salim5566 | 01-08-2019 22:23 | Quote:
Originally Posted by Octopus box
(Post 13496996)
Hello.
What is the firmware version in your device now exaxtly? Please put the device into Fastboot mode and perform "Read info" operation. Then post here full Software lo with this info, we will check it. Also write here, what firmware do You try to write. | here is the info Code:
2019-01-07 23:21:42.559 Loading application settings
2019-01-07 23:21:42.559 Refreshing serial ports list
2019-01-07 23:21:42.777 Found COM ports:
2019-01-07 23:21:42.777 1: COM5 USB Serial Port
2019-01-07 23:21:42.824 Welcome to Octoplus Huawei Software v.1.0.5
2019-01-07 23:21:42.840
2019-01-07 23:21:42.840 To enable 'Manufacture' mode dial
2019-01-07 23:21:42.840 - for Qualcomm and Hisilicon based models: *#*#2846579#*#*
2019-01-07 23:21:42.840 ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode
2019-01-07 23:21:42.840 To enable 'Fastboot' mode
2019-01-07 23:21:42.840 1. Power off the phone. Remove SD and SIM cards
2019-01-07 23:21:42.840 2. Press 'Vol-' and insert USB cable
2019-01-07 23:21:42.840 3. Wait until phone enters 'Fastboot' mode
2019-01-07 23:21:42.840 To enable 'Upgrade' mode
2019-01-07 23:21:42.840 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable
2019-01-07 23:21:42.840 3. Wait until phone enters 'Upgrade mode'
2019-01-07 23:21:42.965 Init finished
2019-01-07 23:21:55.278 2019-01-07 23:21:55 GMT -------------------------------------------------
2019-01-07 23:21:55.278 Starting Read Info (Fastboot Mode)
2019-01-07 23:21:55.294 Searching connected Fastboot devices...
2019-01-07 23:21:56.341 Total interfaces: 1
2019-01-07 23:21:56.341 Interface 0 : flags: 1, name(81): \\?\usb#vid_18d1&pid_d00d#h3z4c15604000504#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b}
2019-01-07 23:21:57.575 S/N: H3Z4C15604000504
2019-01-07 23:21:57.575 Build Number: CHM-UL00 V100R001C00B140 i have download same flash file but when i m trying to flash with huawei octopus tool dose not work, even when i go to advance mode try to flash can not flash,but when i use minimal adb and fastboot and flash recover,boot,and system phone works fine,just to let u know fastboot flash did not work.
here fast boot flashing log, it cud not flash at all just log show flashing done Code:
2019-01-08 03:39:34.157 Starting Write Firmware
2019-01-08 03:39:34.157 Searching connected Fastboot devices...
2019-01-08 03:39:35.175 Total interfaces: 1
2019-01-08 03:39:35.175 Interface 0 : flags: 1, name(81): \\?\usb#vid_18d1&pid_d00d#h3z4c15604000504#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b}
2019-01-08 03:39:35.998 S/N: H3Z4C15604000504
2019-01-08 03:39:36.404 Extracting firmware partitions...
2019-01-08 03:39:40.154 partition has been extracted successfully
2019-01-08 03:39:40.154 Checking firmware compatibility
2019-01-08 03:39:40.779 Failed to read initial Reset FRP data
2019-01-08 03:39:40.982 Failed to read initial Reset FRP data
2019-01-08 03:39:41.185 Failed to read initial Reset FRP data
2019-01-08 03:39:41.389 Failed to read initial Reset FRP data
2019-01-08 03:39:41.592 Failed to read initial Reset FRP data
2019-01-08 03:39:41.592 Write Firmware done.
2019-01-08 03:39:41.592 Performed by 1.0.5 Software version. |
