.324 Job ID: 00000000007B46FD 2021-01-26 08:55:31.616 2021-01-26 08:55:31 GMT ------------------------------------------------- 2021-01-26 08:55:31.766 Starting Write Firmware(Board mode) 2021-01-26 08:55:31.939 Please, before firmware write, disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Android-based devices). Dont run any other programs or attach new devices to your computer during the flashing procedure! Don?t turn off phone and don?t disconnect cable during firmware write. Please, follow these simple instructions to avoid phone damage 2021-01-26 08:55:32.085 Connecting to phone.. 2021-01-26 08:55:32.231 Please, reconnect battery, connect USB cable with attached Test Point on your phone! 2021-01-26 08:55:38.639 Sending loader prog_emmc_firehose.mbn... 2021-01-26 08:55:47.271 Loader send successfully 2021-01-26 08:55:47.425 Reconnecting, please wait.. 2021-01-26 08:56:04.361 Xml file open failed. 2021-01-26 08:56:04.502 2021-01-26 08:56:04.658 Write Firmware(Board mode) failed. 2021-01-26 08:56:04.799 Performed by 1.2.3 Software version. 2021-01-26 08:56:35.182 Selected rawprogram file: D:/Software/bootloaderimage/rawprogram0.xml 2021-01-26 08:56:37.492 Selected patch file: D:/Software/bootloaderimage/patch0.xml 2021-01-26 08:56:48.087 Selected phone model: AUM-L29 2021-01-26 08:56:49.931 Full flashing mode was selected! 2021-01-26 08:56:50.102 Connected to log server. 2021-01-26 08:56:51.587 Job ID: 00000000007B478C 2021-01-26 08:56:51.884 2021-01-26 08:56:51 GMT ------------------------------------------------- 2021-01-26 08:56:52.056 Starting Write Firmware(Board mode) 2021-01-26 08:56:52.212 Please, before firmware write, disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Android-based devices). Dont run any other programs or attach new devices to your computer during the flashing procedure! Don?t turn off phone and don?t disconnect cable during firmware write. Please, follow these simple instructions to avoid phone damage 2021-01-26 08:56:52.384 Connecting to phone.. 2021-01-26 08:56:52.541 Please, reconnect battery, connect USB cable with attached Test Point on your phone! 2021-01-26 08:57:24.548 Sending loader prog_emmc_firehose.mbn... 2021-01-26 08:57:33.236 Loader send successfully 2021-01-26 08:57:33.392 Reconnecting, please wait.. 2021-01-26 08:57:50.314 Writing. Please wait... 2021-01-26 08:57:50.476 Writing SBL1 partition... 2021-01-26 08:57:50.963 Writing RPM partition... 2021-01-26 08:57:51.369 Writing TZ partition... 2021-01-26 08:57:53.065 Writing DEVCFG partition... 2021-01-26 08:57:53.346 Writing EMMC_APPSBOOT partition... 2021-01-26 08:57:56.753 Writing CMNLIB partition... 2021-01-26 08:57:57.191 Writing CMNLIB64 partition... 2021-01-26 08:57:57.675 Writing KEYMASTER partition... 2021-01-26 08:57:58.160 Writing ADSPSO partition... 2021-01-26 08:58:15.925 Writing GPT_MAIN0 partition... 2021-01-26 08:58:16.175 Writing GPT_BACKUP0 partition... 2021-01-26 08:58:16.425 Patching. Please wait... 2021-01-26 08:58:17.833 Patch done successfully 2021-01-26 08:58:20.073 Searching Fastboot devices... 2021-01-26 08:58:24.204 Total interfaces: 1 2021-01-26 08:58:24.354 Interface 0 : flags: 1, name(79): \\?\usb#vid_18d1&pid_d00d#7&371cf733&0&4#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} 2021-01-26 08:58:24.504 Found a fastboot device: c3621c5d 2021-01-26 08:58:24.674 Reading product model failed 2021-01-26 08:58:29.474 oem get-build-number failed 2021-01-26 08:58:31.694 Writing PARTITION partition... 2021-01-26 08:58:33.147 Writing RPM partition... 2021-01-26 08:58:34.607 Writing TZ partition... 2021-01-26 08:58:36.100 Writing ABOOT partition... 2021-01-26 08:58:37.658 Writing RAMDISK partition... 2021-01-26 08:58:39.470 Writing KERNEL partition... 2021-01-26 08:58:43.429 Writing RECOVERY_RAMDISK partition... 2021-01-26 08:58:45.921 Writing RECOVERY_VENDOR partition... 2021-01-26 08:58:47.465 Writing ERECOVERY_KERNEL partition... 2021-01-26 08:58:51.620 Writing ERECOVERY_RAMDISK partition... 2021-01-26 08:58:54.806 Writing ERECOVERY_VENDOR partition... 2021-01-26 08:58:56.338 Writing MODEM partition... 2021-01-26 08:59:05.362 Writing SYSTEM partition... 2021-01-26 08:59:39.305 Writing 1 chunk from 3... 2021-01-26 09:00:37.446 Writing 2 chunk from 3... 2021-01-26 09:01:31.684 Writing 3 chunk from 3... 2021-01-26 09:02:01.642 Writing USERDATA partition... 2021-01-26 09:02:15.514 Writing PERSIST partition... 2021-01-26 09:02:17.178 Writing CACHE partition... 2021-01-26 09:02:18.898 Writing DSP partition... 2021-01-26 09:02:21.701 Writing CMNLIB partition... 2021-01-26 09:02:23.169 Writing CMNLIB64 partition... 2021-01-26 09:02:24.629 Writing DEVCFG partition... 2021-01-26 09:02:26.068 Writing KEYMASTER partition... 2021-01-26 09:02:27.523 Writing OEMINFO partition... 2021-01-26 09:02:33.698 Writing LKSECAPP partition... 2021-01-26 09:02:35.147 Writing APDP partition... 2021-01-26 09:02:36.599 Writing MSADP partition... 2021-01-26 09:02:38.022 Writing FSG partition... 2021-01-26 09:02:39.530 Writing MODEMST1 partition... 2021-01-26 09:02:41.230 Writing MODEMST2 partition... 2021-01-26 09:02:42.836 Writing LOG partition... 2021-01-26 09:02:50.038 Writing PRODUCT partition... 2021-01-26 09:03:01.322 Writing VENDOR partition... 2021-01-26 09:03:10.840 Writing 1 chunk from 2... 2021-01-26 09:04:05.353 Writing 2 chunk from 2... 2021-01-26 09:04:08.763 Writing VERSION partition... 2021-01-26 09:04:10.501 Writing ODM partition... 2021-01-26 09:04:12.878 Writing SBL1 partition... 2021-01-26 09:04:14.339 Writing SEC partition... 2021-01-26 09:04:15.768 Note: After successful reflash the phone in Board Firmware mode, for a correct work of the device, you need to reflash it in Upgrade mode! 2021-01-26 09:04:15.979 2021-01-26 09:04:16.142 Write Firmware(Board mode) done. 2021-01-26 09:04:16.303 Performed by 1.2.3 Software version. Code: 2021-01-26 09:34:54.780 Selected base ptable file: C:/dload/UPDATE.APP 2021-01-26 09:34:54.796 PACKAGE_TYPE: OFFLINE_UPDATE 2021-01-26 09:34:54.796 AMSS_VERLIST : AUM-L29 8.0.0.140(C900) 2021-01-26 09:34:58.510 Selected base ptable file: C:/dload/AUM-L29_hw_meafnaf/update_AUM-L29_hw_meafnaf.app 2021-01-26 09:34:58.510 PACKAGE_TYPE: OFFLINE_UPDATE 2021-01-26 09:34:58.510 AMSS_VERLIST : AUM-L29 8.0.0.140(C900) 2021-01-26 09:35:00.646 Selected phone model: AUM-L29 2021-01-26 09:35:00.866 Connected to log server. 2021-01-26 09:35:02.309 Job ID: 00000000007B55B4 2021-01-26 09:35:02.613 2021-01-26 09:35:02 GMT ------------------------------------------------- 2021-01-26 09:35:02.785 Starting Write Firmware(Fastboot mode) 2021-01-26 09:35:02.941 Searching Fastboot devices... 2021-01-26 09:35:04.995 Total interfaces: 1 2021-01-26 09:35:05.136 Interface 0 : flags: 1, name(79): \\?\usb#vid_18d1&pid_d00d#7&371cf733&0&4#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} 2021-01-26 09:35:05.292 Found a fastboot device: c3621c5d 2021-01-26 09:35:12.677 System: AUM-AL20-BD 1.0.0.50(log) 2021-01-26 09:35:13.512 Writing RPM partition... 2021-01-26 09:35:13.747 Writing RPM partition failed 2021-01-26 09:35:14.171 Connecting to server... 2021-01-26 09:35:15.212 FRP unlock 0 2021-01-26 09:35:36.679 Writing sign buf data 2021-01-26 09:35:40.487 FRP unlock 1 2021-01-26 09:36:00.968 Writing sign buf data 2021-01-26 09:36:04.774 FRP unlock 2 2021-01-26 09:36:21.755 Writing sign buf data 2021-01-26 09:36:25.563 FRP unlock 3 2021-01-26 09:36:43.537 Writing sign buf data 2021-01-26 09:36:48.141 Writing RPM partition... 2021-01-26 09:36:48.305 Cannot open file 2021-01-26 09:36:48.467 Writing RPM partition failed 2021-01-26 09:36:48.635 Writing TZ partition... 2021-01-26 09:36:49.852 Writing SBL1 partition... 2021-01-26 09:36:51.321 Writing APDP partition... 2021-01-26 09:36:52.744 Writing MSADP partition... 2021-01-26 09:36:54.743 Writing MODEM partition... 2021-01-26 09:37:00.478 Writing DSP partition... 2021-01-26 09:37:02.463 Writing CMNLIB partition... 2021-01-26 09:37:03.909 Writing KEYMASTER partition... 2021-01-26 09:37:05.365 Writing CMNLIB64 partition... 2021-01-26 09:37:06.840 Writing DEVCFG partition... 2021-01-26 09:37:08.271 Writing LKSECAPP partition... 2021-01-26 09:37:09.719 Writing ABOOT partition... 2021-01-26 09:37:11.523 Writing KERNEL partition... 2021-01-26 09:37:14.882 Writing RAMDISK partition... 2021-01-26 09:37:16.867 Writing RECOVERY_RAMDISK partition... 2021-01-26 09:37:19.446 Writing RECOVERY_VENDOR partition... 2021-01-26 09:37:21.277 Writing ERECOVERY_KERNEL partition... 2021-01-26 09:37:24.762 Writing ERECOVERY_RAMDISK partition... 2021-01-26 09:37:27.372 Writing ERECOVERY_VENDOR partition... 2021-01-26 09:38:13.069 Writing SYSTEM partition... 2021-01-26 09:39:03.726 Writing 1 chunk from 6... 2021-01-26 09:39:36.771 Writing 2 chunk from 6... 2021-01-26 09:40:07.247 Writing 3 chunk from 6... 2021-01-26 09:40:38.361 Writing 4 chunk from 6... 2021-01-26 09:41:08.013 Writing 5 chunk from 6... 2021-01-26 09:41:33.304 Writing 6 chunk from 6... 2021-01-26 09:41:37.378 Writing CACHE partition... 2021-01-26 09:41:39.131 Writing ODM partition... 2021-01-26 09:41:48.195 Writing VENDOR partition... 2021-01-26 09:41:52.024 Writing 1 chunk from 2... 2021-01-26 09:42:19.146 Writing 2 chunk from 2... 2021-01-26 09:42:21.341 Erasing USERDATA partition.. 2021-01-26 09:42:21.935 Writing USERDATA partition... 2021-01-26 09:42:24.216 2021-01-26 09:42:26.154 Writing CUST partition... 2021-01-26 09:42:37.116 Writing VERSION partition... 2021-01-26 09:42:39.114 Erasing USERDATA partition.. 2021-01-26 09:42:49.991 Writing USERDATA partition... 2021-01-26 09:42:53.086 Writing 1 chunk from 2... 2021-01-26 09:43:17.738 Writing 2 chunk from 2... 2021-01-26 09:43:29.312 2021-01-26 09:43:37.133 Please, select update.app file in the firmware folder and repeat the operation! 2021-01-26 09:43:37.336 Rebooting device... 2021-01-26 09:43:37.539 2021-01-26 09:43:37.695 Write Firmware(Fastboot mode) done. 2021-01-26 09:43:37.867 Performed by 1.2.3 Software version. 2021-01-26 09:44:00.041 Selected base file: C:/dload/UPDATE.APP 2021-01-26 09:44:00.156 PACKAGE_TYPE: OFFLINE_UPDATE 2021-01-26 09:44:00.172 AMSS_VERLIST : AUM-L29 8.0.0.140(C900) Code: 2021-01-26 10:32:00.691 Loading application settings 2021-01-26 10:32:00.738 Refreshing serial ports list 2021-01-26 10:32:00.954 Found COM ports: 2021-01-26 10:32:00.954 1: COM63 HUAWEI Mobile Connect - Fake Acm Interface 2021-01-26 10:32:00.954 2: COM1 Communications Port 2021-01-26 10:32:00.954 3: COM62 Android Adapter PCUI 2021-01-26 10:32:00.954 4: COM64 DBAdapter Reserved Interface 2021-01-26 10:32:01.052 Welcome to Octoplus Huawei Software v.1.2.3 2021-01-26 10:32:01.052 2021-01-26 10:32:01.052 To enable 'Manufacture' mode dial 2021-01-26 10:32:01.052 - for Qualcomm and Hisilicon based models: *#*#2846579#*#* 2021-01-26 10:32:01.052 ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode 2021-01-26 10:32:01.052 - for MTK based models: *#*#14789632#*#* 2021-01-26 10:32:01.052 ProjectMenu > Background Settings > USB Port Settings > Debug Mode 2021-01-26 10:32:01.052 2021-01-26 10:32:01.052 To enable 'Fastboot' mode 2021-01-26 10:32:01.052 1. Power off the phone. Remove SD and SIM cards 2021-01-26 10:32:01.052 2. Press 'Vol-' and insert USB cable 2021-01-26 10:32:01.052 3. Wait until phone enters 'Fastboot' mode 2021-01-26 10:32:01.052 2021-01-26 10:32:01.052 To enable 'Upgrade' mode 2021-01-26 10:32:01.052 1. Power off the phone. Remove SD and SIM cards 2021-01-26 10:32:01.052 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 2021-01-26 10:32:01.052 3. Wait until phone enters 'Upgrade mode' 2021-01-26 10:32:01.118 Refreshing serial ports list 2021-01-26 10:32:01.248 Found COM ports: 2021-01-26 10:32:01.248 1: COM63 HUAWEI Mobile Connect - Fake Acm Interface 2021-01-26 10:32:01.248 2: COM1 Communications Port 2021-01-26 10:32:01.248 3: COM62 Android Adapter PCUI 2021-01-26 10:32:01.248 4: COM64 DBAdapter Reserved Interface 2021-01-26 10:32:01.279 Init finished 2021-01-26 10:32:10.178 Connected to log server. 2021-01-26 10:32:11.585 Job ID: 00000000007B6BB2 2021-01-26 10:32:11.897 2021-01-26 10:32:11 GMT ------------------------------------------------- 2021-01-26 10:32:12.056 Starting Connect 2021-01-26 10:32:12.214 Selected phone model: AUM-L29 2021-01-26 10:32:12.899 Connecting to server... 2021-01-26 10:32:13.956 Check auth 0 2021-01-26 10:32:15.687 Authorization is successful 2021-01-26 10:32:16.291 Device Model: ATU-L29 2021-01-26 10:32:16.451 Boot: Chipset-msm8917 8.0.0.33(03YV)_SBL1 2021-01-26 10:32:16.607 System: System 8.0.0.073(092U) 2021-01-26 10:32:16.768 MEID: 00000000000000 2021-01-26 10:32:16.931 PESN: 00000000 2021-01-26 10:32:17.092 IMEI A: 000000000000000 2021-01-26 10:32:17.255 Bluetooth MAC: 00:00:00:00:00:00 2021-01-26 10:32:17.418 WiFi MAC: 00:00:00:00:00:00 2021-01-26 10:32:17.576 2021-01-26 10:32:17.740 Connect done. 2021-01-26 10:32:17.901 Performed by 1.2.3 Software version. 2021-01-26 10:35:07.215 Connected to log server. 2021-01-26 10:35:08.626 Job ID: 00000000007B6CC5 2021-01-26 10:35:08.938 2021-01-26 10:35:08 GMT ------------------------------------------------- 2021-01-26 10:35:09.102 Starting Repair Info 2021-01-26 10:35:09.266 New Product Name: ATU-L29 2021-01-26 10:35:09.422 New IMEI A: 2021-01-26 10:35:09.578 New IMEI B: 2021-01-26 10:35:09.734 New Bluetooth MAC: 7459095C03F6 2021-01-26 10:35:09.897 New WI-Fi Mac: 7459095C000D 2021-01-26 10:35:10.069 New S/N: 58K6R19801010682 2021-01-26 10:35:10.226 New Board S/N: 58K6R19801010682 2021-01-26 10:35:10.387 New Vendor Code: hw 2021-01-26 10:35:10.559 New Country Code: meafnaf 2021-01-26 10:35:10.715 New SIM Card Mode: double 2021-01-26 10:35:10.887 Repairing Product Name... 2021-01-26 10:35:11.043 Repairing BSN... 2021-01-26 10:35:11.199 Repairing SN... 2021-01-26 10:35:11.370 Repairing IMEI A... 2021-01-26 10:35:11.527 Private enc 0 2021-01-26 10:35:11.685 Repairing Bluetooth MAC... 2021-01-26 10:35:11.843 Private enc 0 2021-01-26 10:35:12.250 Repairing WiFi MAC... 2021-01-26 10:35:12.407 Private enc 0 2021-01-26 10:35:13.826 Repairing IMEI B... 2021-01-26 10:35:13.992 Private enc 0 2021-01-26 10:35:15.539 Repairing Vendor/Country... 2021-01-26 10:35:15.708 Private enc 0 2021-01-26 10:35:16.144 Private enc 0 2021-01-26 10:35:17.370 Enabling software downgrade... 2021-01-26 10:35:17.535 Repairing Sim Card Mode... 2021-01-26 10:35:17.692 Private enc 0 2021-01-26 10:35:18.614 Resetting your device 2021-01-26 10:35:18.781 2021-01-26 10:35:18.947 Repair Info done. 2021-01-26 10:35:19.113 Performed by 1.2.3 Software version. Code: 2021-01-26 13:32:53.397 Starting Connect 2021-01-26 13:32:53.587 Selected phone model: AUM-L29 2021-01-26 13:32:54.305 Connecting to server... 2021-01-26 13:32:55.274 Check auth 0 2021-01-26 13:32:56.255 Authorization is successful 2021-01-26 13:32:56.860 Device Model: ATU-L29 2021-01-26 13:32:57.044 Boot: Chipset-msm8917 8.0.0.33(03YV)_SBL1 2021-01-26 13:32:57.215 System: System 8.0.0.073(092U) 2021-01-26 13:32:57.404 MEID: 00000000000000 2021-01-26 13:32:57.577 PESN: 00000000 2021-01-26 13:32:57.764 IMEI A: 8600 2021-01-26 13:32:57.936 IMEI B: 8600 2021-01-26 13:32:58.124 Bluetooth MAC: 74:59:09:5C:03:F6 2021-01-26 13:32:58.304 WiFi MAC: 74:59:09:5C:00:0D 2021-01-26 13:32:58.477 S/N: 58K6R19801010682 2021-01-26 13:32:58.657 Board S/N: 58K6R19801010682 2021-01-26 13:32:58.834 Vendor Code: hw 2021-01-26 13:32:59.007 Country Code: meafnaf 2021-01-26 13:32:59.180 2021-01-26 13:32:59.352 Connect done. 2021-01-26 13:32:59.543 Performed by 1.2.3 Software version. The initial problem with the phone was boot failure and shutdown After the operation, the phone turned on and works well, but the themes are not available and the anonymous phone model is displayed Even the phone was flashed with a memory card, but there are still problems And the wrong device version is displayed |
01-26-2021, 16:45 | #2 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Online Thanks Meter: 2,141 | Hello. Please do the next steps: 1. Write stock firmware in upgrade mode. 2. Do Repair Product name as indicated in the cust file of the stock firmware. 3. Post here results. Also, what is your phone mode exactly? |
The Following User Says Thank You to Octopus support For This Useful Post: |
01-26-2021, 17:05 | #3 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | device name huwai device model unknown My File Name AUM-L29_8.0.0.155 (C185CUSTC185D1) -id12365.zip after extract Atomu-L29A 8.0.0.155(C185CUSTC185D1)_Firmware_EMUI8.0_05015CD V |
01-27-2021, 16:30 | #4 (permalink) |
Member: 2891705 Status: Online Thanks Meter: 2,141 | Hello. Please do the next steps: 1. Write stock firmware in upgrade mode. 2. Do Repair Product name as indicated in the cust file of the stock firmware. 3. Post here results. |
