12-18-2022, 11:15 | #1 (permalink) |
Freak Poster Join Date: May 2013 Location: algeria
Member: 1933548 Status: Offline Thanks Meter: 19 | Huawei p40 pro (ELS-NX9) id remove issue [Answered] Huawei p40 pro (ELS-NX9) id remove failed. the phone disconnected in the Resetting Huawei ID stage . pls help me Code: Welcome to Octoplus Huawei Software v.1.3.3 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM1 Communications Port 2: COM5 USB Serial Port Job ID: 000000000191EB03 2022-12-18 10:02:21 Starting Reset Huawei ID Selected phone model: ELS-NX9 Selected method: Reset Huawei Id (EMUI12/Harmony) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN990_5G_V5... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Writing BL2 partition... Operation in progress. Please wait for instructions... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: 0123456789ABCDEF Detected Android Sooner Single ADB Interface port Reading basic data... Device Model: ELS-NX9 System: ELS-N29 12.0.0.276(C432E3R6P5) Android Version: 10 Base Version: ELS-LGRP4-OVS 102.0.0.276 Custom Version: ELS-N29-CUST 102.0.0.3(C432) Preload Version: ELS-N29-PRELOAD 102.0.0.5(C432R6) C_Version: C432 D_Version: D000 FB Lock State: LOCKED User Lock State: LOCKED Connecting to the credit server... Username: Default_user Checking balance... Your balance: 0 credits Sending device information... Sending firmware information... Removing firmware protection... Connecting to server... Waiting for a response from the server... FB Lock State: UNLOCKED User Lock State: LOCKED Device Model: ELS-NX9 System: ELS-N29 12.0.0.276(C432E3R6P5) MEID: xxxxxxxxxxxxxxxxx IMEI A: xxxxxxxxxxxxxxxx IMEI B: xxxxxxxxxxxxxxxx Writing secure data... Resetting Huawei ID... Reset Huawei ID done. Performed by 1.3.3 Software version. |
12-19-2022, 16:15 | #2 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,141 | Hello As we can see from software log your device has one of the last security level. You need to downgrade firmware version to 220 to perform operation successfully You can re-flash device via factory mode with this (ELS-NX9 11.0.0.208(C432E3R6P4) firmware version and try to perform operation once again. All operation with flashing firmware you do at your own risk. |
01-19-2023, 15:34 | #11 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Gsm World Age: 37
Member: 2070850 Status: Offline Thanks Meter: 9 | After downgrade the phone from the factory mode, look at the info from fastboot. Job ID: 0000000001A15D49 2023-01-19 13:56:45 Starting Write Firmware(Fastboot mode) Selected phone model: ELS-NX9 PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE Searching Fastboot devices... Found android device: 0123456789ABCDEF Device Model: ELS-NX9 System: ELS-N29 11.0.0.202(C432E3R6P4) Removing firmware protection... Connecting to server... Waiting for a response from the server... FB Lock State: UNLOCKED User Lock State: LOCKED Writing PTABLE partition... Writing PTABLE partition... Writing XLOADER partition... Writing FASTBOOT partition... Writing BL2 partition... Writing BOOT partition... Writing DTBO partition... Writing VECTOR partition... Writing FW_LPM3 partition... Writing HHEE partition... Writing VBMETA partition... Writing TEEOS partition... Writing TRUSTFIRMWARE partition... Writing HIEPS partition... Writing SENSORHUB partition... Writing FW_HIFI partition... Writing MODEMNVM_UPDATE partition... Writing MODEMNVM_CUST partition... Writing MODEM_DRIVER partition... Writing RECOVERY partition... Writing RECOVERY_RAMDISK partition... Writing RECOVERY_VENDOR partition... Writing RECOVERY_VBMETA partition... Writing ERECOVERY partition... Writing ERECOVERY_RAMDISK partition... Writing ERECOVERY_VENDOR partition... Writing ERECOVERY_VBMETA partition... Writing PREAS partition... Writing PREAVS partition... Writing ENG_VENDOR partition... Writing ENG_SYSTEM partition... Writing HDCP partition... Writing CACHE partition... Writing RAMDISK partition... Writing SUPER partition... Writing 1 chunk from 3... Writing 2 chunk from 3... Writing 3 chunk from 3... Writing SUPER partition... Writing 1 chunk from 9... Writing 2 chunk from 9... Writing 3 chunk from 9... Writing 4 chunk from 9... Writing 5 chunk from 9... Writing 6 chunk from 9... Writing 7 chunk from 9... Writing 8 chunk from 9... Writing 9 chunk from 9... Writing METADATA partition... Writing VBMETA_SYSTEM partition... Writing VBMETA_VENDOR partition... Writing VBMETA_ODM partition... Writing VBMETA_HW_PRODUCT partition... Writing VBMETA_CUST partition... Writing ISP_FIRMWARE partition... Writing MODEM_FW partition... Writing IVP partition... Writing NPU partition... Writing HISEE_IMG partition... Writing USERDATA partition... Writing VERSION partition... Writing PRELOAD partition... Writing PATCH partition... Writing VERSION partition... Writing PRELOAD partition... Writing 1 chunk from 2... Writing 2 chunk from 2... Write Firmware(Fastboot mode) done. Performed by 1.3.3 Software version. Job ID: 0000000001A2ED28 2023-01-19 14:22:46 Starting Read Info Selected phone model: ELS-NX9 Searching Fastboot devices... Found android device: K5J0220314006679 Detected Android Sooner Single ADB Interface port Reading basic data... Device Model: ELS-N29 System: ELS-N29 11.0.0.202(C432E3R6P4) Android Version: 10 Base Version: ELS-LGRP4-OVS 102.0.0.290 Custom Version: ELS-N29-CUST 102.0.0.3(C432) Preload Version: ELS-N29-PRELOAD 102.0.0.5(C432R4) C_Version: C432 D_Version: D000 Read Info done. Performed by 1.3.3 Software version. |
01-20-2023, 11:41 | #13 (permalink) |
Member: 2070850 Status: Offline Thanks Meter: 9 | Once I flashed from factory mode (black screen on fast boot) the device turned on normally. as far as I know there is no other option to flash (downgrade) emui 12 through your tool, can you give specific guidelines to solve huawei id… |
01-20-2023, 13:32 | #14 (permalink) |
Member: 2891705 Status: Offline Thanks Meter: 2,141 | Hello After downgrading via downgrade mode device become black screen? Only after dowgrading device you can perform Reset Huawei ID, device's firmware should be 220 |
