01-05-2023, 07:57 | #1 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | HUAWEI P30 ele-l29 FRP Question [Answered] and which version select emui 12/11/10 i want to unlock frp test point method. Code: Job ID: 00000000019B5BB8 2023-01-04 17:51:07 Starting Read Info Selected phone model: ELE-L29 Searching Fastboot devices... Found android device: 53F5T19816000114 Detected Android Sooner Single ADB Interface port Reading basic data... Device Model: ELE-L29 System: ELE-L29 12.0.0.134(C636E3R3P1) Android Version: 10 Base Version: ELE-LGRP2-OVS 102.0.0.134 Custom Version: ELE-L29-CUST 102.0.0.3(C636) Preload Version: ELE-L29-PRELOAD 102.0.0.1(C636R3) C_Version: C636 D_Version: D000 Read Info done. Performed by 1.3.2.3 Software version. |
01-05-2023, 08:20 | #2 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,141 | Hello Reset FRP for this device supported and you can try to perform it, but before read software manual. Thereafter, please send us result, we will check it. |
The Following User Says Thank You to Octopus support For This Useful Post: |
01-05-2023, 10:20 | #3 (permalink) |
Member: 2556542 Status: Offline Thanks Meter: 1,790 | frp reset faild Code: Job ID: 00000000019B6E3C 2023-01-04 20:14:50 Starting Reset FRP Selected phone model: ELE-L29 Selected method: Reset Frp (EMUI12/Harmony) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN980_V4... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Operation in progress. Please wait for instructions... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: 53F5T19816000114 Detected Android Sooner Single ADB Interface port Reading basic data... Device Model: ELE-L29 System: ELE-L29 12.0.0.134(C636E3R3P1) Android Version: 10 Base Version: ELE-LGRP2-OVS 102.0.0.134 Custom Version: ELE-L29-CUST 102.0.0.3(C636) Preload Version: ELE-L29-PRELOAD 102.0.0.1(C636R3) C_Version: C636 D_Version: D000 FB Lock State: LOCKED User Lock State: LOCKED Connecting to the credit server... Username: Default_user Checking balance... Your balance: 0 credits Sending device information... Sending firmware information... Error: Bootloader check failed. Connect your phone via Factory mode and perform the operation again. Reset FRP failed. Performed by 1.3.2.3 Software version. |
01-05-2023, 10:23 | #4 (permalink) |
Member: 2556542 Status: Offline Thanks Meter: 1,790 | on/off factory mode faild Code: Job ID: 00000000019B6EF2 2023-01-04 20:19:32 Starting ON/OFF Factory Mode Selected phone model: ELE-L29 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode! Performing OFF Factory Mode operation... Searching Fastboot devices... Found android device: 53F5T19816000114 Detected Android Sooner Single ADB Interface port Device Model: ELE-L29 System: ELE-L29 12.0.0.134(C636E3R3P1) Removing firmware protection... Connecting to server... Error: Data encryption failed ON/OFF Factory Mode failed. Performed by 1.3.2.3 Software version. |
