![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2019 Location: Ghana
Member: 2938458 Status: Offline Thanks Meter: 61 | ![]() 2023-11-10 11:44:15 Starting Reset Huawei ID Selected phone model: JLN-LX1 Warning: Please, make sure the phone`s battery is fully charged and connected, after connect the device via Factory Mode (use Hardware Test Point or "ON/OFF Factory Mode option"). Warning: Selected response: Proceed Downloading resource... Downloading resource... Searching Qualcomm HS-USB QDLoader 9008 port... Please, reconnect battery, connect USB cable with attached Test Point on your phone! Detected Qualcomm HS-USB QDLoader 9008 port Connecting to device... Hadshaking... Reading bootloader info... OEM PK HASH: B25DECD85D217F5D9B53DC3C42EF7846DCEF59DD3E0AF4D126 06199F5099FF23 MSM HW ID: 001B80E1 Serial Number: A974*** Sending loader Qualcomm Snapdragon 680V.0.mbn... Loader send successfully Reconnecting, please wait... Configuring device... Reading partition table... Creating backup... Backup saved to JLN-LX1_BACKUP_FIRMWARE_2023-11-10_11-45-00. Searching for Huawei Id protection... Resetting Huawei Id... Performing factory reset... Please perform the factory reset operation manually through the recovery mode if the operation was not done automatically Reset Huawei ID done. Performed by 1.3.4 Software version. Job ID: 000000000256E154 2023-11-10 11:53:52 Starting Restore "Chip is damaged" Selected phone model: JLN-LX1 Warning: Please, make sure the phone`s battery is fully charged and connected, after connect the device via Factory Mode (use Hardware Test Point or "ON/OFF Factory Mode option"). Warning: Selected response: Proceed Downloading resource... Downloading resource... Searching Qualcomm HS-USB QDLoader 9008 port... Please, reconnect battery, connect USB cable with attached Test Point on your phone! Detected Qualcomm HS-USB QDLoader 9008 port Connecting to device... Hadshaking... Reading bootloader info... OEM PK HASH: B25DECD85D217F5D9B53DC3C42EF7846DCEF59DD3E0AF4D126 06199F5099FF23 MSM HW ID: 001B80E1 Serial Number: A974*** Sending loader Qualcomm Snapdragon 680V.0.mbn... Loader send successfully Reconnecting, please wait... Configuring device... Reading partition table... Creating backup... Backup saved to JLN-LX1_BACKUP_FIRMWARE_2023-11-10_11-54-33. Restoring "Chip is damaged"... Performing factory reset... Warning: 1. Plese activate Your device (finish all activating stages). 2. Thereafter, You have to put device into EDL Mode and tap "Ok" button. Note: if You don't complete steps above "Find Device" service will not be available! Warning: Selected response: Ok Downloading resource... Searching Qualcomm HS-USB QDLoader 9008 port... Please, reconnect battery, connect USB cable with attached Test Point on your phone! Detected Qualcomm HS-USB QDLoader 9008 port Connecting to device... Hadshaking... Reading bootloader info... OEM PK HASH: B25DECD85D217F5D9B53DC3C42EF7846DCEF59DD3E0AF4D126 06199F5099FF23 MSM HW ID: 001B80E1 Serial Number: A974E**** Sending loader Qualcomm Snapdragon 680V.0.mbn... Loader send successfully Reconnecting, please wait... Configuring device... Reading partition table... Restoring "Find device"... Restore "Chip is damaged" done. Performed by 1.3.4 Software version. |
The Following 2 Users Say Thank You to obimpena For This Useful Post: |
