Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus Huawei Tool
Old 05-09-2024, 17:33   #1 (permalink)
Member: 1598426
Thanks Meter: 32
jny-lx1 downgrade problem [Answered]
Job ID: 00000000018F71A6
2024-05-08 18:20:28
Starting Read Info
Selected phone model: ‪JNY-LX1‬
Searching Fastboot devices...
Found android device: AUDUT20C23007279
Detected ‪Android Sooner Single ADB Interface‬ port
Reading basic data...
Device Model: ‪JNY-L21‬
System: ‪JNY-L21 12.0.0.296(C185E5R6P2)‬
Android Version: ‪10‬
Base Version: ‪JNY-LGRP2-OVS 102.0.0.296‬
Custom Version: ‪JNY-L21-CUST 102.0.0.5(C185)‬
Preload Version: ‪JNY-L21-PRELOAD 102.0.0.2(C185R6)‬
C_Version: ‪C185‬
D_Version: ‪D000‬
Read Info done.
Performed by ‪1.3.4‬ Software version.
this is the info of the device with huawei id
i reset huawei id and it was succesful but i faced chip is damaged problem i tried to restore chip is damaged and still the same so i tried to downgrade but i'm facing this problem
Welcome to Octoplus Huawei Software v.‪1.3.4‬
To enable 'Manufacture' mode dial
- for Qualcomm and Hisilicon based models: *#*#2846579#*#*
ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode
- for MTK based models: *#*#14789632#*#*
ProjectMenu > Background Settings > USB Port Settings > Debug Mode
To enable 'Fastboot' mode
1. Power off the phone. Remove SD and SIM cards
2. Press 'Vol-' and insert USB cable
3. Wait until phone enters 'Fastboot' mode
To enable 'Upgrade' mode
2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable
3. Wait until phone enters 'Upgrade mode'
Found COM ports:
1: COM1 Communications Port
2: COM10 RIM Virtual Serial Port v2
3: COM11 RIM Virtual Serial Port v2
4: COM3 Intel(R) Active Management Technology - SOL
Job ID: 0000000001E6E2F4
2024-05-09 16:08:33
Starting Write Firmware(Factory mode)
Warning: Please, make sure the phone`s battery is fully charged and connected, after connect the device via Factory Mode (use Hardware Test Point or "ON/OFF Factory Mode option").
Warning: Selected response: Proceed
Selected base ptable file: C:/Users/bassem/Desktop/JNY-LX1 102.0.0.220(C432E5R6P2)_Firmware_EMUI12.0.0_05016P NN/Software/dload/update_sd_base/PTABLE.APP
Selected cust ptable file: C:/Users/bassem/Desktop/JNY-LX1 102.0.0.220(C432E5R6P2)_Firmware_EMUI12.0.0_05016P NN/Software/dload/JNY-L21_hw_eu/update_sd_cust_JNY-L21_hw_eu/PTABLE.APP
Selected preload ptable file: C:/Users/bassem/Desktop/JNY-LX1 102.0.0.220(C432E5R6P2)_Firmware_EMUI12.0.0_05016P NN/Software/dload/JNY-L21_hw_eu/update_sd_preload_JNY-L21_hw_eu_R6/PTABLE.APP
Selected base update file: C:/Users/bassem/Desktop/JNY-LX1 102.0.0.220(C432E5R6P2)_Firmware_EMUI12.0.0_05016P NN/Software/dload/update_sd_base/UPDATE.APP
Selected cust update file: C:/Users/bassem/Desktop/JNY-LX1 102.0.0.220(C432E5R6P2)_Firmware_EMUI12.0.0_05016P NN/Software/dload/JNY-L21_hw_eu/update_sd_cust_JNY-L21_hw_eu/UPDATE.APP
Selected preload base file: C:/Users/bassem/Desktop/JNY-LX1 102.0.0.220(C432E5R6P2)_Firmware_EMUI12.0.0_05016P NN/Software/dload/JNY-L21_hw_eu/update_sd_preload_JNY-L21_hw_eu_R6/UPDATE.APP
PACKAGE_TYPE: OFFLINE_UPDATE
Selected method: Write firmware (EMUI 10)
Searching HUAWEI USB COM 1.0 port...
Detected ‪HUAWEI USB COM 1.0‬ port
Phone connect successfully
Writing bootloader KIRIN810_V4...
Initializing remote service connection...
Writing ‪XLOADER‬ partition...
Writing ‪UCE‬ partition...
Writing ‪FASTBOOT‬ partition...
Bootloader Update successfully
Rebooting to fastboot mode...
Warning: If you use modified USB cable please reconnect cable from the mother board and press "Ok" to proceed the operation
Warning: Selected response: Ok
Found android device: UT7VMG2116019096
Device Model: ‪JNY-LX1‬
Removing firmware protection...
Connecting to server...
Waiting for a response from the server...
FB Lock State: ‪UNLOCKED‬
User Lock State: ‪LOCKED‬
Writing PTABLE partition...
Writing XLOADER partition...
Writing FASTBOOT partition...
Writing BOOT partition...
Writing DTBO partition...
Writing VECTOR partition...
Writing FW_LPM3 partition...
Writing HHEE partition...
Writing VBMETA partition...
Writing TEEOS partition...
Writing TRUSTFIRMWARE partition...
Writing SENSORHUB partition...
Writing FW_HIFI partition...
Writing MODEMNVM_UPDATE partition...
Writing MODEMNVM_CUST partition...
Writing MODEM_DRIVER partition...
Writing RECOVERY partition...
Writing RECOVERY_RAMDISK partition...
Writing RECOVERY_VENDOR partition...
Writing RECOVERY_VBMETA partition...
Writing ERECOVERY partition...
Writing ERECOVERY_RAMDISK partition...
Writing ERECOVERY_VENDOR partition...
Writing ERECOVERY_VBMETA partition...
Writing PREAS partition...
Writing PREAVS partition...
Writing ENG_VENDOR partition...
Writing ENG_SYSTEM partition...
Writing CACHE partition...
Writing RAMDISK partition...
Error: Erasing SUPER partition failed
Writing SUPER partition...
Writing 1 chunk from 2...
Warning: Download size mismatch
Warning: Writing SUPER partition failed
Warning: Failed to write download size
Error: Writing SUPER partition failed
Writing 1 chunk from 9...
Error: Erasing METADATA partition failed
Writing METADATA partition...
Warning: Writing METADATA partition failed
Error: Writing METADATA partition failed
Error: Erasing VBMETA_SYSTEM partition failed
Writing VBMETA_SYSTEM partition...
Warning: Writing VBMETA_SYSTEM partition failed
both firmware
JNY-L21 10.1.0.314(C185E4R6P1)_Firmware_EMUI10.1.0_05016NT A
which firmware should i use to downgrade the phone
now it goes to erecovery mode
The Following User Says Thank You to basem the ghost For This Useful Post:
Old 05-10-2024, 10:28   #2 (permalink)
Member: 195049
Thanks Meter: 16
Try older versión, this work for me. https://androidhost.ru/B7s
Good luck
The Following User Says Thank You to mike090 For This Useful Post:
Old 05-12-2024, 18:19   #3 (permalink)
Member: 1598426
Thanks Meter: 32
Job ID: 00000000018E4228
2024-05-12 17:05:53
Selected base ptable file: C:/Users/bassem/Desktop/Huawei_P40_Lite_JNY-LX1_10.1.0.393_C185E5R6P1_Firmware_EMUI10.1.0_0501 7WWT_Dload/Firmware/dload/update_sd_base/PTABLE.APP
Selected cust ptable file: C:/Users/bassem/Desktop/Huawei_P40_Lite_JNY-LX1_10.1.0.393_C185E5R6P1_Firmware_EMUI10.1.0_0501 7WWT_Dload/Firmware/dload/JNY-L21_hw_meafnaf/update_sd_cust_JNY-L21_hw_meafnaf/PTABLE.APP
Selected preload ptable file: C:/Users/bassem/Desktop/Huawei_P40_Lite_JNY-LX1_10.1.0.393_C185E5R6P1_Firmware_EMUI10.1.0_0501 7WWT_Dload/Firmware/dload/JNY-L21_hw_meafnaf/update_sd_preload_JNY-L21_hw_meafnaf_R6/PTABLE.APP
Selected base update file: C:/Users/bassem/Desktop/Huawei_P40_Lite_JNY-LX1_10.1.0.393_C185E5R6P1_Firmware_EMUI10.1.0_0501 7WWT_Dload/Firmware/dload/update_sd_base/UPDATE.APP
Selected cust update file: C:/Users/bassem/Desktop/Huawei_P40_Lite_JNY-LX1_10.1.0.393_C185E5R6P1_Firmware_EMUI10.1.0_0501 7WWT_Dload/Firmware/dload/JNY-L21_hw_meafnaf/update_sd_cust_JNY-L21_hw_meafnaf/UPDATE.APP
Selected preload base file: C:/Users/bassem/Desktop/Huawei_P40_Lite_JNY-LX1_10.1.0.393_C185E5R6P1_Firmware_EMUI10.1.0_0501 7WWT_Dload/Firmware/dload/JNY-L21_hw_meafnaf/update_sd_preload_JNY-L21_hw_meafnaf_R6/UPDATE.APP
same problem with provided firmware
Old 05-13-2024, 06:49   #4 (permalink)
Octopus support's Avatar
Member: 2891705
Thanks Meter: 2,162
Hello
What's the exact state of device right now?
Old 05-13-2024, 17:10   #5 (permalink)
Member: 1598426
Thanks Meter: 32
Originally Posted by Octopus support View Post
Hello
it was going to erecovery mode
but flashing done by **** with same firmware and it's fully working now without huawei id
Old 05-17-2024, 08:55   #6 (permalink)
Member: 2891705
Thanks Meter: 2,162
Hello
Unfortunately, reset Huawei ID is not supported currently for such high firmwareversion
Page generated in 0.17436 seconds with 8 queries
