05-09-2024, 17:33 | #1 (permalink) |
Freak Poster Join Date: Jun 2011 Location: Egypt
Member: 1598426 Status: Offline Thanks Meter: 32 | jny-lx1 downgrade problem [Answered] 2024-05-08 18:20:28 Starting Read Info Selected phone model: JNY-LX1 Searching Fastboot devices... Found android device: AUDUT20C23007279 Detected Android Sooner Single ADB Interface port Reading basic data... Device Model: JNY-L21 System: JNY-L21 12.0.0.296(C185E5R6P2) Android Version: 10 Base Version: JNY-LGRP2-OVS 102.0.0.296 Custom Version: JNY-L21-CUST 102.0.0.5(C185) Preload Version: JNY-L21-PRELOAD 102.0.0.2(C185R6) C_Version: C185 D_Version: D000 Read Info done. Performed by 1.3.4 Software version. this is the info of the device with huawei id i reset huawei id and it was succesful but i faced chip is damaged problem i tried to restore chip is damaged and still the same so i tried to downgrade but i'm facing this problem Welcome to Octoplus Huawei Software v.1.3.4 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM1 Communications Port 2: COM10 RIM Virtual Serial Port v2 3: COM11 RIM Virtual Serial Port v2 4: COM3 Intel(R) Active Management Technology - SOL Job ID: 0000000001E6E2F4 2024-05-09 16:08:33 Starting Write Firmware(Factory mode) Selected phone model: JNY-LX1 Warning: Please, make sure the phone`s battery is fully charged and connected, after connect the device via Factory Mode (use Hardware Test Point or "ON/OFF Factory Mode option"). Warning: Selected response: Proceed Selected base ptable file: C:/Users/bassem/Desktop/JNY-LX1 102.0.0.220(C432E5R6P2)_Firmware_EMUI12.0.0_05016P NN/Software/dload/update_sd_base/PTABLE.APP Selected cust ptable file: C:/Users/bassem/Desktop/JNY-LX1 102.0.0.220(C432E5R6P2)_Firmware_EMUI12.0.0_05016P NN/Software/dload/JNY-L21_hw_eu/update_sd_cust_JNY-L21_hw_eu/PTABLE.APP Selected preload ptable file: C:/Users/bassem/Desktop/JNY-LX1 102.0.0.220(C432E5R6P2)_Firmware_EMUI12.0.0_05016P NN/Software/dload/JNY-L21_hw_eu/update_sd_preload_JNY-L21_hw_eu_R6/PTABLE.APP Selected base update file: C:/Users/bassem/Desktop/JNY-LX1 102.0.0.220(C432E5R6P2)_Firmware_EMUI12.0.0_05016P NN/Software/dload/update_sd_base/UPDATE.APP Selected cust update file: C:/Users/bassem/Desktop/JNY-LX1 102.0.0.220(C432E5R6P2)_Firmware_EMUI12.0.0_05016P NN/Software/dload/JNY-L21_hw_eu/update_sd_cust_JNY-L21_hw_eu/UPDATE.APP Selected preload base file: C:/Users/bassem/Desktop/JNY-LX1 102.0.0.220(C432E5R6P2)_Firmware_EMUI12.0.0_05016P NN/Software/dload/JNY-L21_hw_eu/update_sd_preload_JNY-L21_hw_eu_R6/UPDATE.APP PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE Selected method: Write firmware (EMUI 10) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN810_V4... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Warning: If you use modified USB cable please reconnect cable from the mother board and press "Ok" to proceed the operation Warning: Selected response: Ok Searching Fastboot devices... Found android device: UT7VMG2116019096 Device Model: JNY-LX1 System: JNY-L21 12.0.0.296(C185E5R6P2) Removing firmware protection... Connecting to server... Waiting for a response from the server... FB Lock State: UNLOCKED User Lock State: LOCKED Writing PTABLE partition... Writing PTABLE partition... Writing XLOADER partition... Writing FASTBOOT partition... Writing BOOT partition... Writing DTBO partition... Writing VECTOR partition... Writing FW_LPM3 partition... Writing HHEE partition... Writing VBMETA partition... Writing TEEOS partition... Writing TRUSTFIRMWARE partition... Writing SENSORHUB partition... Writing FW_HIFI partition... Writing MODEMNVM_UPDATE partition... Writing MODEMNVM_CUST partition... Writing MODEM_DRIVER partition... Writing RECOVERY partition... Writing RECOVERY_RAMDISK partition... Writing RECOVERY_VENDOR partition... Writing RECOVERY_VBMETA partition... Writing ERECOVERY partition... Writing ERECOVERY_RAMDISK partition... Writing ERECOVERY_VENDOR partition... Writing ERECOVERY_VBMETA partition... Writing PREAS partition... Writing PREAVS partition... Writing ENG_VENDOR partition... Writing ENG_SYSTEM partition... Writing CACHE partition... Writing RAMDISK partition... Error: Erasing SUPER partition failed Writing SUPER partition... Writing 1 chunk from 2... Warning: Download size mismatch Warning: Writing SUPER partition failed Writing SUPER partition... Writing 1 chunk from 2... Warning: Failed to write download size Warning: Writing SUPER partition failed Error: Writing SUPER partition failed Writing SUPER partition... Writing 1 chunk from 9... Warning: Failed to write download size Warning: Writing SUPER partition failed Writing SUPER partition... Writing 1 chunk from 9... Warning: Failed to write download size Warning: Writing SUPER partition failed Error: Writing SUPER partition failed Error: Erasing METADATA partition failed Writing METADATA partition... Warning: Failed to write download size Warning: Writing METADATA partition failed Writing METADATA partition... Warning: Failed to write download size Warning: Writing METADATA partition failed Error: Writing METADATA partition failed Error: Erasing VBMETA_SYSTEM partition failed Writing VBMETA_SYSTEM partition... Warning: Failed to write download size Warning: Writing VBMETA_SYSTEM partition failed Writing VBMETA_SYSTEM partition... both firmware JNY-LX1 102.0.0.220(C432E5R6P2)_Firmware_EMUI12.0.0_05016P NN JNY-L21 10.1.0.314(C185E4R6P1)_Firmware_EMUI10.1.0_05016NT A which firmware should i use to downgrade the phone now it goes to erecovery mode |
The Following User Says Thank You to basem the ghost For This Useful Post: |
05-10-2024, 10:28 | #2 (permalink) |
Major Poster Join Date: Oct 2005 Location: Rancagua, Chile Age: 36
Member: 195049 Status: Offline Thanks Meter: 16 | Try older versión, this work for me. https://androidhost.ru/B7s Good luck |
The Following User Says Thank You to mike090 For This Useful Post: |
05-12-2024, 18:19 | #3 (permalink) |
Member: 1598426 Status: Offline Thanks Meter: 32 | Job ID: 00000000018E4228 2024-05-12 17:05:53 Starting Write Firmware(Factory mode) Selected phone model: JNY-LX1 Warning: Please, make sure the phone`s battery is fully charged and connected, after connect the device via Factory Mode (use Hardware Test Point or "ON/OFF Factory Mode option"). Warning: Selected response: Proceed Selected base ptable file: C:/Users/bassem/Desktop/Huawei_P40_Lite_JNY-LX1_10.1.0.393_C185E5R6P1_Firmware_EMUI10.1.0_0501 7WWT_Dload/Firmware/dload/update_sd_base/PTABLE.APP Selected cust ptable file: C:/Users/bassem/Desktop/Huawei_P40_Lite_JNY-LX1_10.1.0.393_C185E5R6P1_Firmware_EMUI10.1.0_0501 7WWT_Dload/Firmware/dload/JNY-L21_hw_meafnaf/update_sd_cust_JNY-L21_hw_meafnaf/PTABLE.APP Selected preload ptable file: C:/Users/bassem/Desktop/Huawei_P40_Lite_JNY-LX1_10.1.0.393_C185E5R6P1_Firmware_EMUI10.1.0_0501 7WWT_Dload/Firmware/dload/JNY-L21_hw_meafnaf/update_sd_preload_JNY-L21_hw_meafnaf_R6/PTABLE.APP Selected base update file: C:/Users/bassem/Desktop/Huawei_P40_Lite_JNY-LX1_10.1.0.393_C185E5R6P1_Firmware_EMUI10.1.0_0501 7WWT_Dload/Firmware/dload/update_sd_base/UPDATE.APP Selected cust update file: C:/Users/bassem/Desktop/Huawei_P40_Lite_JNY-LX1_10.1.0.393_C185E5R6P1_Firmware_EMUI10.1.0_0501 7WWT_Dload/Firmware/dload/JNY-L21_hw_meafnaf/update_sd_cust_JNY-L21_hw_meafnaf/UPDATE.APP Selected preload base file: C:/Users/bassem/Desktop/Huawei_P40_Lite_JNY-LX1_10.1.0.393_C185E5R6P1_Firmware_EMUI10.1.0_0501 7WWT_Dload/Firmware/dload/JNY-L21_hw_meafnaf/update_sd_preload_JNY-L21_hw_meafnaf_R6/UPDATE.APP PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE PACKAGE_TYPE: OFFLINE_UPDATE Selected method: Write firmware (EMUI 10) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN810_V4... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Warning: If you use modified USB cable please reconnect cable from the mother board and press "Ok" to proceed the operation Warning: Selected response: Ok Searching Fastboot devices... Found android device: UT7VMG2116019096 Device Model: JNY-LX1 System: JNY-L21 12.0.0.296(C185E5R6P2) Removing firmware protection... Connecting to server... Waiting for a response from the server... FB Lock State: UNLOCKED User Lock State: LOCKED Writing PTABLE partition... Writing PTABLE partition... Writing XLOADER partition... Writing FASTBOOT partition... Writing BOOT partition... Writing DTBO partition... Writing VECTOR partition... Writing FW_LPM3 partition... Writing HHEE partition... Writing VBMETA partition... Writing TEEOS partition... Writing TRUSTFIRMWARE partition... Writing SENSORHUB partition... Writing FW_HIFI partition... Writing MODEMNVM_UPDATE partition... Writing MODEMNVM_CUST partition... Writing RECOVERY partition... Writing RECOVERY_RAMDISK partition... Writing RECOVERY_VENDOR partition... Writing RECOVERY_VBMETA partition... Writing PREAS partition... Writing PREAVS partition... Writing ERECOVERY partition... Writing ERECOVERY_RAMDISK partition... Writing ERECOVERY_VENDOR partition... Writing ERECOVERY_VBMETA partition... Writing ENG_VENDOR partition... Writing ENG_SYSTEM partition... Writing CACHE partition... Writing RAMDISK partition... Error: Erasing SUPER partition failed Writing SUPER partition... Warning: Download size mismatch Warning: Writing SUPER partition failed Writing SUPER partition... Warning: Failed to write download size Warning: Writing SUPER partition failed Error: Writing SUPER partition failed Writing SUPER partition... same problem with provided firmware |
05-13-2024, 17:10 | #5 (permalink) |
Member: 1598426 Status: Offline Thanks Meter: 32 | it was going to erecovery mode but flashing done by **** with same firmware and it's fully working now without huawei id Last edited by Octopus support; 05-17-2024 at 08:55. |
