07-14-2021, 16:07 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Huwaie P30 pro converted chinese to global Code: 2021-07-14 13:21:29.946 Loading application settings 2021-07-14 13:21:29.946 Refreshing serial ports list 2021-07-14 13:21:29.993 Found COM ports: 2021-07-14 13:21:29.993 1: COM1 Communications Port 2021-07-14 13:21:29.993 2: COM123 USB Serial Port 2021-07-14 13:21:30.118 Welcome to Octoplus Huawei Software v.1.2.4 2021-07-14 13:21:30.118 2021-07-14 13:21:30.118 To enable 'Manufacture' mode dial 2021-07-14 13:21:30.118 - for Qualcomm and Hisilicon based models: *#*#2846579#*#* 2021-07-14 13:21:30.118 ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode 2021-07-14 13:21:30.118 - for MTK based models: *#*#14789632#*#* 2021-07-14 13:21:30.118 ProjectMenu > Background Settings > USB Port Settings > Debug Mode 2021-07-14 13:21:30.118 2021-07-14 13:21:30.118 To enable 'Fastboot' mode 2021-07-14 13:21:30.118 1. Power off the phone. Remove SD and SIM cards 2021-07-14 13:21:30.118 2. Press 'Vol-' and insert USB cable 2021-07-14 13:21:30.118 3. Wait until phone enters 'Fastboot' mode 2021-07-14 13:21:30.118 2021-07-14 13:21:30.118 To enable 'Upgrade' mode 2021-07-14 13:21:30.118 1. Power off the phone. Remove SD and SIM cards 2021-07-14 13:21:30.118 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 2021-07-14 13:21:30.118 3. Wait until phone enters 'Upgrade mode' 2021-07-14 13:21:30.227 Refreshing serial ports list 2021-07-14 13:21:30.258 Found COM ports: 2021-07-14 13:21:30.274 1: COM1 Communications Port 2021-07-14 13:21:30.274 2: COM123 USB Serial Port 2021-07-14 13:21:30.352 Init finished 2021-07-14 13:22:05.780 Connected to log server. 2021-07-14 13:22:07.932 Job ID: 000000000143759D 2021-07-14 13:22:08.447 2021-07-14 13:22:08 GMT ------------------------------------------------- 2021-07-14 13:22:08.697 Starting Backup Firmware 2021-07-14 13:22:08.946 Selected phone model: VOG-AL00 2021-07-14 13:22:09.227 Searching HUAWEI USB COM 1.0 port... 2021-07-14 13:22:27.324 Refreshing serial ports list 2021-07-14 13:22:27.603 Found COM ports: 2021-07-14 13:22:27.863 1: COM1 Communications Port 2021-07-14 13:22:28.100 2: COM185 HUAWEI USB COM 1.0 2021-07-14 13:22:28.350 3: COM123 USB Serial Port 2021-07-14 13:22:28.600 Detected HUAWEI USB COM 1.0 port 2021-07-14 13:22:28.880 Writing bootloader KIRIN980_V1... 2021-07-14 13:22:29.130 Initializing remote service connection... 2021-07-14 13:22:36.571 Writing XLOADER partition... 2021-07-14 13:22:37.336 Writing UCE partition... 2021-07-14 13:23:07.995 Writing FASTBOOT partition... 2021-07-14 13:23:25.640 Bootloader Update successfully 2021-07-14 13:23:25.889 Rebooting to fastboot mode... 2021-07-14 13:23:26.139 Searching Fastboot devices... 2021-07-14 13:23:34.359 Total interfaces: 1 2021-07-14 13:23:34.609 Interface 0 : flags: 1, name(79): \\?\usb#vid_18d1&pid_d00d#5&2a6d7c22&0&2#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} 2021-07-14 13:23:34.858 Found a fastboot device: 7N6BUV1943144548 2021-07-14 13:23:36.980 Response contains FAIL! 2021-07-14 13:23:37.230 Reading serial number failed 2021-07-14 13:23:41.410 Device Model: VOG-AL00 2021-07-14 13:23:41.660 System: VOG-AL00 10.1.0.162(C00E160R2P8) 2021-07-14 13:23:46.418 Removing firmware protection... 2021-07-14 13:23:47.260 Connecting to server... 2021-07-14 13:23:48.742 Private enc 0 2021-07-14 13:23:49.008 Waiting for a response from the server... 2021-07-14 13:24:14.015 Writing sign buf data 2021-07-14 13:24:16.079 FB Lock State: UNLOCKED 2021-07-14 13:24:16.333 User Lock State: UNLOCKED 2021-07-14 13:24:16.751 Detected UFS partition table 2021-07-14 13:24:17.005 Partition frp: start 80000, size 80000 2021-07-14 13:24:17.261 Partition persist: start 100000, size 600000 2021-07-14 13:24:17.517 Partition reserved1: start 700000, size 100000 2021-07-14 13:25:22.211 Backuping partition MODEM_FW... 2021-07-14 13:25:25.586 Backuping partition MODEM_OM... 2021-07-14 13:25:25.835 Response contains FAIL! 2021-07-14 13:25:26.116 partition is not exist 2021-07-14 13:25:26.366 MODEM_OM partition backup failure! 2021-07-14 13:25:26.631 Backuping partition MODEM_SECURE... 2021-07-14 13:25:26.896 Backuping partition MODEMNVM_BACKUP... 2021-07-14 13:25:27.614 Backuping partition MODEMNVM_CUST... 2021-07-14 13:25:28.721 Backuping partition MODEMNVM_FACTORY... 2021-07-14 13:25:29.829 Backuping partition MODEMNVM_IMG... 2021-07-14 13:25:31.982 Backuping partition MODEMNVM_SYSTEM... 2021-07-14 13:25:32.231 Response contains FAIL! 2021-07-14 13:25:32.481 partition is not exist 2021-07-14 13:25:32.730 MODEMNVM_SYSTEM partition backup failure! 2021-07-14 13:25:32.996 Backuping partition MODEMNVM_UPDATE... 2021-07-14 13:25:33.292 Backuping partition NVME... 2021-07-14 13:25:33.776 Backuping partition OEMINFO... 2021-07-14 13:25:39.454 Rebooting device... 2021-07-14 13:25:39.735 2021-07-14 13:25:40.000 Backup Firmware done. 2021-07-14 13:25:40.255 Performed by 1.2.4 Software version. 2021-07-14 13:26:31.732 Connected to log server. 2021-07-14 13:26:33.947 Job ID: 0000000001437773 2021-07-14 13:26:34.509 2021-07-14 13:26:34 GMT ------------------------------------------------- 2021-07-14 13:26:34.774 Starting Write Backup 2021-07-14 13:26:35.055 Selected phone model: VOG-AL00 2021-07-14 13:26:35.367 Searching HUAWEI USB COM 1.0 port... 2021-07-14 13:26:40.626 Refreshing serial ports list 2021-07-14 13:26:40.936 Found COM ports: 2021-07-14 13:26:41.255 1: COM1 Communications Port 2021-07-14 13:26:41.520 2: COM185 HUAWEI USB COM 1.0 2021-07-14 13:26:41.801 3: COM123 USB Serial Port 2021-07-14 13:26:42.066 Detected HUAWEI USB COM 1.0 port 2021-07-14 13:26:42.363 Writing bootloader KIRIN980_V1... 2021-07-14 13:26:42.643 Initializing remote service connection... 2021-07-14 13:26:46.200 Canceling... Please be patient! 2021-07-14 13:26:50.521 Writing XLOADER partition... 2021-07-14 13:26:50.802 2021-07-14 13:26:51.083 Write Backup failed. 2021-07-14 13:26:51.364 Performed by 1.2.4 Software version. 2021-07-14 13:27:40.352 Connected to log server. 2021-07-14 13:27:42.583 Job ID: 00000000014377DE 2021-07-14 13:27:43.129 2021-07-14 13:27:43 GMT ------------------------------------------------- 2021-07-14 13:27:43.409 Starting Write Backup 2021-07-14 13:27:43.690 Selected phone model: VOG-AL00 2021-07-14 13:27:43.987 Searching HUAWEI USB COM 1.0 port... 2021-07-14 13:27:50.298 Refreshing serial ports list 2021-07-14 13:27:50.608 Found COM ports: 2021-07-14 13:27:50.931 1: COM1 Communications Port 2021-07-14 13:27:51.212 2: COM185 HUAWEI USB COM 1.0 2021-07-14 13:27:51.477 3: COM123 USB Serial Port 2021-07-14 13:27:51.758 Detected HUAWEI USB COM 1.0 port 2021-07-14 13:27:52.055 Writing bootloader KIRIN980_V1... 2021-07-14 13:27:52.335 Initializing remote service connection... 2021-07-14 13:27:59.699 Writing XLOADER partition... 2021-07-14 13:28:00.463 Writing UCE partition... 2021-07-14 13:28:31.122 Writing FASTBOOT partition... 2021-07-14 13:28:48.888 Bootloader Update successfully 2021-07-14 13:28:49.170 Rebooting to fastboot mode... 2021-07-14 13:28:49.458 Searching Fastboot devices... 2021-07-14 13:28:57.354 Total interfaces: 1 2021-07-14 13:28:57.630 Interface 0 : flags: 1, name(79): \\?\usb#vid_18d1&pid_d00d#5&2a6d7c22&0&2#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} 2021-07-14 13:28:57.904 Found a fastboot device: 7N6BUV1943144548 2021-07-14 13:28:59.955 Response contains FAIL! 2021-07-14 13:29:00.229 Reading serial number failed 2021-07-14 13:29:04.355 Device Model: VOG-AL00 2021-07-14 13:29:04.638 System: VOG-AL00 10.1.0.162(C00E160R2P8) 2021-07-14 13:29:09.356 Removing firmware protection... 2021-07-14 13:29:10.201 Connecting to server... 2021-07-14 13:29:11.845 Private enc 0 2021-07-14 13:29:12.119 Waiting for a response from the server... 2021-07-14 13:29:37.116 Writing sign buf data 2021-07-14 13:29:39.178 FB Lock State: UNLOCKED 2021-07-14 13:29:39.461 User Lock State: UNLOCKED 2021-07-14 13:29:39.744 Writing OEMINFO partition... 2021-07-14 13:29:43.838 Rebooting device... 2021-07-14 13:29:44.123 2021-07-14 13:29:44.407 Write Backup done. 2021-07-14 13:29:44.690 Performed by 1.2.4 Software version. 2021-07-14 13:29:56.848 Connected to log server. 2021-07-14 13:29:59.113 Job ID: 000000000143788F Repair info and flash in update mode Code: 2021-07-14 14:29:01 GMT ------------------------------------------------- Starting Repair Info Selected phone model: VOG-AL00 New Product Name: VOG-L29 New Vendor Code: hw New Country Code: eu Repairing info... Removing firmware protection... Connecting to server... Waiting for a response from the server... FB Lock State: UNLOCKED User Lock State: LOCKED Repairing Vendor/Country... Rebooting device... Repair Info done. Performed by 1.2.4 Software version. Selected base ptable file: D:/Huawei/vog-l29/HUAWEI P30 PRO VOG-L29 10.1.0.163(C185E8R5P1)_Firmware_EMUI10.1.0_05015XPG/dload/update_sd_base/PTABLE.APP Selected base update file: D:/Huawei/vog-l29/HUAWEI P30 PRO VOG-L29 10.1.0.163(C185E8R5P1)_Firmware_EMUI10.1.0_05015XPG/dload/update_sd_base/UPDATE.APP Selected cust ptable file: D:/Huawei/vog-l29/HUAWEI P30 PRO VOG-L29 10.1.0.163(C185E8R5P1)_Firmware_EMUI10.1.0_05015XPG/dload/update_sd_cust_VOG-L29_hw_meafnaf/PTABLE.APP Selected cust update file: D:/Huawei/vog-l29/HUAWEI P30 PRO VOG-L29 10.1.0.163(C185E8R5P1)_Firmware_EMUI10.1.0_05015XPG/dload/update_sd_cust_VOG-L29_hw_meafnaf/UPDATE.APP Selected preload ptable file: D:/Huawei/vog-l29/HUAWEI P30 PRO VOG-L29 10.1.0.163(C185E8R5P1)_Firmware_EMUI10.1.0_05015XPG/dload/update_sd_preload_VOG-L29_hw_meafnaf_R5/PTABLE.APP Selected preload base file: D:/Huawei/vog-l29/HUAWEI P30 PRO VOG-L29 10.1.0.163(C185E8R5P1)_Firmware_EMUI10.1.0_05015XPG/dload/update_sd_preload_VOG-L29_hw_meafnaf_R5/UPDATE.APP PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE Selected base update file: D:/Huawei/vog-l29/HUAWEI P30 PRO VOG-L29 10.1.0.163(C185E8R5P1)_Firmware_EMUI10.1.0_05015XPG/dload/update_sd_base/UPDATE.APP PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE Job ID: 0000000001438F8C 2021-07-14 14:35:02 GMT ------------------------------------------------- Starting Write Firmware(Upgrade mode) Selected phone model: VOG-AL00 Checking firmware package type Searching device in Upgrade mode... Detected DBAdapter Reserved Interface port Connecting to phone.. Phone connect successfully! Writing firmware partitions... Writing SHA256RSA partition... Writing CRC partition... Writing BASE_VERLIST partition... Writing BASE_VER partition... Writing PACKAGE_TYPE partition... Writing HISIUFS_GPT partition... Writing SHA256RSA partition... Writing CRC partition... Writing CUST_VERLIST partition... Writing CUST_VER partition... Writing PACKAGE_TYPE partition... Writing PTABLE_CUST partition... Writing SHA256RSA partition... Writing CRC partition... Writing PRELOAD_VERLIST partition... Writing PRELOAD_VER partition... Writing PACKAGE_TYPE partition... Writing PTABLE_PRELOAD partition... Writing SHA256RSA partition... Writing CRC partition... Writing BASE_VERLIST partition... Writing BASE_VER partition... Writing PACKAGE_TYPE partition... Writing HISIUFS_GPT partition... Writing XLOADER partition... Writing FASTBOOT partition... Writing DTS partition... Writing DTO partition... Writing VECTOR partition... Writing FW_LPM3 partition... Writing HHEE partition... Writing VBMETA partition... Writing TEEOS partition... Writing TRUSTFIRMWARE partition... Writing SENSORHUB partition... Writing FW_HIFI partition... Writing KERNEL partition... Writing MODEMNVM_UPDATE partition... Writing MODEMNVM_CUST partition... Writing MODEM_DRIVER partition... Writing RECOVERY_RAMDISK partition... Writing RECOVERY_VENDOR partition... Writing RECOVERY_VBMETA partition... Writing PREAS partition... Writing PREAVS partition... Writing PRETS partition... Writing PRETVS partition... Writing ERECOVERY_KERNEL partition... Writing ERECOVERY_RAMDISK partition... Writing ERECOVERY_VENDOR partition... Writing ERECOVERY_VBMETA partition... Writing ENG_VENDOR partition... Writing ENG_SYSTEM partition... Writing HDCP partition... Writing CACHE partition... Writing RAMDISK partition... Writing SUPER partition... Writing SUPER partition... Writing VBMETA_SYSTEM partition... Writing VBMETA_VENDOR partition... Writing VBMETA_ODM partition... Writing VBMETA_HW_PRODUCT partition... Writing VBMETA_CUST partition... Writing ISP_FIRMWARE partition... Writing MODEM_FW partition... Writing HISEE_IMG partition... Writing PATCH partition... Writing KPATCH partition... Writing USERDATA partition... Writing UFSFW partition... Writing SHA256RSA partition... Writing CRC partition... Writing CUST_VERLIST partition... Writing CUST_VER partition... Writing PACKAGE_TYPE partition... Writing PTABLE_CUST partition... Writing VERSION partition... Writing SHA256RSA partition... Writing CRC partition... Writing PRELOAD_VERLIST partition... Writing PRELOAD_VER partition... Writing PACKAGE_TYPE partition... Writing PTABLE_PRELOAD partition... Writing PRELOAD partition... Firmware writing successfully completed Write Firmware(Upgrade mode) done. Performed by 1.2.4 Software version. |
The Following User Says Thank You to zishhaider For This Useful Post: |
