03-24-2023, 04:55 | #1 (permalink) |
No Life Poster Join Date: Jul 2013 Location: Pakistan. Rahim Yar Khan
Member: 1977629 Status: Offline Thanks Meter: 429 | Art-l29 Fastboot issue [Answered] 2023-03-24 02:56:49 Starting Read Info Selected phone model: ART-AL00X Searching Fastboot devices... Found android device: DUJ6R20624012362 Detected Android Sooner Single ADB Interface port Reading basic data... Device Model: ARTH-L29 System: ARTH-L29 10.1.0.191(C185E2R3P1) Android Version: 10 Base Version: ART-LGRP2-OVS 10.1.0.191 Custom Version: ARTH-L29-CUST 10.1.0.2(C185) Preload Version: ARTH-L29-PRELOAD 10.1.0.1(C185R3) C_Version: C185 D_Version: D000 Read Info done. Performed by 1.3.3 Software version. |
03-24-2023, 08:45 | #3 (permalink) |
Member: 1977629 Status: Offline Thanks Meter: 429 | This mobile come from other shop now this mobile go only fastboot not power on not go upgrade not recovery just fastboot mode only i flah many firmware but not success any solution for this problem please help me |
03-25-2023, 06:31 | #4 (permalink) |
Member: 1977629 Status: Offline Thanks Meter: 429 | update faild in Upgrade mode 2023-03-25 05:08:33.459 Loading application settings 2023-03-25 05:08:33.522 Refreshing serial ports list 2023-03-25 05:08:33.537 Found COM ports: 2023-03-25 05:08:33.537 1: COM1 Communications Port 2023-03-25 05:08:33.537 2: COM2 Communications Port 2023-03-25 05:08:34.584 Welcome to Octoplus Huawei Software v.1.3.3 2023-03-25 05:08:34.584 2023-03-25 05:08:34.584 To enable 'Manufacture' mode dial 2023-03-25 05:08:34.584 - for Qualcomm and Hisilicon based models: *#*#2846579#*#* 2023-03-25 05:08:34.584 ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode 2023-03-25 05:08:34.584 - for MTK based models: *#*#14789632#*#* 2023-03-25 05:08:34.584 ProjectMenu > Background Settings > USB Port Settings > Debug Mode 2023-03-25 05:08:34.584 2023-03-25 05:08:34.584 To enable 'Fastboot' mode 2023-03-25 05:08:34.584 1. Power off the phone. Remove SD and SIM cards 2023-03-25 05:08:34.584 2. Press 'Vol-' and insert USB cable 2023-03-25 05:08:34.584 3. Wait until phone enters 'Fastboot' mode 2023-03-25 05:08:34.584 2023-03-25 05:08:34.584 To enable 'Upgrade' mode 2023-03-25 05:08:34.584 1. Power off the phone. Remove SD and SIM cards 2023-03-25 05:08:34.600 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 2023-03-25 05:08:34.600 3. Wait until phone enters 'Upgrade mode' 2023-03-25 05:08:36.491 Refreshing serial ports list 2023-03-25 05:08:36.491 Found COM ports: 2023-03-25 05:08:36.491 1: COM1 Communications Port 2023-03-25 05:08:36.491 2: COM2 Communications Port 2023-03-25 05:08:36.647 Init finished 2023-03-25 05:09:04.161 Job ID: 000000000192CEBC 2023-03-25 05:09:04.849 2023-03-25 05:09:04 2023-03-25 05:09:04.849 Starting Write Firmware(Fastboot mode) 2023-03-25 05:09:04.880 Selected phone model: ART-AL00X 2023-03-25 05:09:08.665 Selected cust ptable file: F:/Pak/Huawei/ART-L29/Software/dload/update_sd_base/UPDATE.APP 2023-03-25 05:09:10.058 PACKAGE_TYPE: OFFLINE_UPDATE 2023-03-25 05:09:17.624 Searching Fastboot devices... 2023-03-25 05:09:19.659 Total interfaces: 1 2023-03-25 05:09:19.659 Interface 0 : flags: 1, name(81): \\?\usb#vid_18d1&pid_d00d#duj6r20624012362#{f72fe0 d4-cbcb-407d-8814-9ed673d0dd6b} 2023-03-25 05:09:19.660 Found android device: DUJ6R20624012362 2023-03-25 05:09:19.672 Reading product model 2023-03-25 05:09:21.655 Reading build number 2023-03-25 05:09:23.655 Device Model: ART-L29 2023-03-25 05:09:23.669 System: ARTH-L29 10.1.0.191(C185E2R3P1) 2023-03-25 05:09:23.681 Reading build number 2023-03-25 05:09:23.684 Response contains FAIL! 2023-03-25 05:09:23.687 Removing firmware protection... 2023-03-25 05:09:24.175 Connecting to server... 2023-03-25 05:09:25.329 Private enc 0 2023-03-25 05:09:25.620 Fail Private enc 0: Wrong packet received 2023-03-25 05:09:25.621 Data encryption failed 2023-03-25 05:09:25.635 Write Firmware(Fastboot mode) failed. 2023-03-25 05:09:25.648 Performed by 1.3.3 Software version. 2023-03-25 05:09:36.482 Job ID: 000000000192CEC0 2023-03-25 05:09:37.129 2023-03-25 05:09:37 2023-03-25 05:09:37.145 Starting Switch Fastboot to Update mode 2023-03-25 05:09:37.158 Selected phone model: ART-AL00X 2023-03-25 05:09:37.210 Searching Fastboot devices... 2023-03-25 05:09:39.201 Total interfaces: 1 2023-03-25 05:09:39.202 Interface 0 : flags: 1, name(81): \\?\usb#vid_18d1&pid_d00d#duj6r20624012362#{f72fe0 d4-cbcb-407d-8814-9ed673d0dd6b} 2023-03-25 05:09:39.202 Found android device: DUJ6R20624012362 2023-03-25 05:09:39.219 Reading product model 2023-03-25 05:09:41.207 Reading build number 2023-03-25 05:09:43.208 Device Model: ART-L29 2023-03-25 05:09:43.226 System: ARTH-L29 10.1.0.191(C185E2R3P1) 2023-03-25 05:09:43.235 Initializing remote service connection... 2023-03-25 05:09:44.551 Switching to Upgrade Mode... Writing ERECOVERY files... 2023-03-25 05:09:44.572 Response contains FAIL! 2023-03-25 05:09:44.573 invalid command 2023-03-25 05:09:48.546 Response contains FAIL! 2023-03-25 05:09:48.546 invalid command 2023-03-25 05:09:53.885 Response contains FAIL! 2023-03-25 05:09:53.885 invalid command 2023-03-25 05:09:57.085 Successfully switched to update mode. 2023-03-25 05:09:57.105 Switch Fastboot to Update mode done. 2023-03-25 05:09:57.122 Performed by 1.3.3 Software version. 2023-03-25 05:10:10.123 Job ID: 0000000001E35000 2023-03-25 05:10:10.882 2023-03-25 05:10:10 2023-03-25 05:10:10.902 Starting Write Firmware(Downgrade mode) 2023-03-25 05:10:10.919 Selected phone model: ART-AL00X 2023-03-25 05:10:12.777 PACKAGE_TYPE: OFFLINE_UPDATE 2023-03-25 05:10:17.716 Checking firmware package type 2023-03-25 05:10:17.726 Searching device in Upgrade mode... 2023-03-25 05:10:17.736 Detected DBAdapter Reserved Interface port 2023-03-25 05:10:17.755 Connecting to phone.. 2023-03-25 05:10:17.766 Phone connect successfully! 2023-03-25 05:10:17.777 Writing firmware partitions... 2023-03-25 05:10:17.788 Initializing remote service connection... 2023-03-25 05:10:17.798 Downloading patch files from the server... 2023-03-25 05:10:20.337 Downloading resource... 2023-03-25 05:10:22.041 Writing SHA256RSA partition... 2023-03-25 05:10:23.567 Writing CRC partition... 2023-03-25 05:10:24.798 Writing HISIUFS_GPT partition... 2023-03-25 05:10:25.449 Failed write HISIUFS_GPT partition 2023-03-25 05:10:25.476 Write Firmware(Downgrade mode) failed. 2023-03-25 05:10:25.500 Performed by 1.3.3 Software version. 2023-03-25 05:10:42.817 Job ID: 000000000192CECF 2023-03-25 05:10:43.459 2023-03-25 05:10:43 2023-03-25 05:10:43.485 Starting Switch Fastboot to Update mode 2023-03-25 05:10:43.511 Selected phone model: ART-AL00X 2023-03-25 05:10:43.550 Searching Fastboot devices... 2023-03-25 05:10:45.566 Total interfaces: 1 2023-03-25 05:10:45.568 Interface 0 : flags: 1, name(81): \\?\usb#vid_18d1&pid_d00d#duj6r20624012362#{f72fe0 d4-cbcb-407d-8814-9ed673d0dd6b} 2023-03-25 05:10:45.568 Found android device: DUJ6R20624012362 2023-03-25 05:10:45.598 Reading product model 2023-03-25 05:10:47.574 Reading build number 2023-03-25 05:10:49.591 Device Model: ART-L29 2023-03-25 05:10:49.619 System: ARTH-L29 10.1.0.191(C185E2R3P1) 2023-03-25 05:10:49.637 Initializing remote service connection... 2023-03-25 05:10:51.330 Switching to Upgrade Mode... Writing ERECOVERY files... 2023-03-25 05:10:51.359 Response contains FAIL! 2023-03-25 05:10:51.360 invalid command 2023-03-25 05:10:56.140 Response contains FAIL! 2023-03-25 05:10:56.140 invalid command 2023-03-25 05:11:01.097 Response contains FAIL! 2023-03-25 05:11:01.098 invalid command 2023-03-25 05:11:04.255 Successfully switched to update mode. 2023-03-25 05:11:04.287 Switch Fastboot to Update mode done. 2023-03-25 05:11:04.316 Performed by 1.3.3 Software version. 2023-03-25 05:11:19.776 Job ID: 0000000001E35010 2023-03-25 05:11:20.617 2023-03-25 05:11:20 2023-03-25 05:11:20.646 Starting Write Firmware(Upgrade mode) 2023-03-25 05:11:20.672 Selected phone model: ART-AL00X 2023-03-25 05:11:22.263 PACKAGE_TYPE: OFFLINE_UPDATE 2023-03-25 05:11:39.277 Checking firmware package type 2023-03-25 05:11:39.292 Searching device in Upgrade mode... 2023-03-25 05:11:39.307 Detected DBAdapter Reserved Interface port 2023-03-25 05:11:39.330 Connecting to phone.. 2023-03-25 05:11:39.346 Phone connect successfully! 2023-03-25 05:11:39.361 Writing firmware partitions... 2023-03-25 05:11:39.377 Writing SHA256RSA partition... 2023-03-25 05:11:41.722 Writing CRC partition... 2023-03-25 05:11:44.080 Writing XLOADER partition... 2023-03-25 05:11:45.260 Failed write XLOADER partition 2023-03-25 05:11:45.296 Write Firmware(Upgrade mode) failed. 2023-03-25 05:11:45.313 Performed by 1.3.3 Software version. |
03-27-2023, 07:00 | #5 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,142 | Hello Try firstly, flash device with board firmware via Facory mode, try to use TP. Then, you need to flash same stock firmware version via Fastboot mode. Thereafter, please inform us about result. |
