Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus Huawei Tool
Old 01-14-2022, 07:39   #1 (permalink)
.:D:.'s Avatar
Member: 2561651
Sonork: 100.*******
Thanks Meter: 283
ine lx1 read write question [Answered]
hello
ine lx1 8 version but still read write cert fail
here,s the logs
Welcome to Octoplus Huawei Software v.‪1.2.8‬
To enable 'Manufacture' mode dial
- for Qualcomm and Hisilicon based models: *#*#2846579#*#*
ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode
- for MTK based models: *#*#14789632#*#*
ProjectMenu > Background Settings > USB Port Settings > Debug Mode
To enable 'Fastboot' mode
1. Power off the phone. Remove SD and SIM cards
2. Press 'Vol-' and insert USB cable
3. Wait until phone enters 'Fastboot' mode
To enable 'Upgrade' mode
2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable
3. Wait until phone enters 'Upgrade mode'
Found COM ports:
1: COM17 USB Serial Port
2: COM105 HUAWEI USB COM 1.0
Job ID: 00000000021C2678
2022-01-14 06:35:29
Starting Read Cert
Selected phone model: ‪INE-LX1‬
Searching HUAWEI USB COM 1.0 port...
Detected ‪HUAWEI USB COM 1.0‬ port
Writing bootloader KIRIN710_V1...
Initializing remote service connection...
Writing ‪XLOADER‬ partition...
Writing ‪UCE‬ partition...
Writing ‪FASTBOOT‬ partition...
Bootloader Update successfully
Rebooting to fastboot mode...
Searching Fastboot devices...
Found android device:
Detected ‪Android Sooner Single ADB Interface‬ port
Device Model: ‪INE-LX1‬
System: ‪INE-LX1 8.2.0.137(C432)‬
MEID: ‪
IMEI A: ‪‬
IMEI B: ‪‬
S/N: ‪
Reading certificate files...
Reading certificate for IMEI A...
Error: Can't get current certificate file!
Warning: Skipping read certificate for IMEI A
Reading certificate for IMEI B...
Warning: Skipping read certificate for IMEI B
Rebooting device...
Read Cert done.
Performed by ‪1.2.8‬ Software version.
Old 01-14-2022, 10:07   #2 (permalink)
Member: 2891705
Thanks Meter: 1,361
Hello.
Please, send us your "modem_secure" file. We will check it.
Old 01-14-2022, 10:18   #3 (permalink)
.:D:.'s Avatar
Member: 2561651
Sonork: 100.*******
Thanks Meter: 283
here,s your file chkkkk
https://drive.google.com/file/d/1ZM2...ew?usp=sharing
Old 01-14-2022, 10:52   #4 (permalink)
Member: 2891705
Thanks Meter: 1,361
What is state of phone now? The IMEI of the device okay?
Old 01-14-2022, 11:34   #5 (permalink)
.:D:.'s Avatar
Member: 2561651
Sonork: 100.*******
Thanks Meter: 283
ok listen imei etc showing ok but read write cert was not working so i even wipe oem
and write board rom but still prob remain
Old 01-14-2022, 13:04   #6 (permalink)
Member: 2891705
Thanks Meter: 1,361
The software is working properly.
There are no cert files from your device in this partition, which means that they are corrupted. For the same reason, you can't perform Read Cert operation.
Old 01-15-2022, 06:42   #7 (permalink)
.:D:.'s Avatar
Member: 2561651
Sonork: 100.*******
Thanks Meter: 283
if cert part is empty then i try to write cert but its also not workable
so what,s the reason of this or how to solve it?
Old 01-15-2022, 07:18   #8 (permalink)
.:D:.'s Avatar
Member: 2561651
Sonork: 100.*******
Thanks Meter: 283
and i tried 2 differnt board roms from your support but this error
Job ID: 0
2022-01-15 06:15:49
Starting Write Firmware(Factory mode)
Selected phone model: ‪INE-LX2‬
Selected file: C:/Users/unnam/Desktop/Software/IVY-BD_1.0.0.27_Download.xml
Selected Full flashing mode!
Loading firmware configuaration file...
Error: This firmware version is not currently supported! Please, use a different firmware version or download the firmware from the support area!
Write Firmware(Factory mode) failed.
Old 01-15-2022, 08:13   #9 (permalink)
.:D:.'s Avatar
Member: 2561651
Sonork: 100.*******
Thanks Meter: 283
now see this team its write cert and even in logs showing my changed imei but in device
its not showing the real imei still old imei
Job ID:
2022-01-15 07:02:16
Starting Write Cert
Username: Default_user
Connecting to the credit server...
Checking balance...
Your balance: 0 credits
Sending device information...
Sending firmware information...
To perform this operation you need to have: 0 credits.
System: ‪INE-LX1 8.2.0.106(C432)‬
MEID: ‪A00000
IMEI A: 86xx
IMEI B: ‪86xx
S/N: ‪‬
Saving backup of MODEM_SECURE...
Saving backup of OEMINFO...
Reading secure data...
Writing certificate files...
Rebooting device...
Write Cert done.
Old 01-15-2022, 08:20   #10 (permalink)
Member: 2891705
Thanks Meter: 1,361
Try to perform Factory Reset and check IMEI status on your device one more time.
Old 01-15-2022, 10:00   #11 (permalink)
.:D:.'s Avatar
Member: 2561651
Sonork: 100.*******
Thanks Meter: 283
bro i write sec backup from another device then imei changed to another device
after that i was successfuly able to read cert but when i writed another imei its still showing of another device IMEI even i write again another board from your support but still another device imei
its basiclly changed imei when i change sec backup even now fix read cert but after write
old imei why?
let me add some more logs
MEID: ‪
IMEI A: ‪86xxxxxxxxxxxxxx
IMEI B: ‪86xxxxxxxxxxxxxx
S/N: ‪xxxxxxxxxxxxxx‬
Warning: The VRL file was not found
Writing MODEM_SECURE partition...
Writing MODEMNVM_BACKUP partition...
Writing MODEMNVM_CUST_A partition...
Writing MODEMNVM_FACTORY partition...
Writing MODEMNVM_IMG partition...
Writing MODEMNVM_UPDATE_A partition...
Writing OEMINFO partition...
Rebooting device...
Write Backup done.
Job ID:
2022-01-15 08:11:10
Starting Read Cert
Found android device: TGDDU16831005180
System: ‪Chipset-miami 8.2.0.001(01S9)‬
MEID: ‪00000000000000‬
S/N: ‪xxxxxxxxxxxxxxxxxx
Rebooting device...
Read Cert done.
Selected IMEI_B file: C:/Users/unnam/Desktop/huawei cert/xxx-L21_IMEI_SLOT_2_8xxxxxxxxxxxxx.obf
Job ID:
2022-01-15 08:32:36
Starting Write Cert
Checking balance...
IMEI B: ‪86xxxxxxxxxxxxxx‬
S/N: ‬
Rebooting device...
Write Cert done.
Job ID:
2022-01-15 08:39:29
Starting Update OEMINFO
Found android device: xxxxxxxxxxxxxxxxx
S/N: ‪
Update OEMINFO done.
Old 01-15-2022, 10:16   #12 (permalink)
Member: 2891705
Thanks Meter: 1,361
We will send this information to our developers to find a solution to your issue.
We'll try to give you an answer on Monday.
Old 01-17-2022, 07:32   #13 (permalink)
.:D:.'s Avatar
Member: 2561651
Sonork: 100.*******
Thanks Meter: 283
hope i get reply today i,m still wait for you
Old 01-17-2022, 09:13   #14 (permalink)
Member: 2891705
Thanks Meter: 1,361
Hello.
Please, explain one more time and more detail.
What exactly do you need to do with your device?
Also, after write backup, you always need to perform Factory Reset. You have completed Factory Reset in the previous steps?
Old 01-17-2022, 09:22   #15 (permalink)
.:D:.'s Avatar
Member: 2561651
Sonork: 100.*******
Thanks Meter: 283
can you come to skype so we,ll chat live with ss
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.11714 seconds with 7 queries
