09-01-2021, 12:58 | #1 (permalink) |
Freak Poster Join Date: Aug 2016 Location: Peshawar Pakistan
Member: 2613197 Status: Offline Sonork: 100.1673396 Thanks Meter: 29 | Huawei MED-LX9 Huawei Id Remove DOne Selected phone model: MED-LX9 Please, put your device in Factory mode (use "ON/OFF Factory Mode" option or Hardware Test Point) and insert USB cable Detected MediaTek USB Port_V1633 port Detecting Chip Version... HW Chip : MT6765 HW Version : 8A00.CA00.0000.0000 Brom Version: 5 Boot Loader Version: FE Initializing remote service connection... Downloading Authentication Data... Sending Authentication Data... Initializing remote service connection... Downloading Download Agent data... Using MTK_AllInOne_DA_v3.3001.2018/10/18.17:38_452898 download agent... Found a suitable Download agent. Sending Download Agent... DA successfully sent Synchronizing with DA... Mobile Status: SYNC Mobile Status: brom Sending BootLoader Info... Initializing remote service connection... Downloading preloader data... Initializing Memory Flash... Initialization completed Sending Loader... Mobile Status: SYNC Loader successfully sent Reading Flash Info... EMMC rpmb size : 16 Mb EMMC boot1 size : 4 Mb EMMC boot2 size : 4 Mb EMMC gp1 size : 0 Mb EMMC gp2 size : 0 Mb EMMC gp3 size : 0 Mb EMMC gp4 size : 0 Mb EMMC user area size : 59640 Mb IMEI A: 860325XXXXXXXXX IMEI B: 860325XXXXXXXXX Connect done. Performed by 1.2.5 Software version. 2021-08-31 11:28:19 GMT ------------------------------------------------- Starting Reset Huawei ID Selected phone model: MED-LX9 Saving oeminfo backup to C:/Users/silen/Downloads/Compressed/oeminfo Creating partition backup: oeminfo Resetting Huawei ID... In case, if you are using Test Point method do next steps: - Power On your device manually and let it start; - Once you are in the phone main menu, Power Off your device; - Press "Ok" button and select oeminfo backup file manually, that you saved, before performing the operation; - Reconnect your device to PC. In case, if you are using "On/Off Factory mode" feature do next steps: - Press "Cancel" button; - Use "On/Off Factory mode" option for Power On your phone and let it start; - Once you are in the phone main menu, Power Off your device; - Switch your phone to Factory mode and write Oeminfo backup manually(use Write firmware Tab), that you saved, before performing the operation! Selected backup oeminfo file: C:/Users/silen/Desktop/oeminfo Please, put your device in Factory mode (use "ON/OFF Factory Mode" option or Hardware Test Point) and insert USB cable Detected MediaTek USB Port_V1633 port Detecting Chip Version... HW Chip : MT6765 HW Version : 8A00.CA00.0000.0000 Brom Version: 5 Boot Loader Version: FE Initializing remote service connection... Downloading Authentication Data... Sending Authentication Data... Initializing remote service connection... Downloading Download Agent data... Using MTK_AllInOne_DA_v3.3001.2018/10/18.17:38_452898 download agent... Found a suitable Download agent. Sending Download Agent... DA successfully sent Synchronizing with DA... Mobile Status: SYNC Mobile Status: brom Sending BootLoader Info... Initializing remote service connection... Downloading preloader data... Initializing Memory Flash... Initialization completed Sending Loader... Mobile Status: SYNC Loader successfully sent Reading Flash Info... EMMC rpmb size : 16 Mb EMMC boot1 size : 4 Mb EMMC boot2 size : 4 Mb EMMC gp1 size : 0 Mb EMMC gp2 size : 0 Mb EMMC gp3 size : 0 Mb EMMC gp4 size : 0 Mb EMMC user area size : 59640 Mb Writing partition: oeminfo |
The Following User Says Thank You to asiftanha For This Useful Post: |
