Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Apr 2018
Member: 2829176 Status: Offline Thanks Meter: 2 | JNY-AL10 repair chip failed [Answered] To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM1 Communications Port 2: COM12 USB Serial Port 3: COM78 Agere Systems HDA Modem Warning: Connecting to remote service failed 2022-11-20 12:01:03 Starting Restore "Chip is damaged" Selected phone model: JNY-AL10 Selected method: Restore "Chip is damaged"(EMUI 10) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN810_V4... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: UT6WUW19C9017058 Detected Android Sooner Single ADB Interface port Reading basic data... Device Model: JNY-AL10 System: JNY-AL10 2.0.0.270(C00E230R3P5) Android Version: 10 Base Version: JNY-LGRP1-CHN 102.0.0.270 Custom Version: JNY-AL10-CUST 102.0.0.230(C00) Preload Version: JNY-AL10-PRELOAD 102.0.0.5(C00R3) C_Version: C00 D_Version: D000 FB Lock State: LOCKED User Lock State: LOCKED Error: Please make sure your internet connection is stable and try to repeat the operation Restore "Chip is damaged" failed. Performed by 1.3.3 Software version. Warning: Connecting to remote service failed 2022-11-20 12:04:13 Starting Restore "Chip is damaged" Selected phone model: JNY-AL10 Selected method: Restore "Chip is damaged"(EMUI 10) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN810_V4... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: Detected Android Sooner Single ADB Interface port Reading basic data... Restore "Chip is damaged" failed. Performed by 1.3.3 Software version. |
![]() | #2 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Jan 2019
Member: 2891705 Status: Offline Thanks Meter: 1,828 | Hello Unfortunately, your device has one of the last security level, which currently not supported. You can try to downgrade device via factory mode and perform operation once again. All operation with flashing firmware you do at your own risk |
