08-09-2022, 13:54 | #1 (permalink) |
Freak Poster Join Date: May 2020 Location: turkey
Member: 2956535 Status: Offline Sonork: 100.1661966666 Thanks Meter: 31 | jny-lx1 huawei id remove not done [Answered] Starting Reset Huawei ID Selected phone model: JNY-LX1 Selected method: Reset Huawei Id (EMUI12/Harmony) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN810_V3... Initializing remote service connection... Writing XLOADER partition... Reset Huawei ID failed. Performed by 1.3.2.3 Software version. Job ID: 0000000001993D1E 2022-08-09 12:52:10 Starting Backup Firmware Selected phone model: JNY-LX1 Selected method: Read backup (EMUI12/Harmony) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN810_V3... Initializing remote service connection... Writing XLOADER partition... Backup Firmware failed. Performed by 1.3.2.3 Software version. |
08-09-2022, 13:56 | #2 (permalink) |
Member: 2956535 Status: Offline Sonork: 100.1661966666 Thanks Meter: 31 | device firmware info Device Model: JNY-LX1 Device Firmware: :JNY-L21 12.0.0.232(C432E5R6P2) Base Firmware: :JNY-LGRP2-OVS 102.0.0.232 Custom Firmware: :JNY-L21-CUST 102.0.0.5(C432) Preload Firmware: :JNY-L21-PRELOAD 102.0.0.2(C432R6) |
08-09-2022, 14:32 | #3 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Online Thanks Meter: 2,138 | Hello For devices with high firmware verion you must downgrade firmware version to perform Reset Huawei ID operation. At first please make backup via Read Backup operation. Then try to re-flash device via factory mode with another lower version(lower than 12.0.0.230) and try to perform operation once again. Also, use forum search! |
The Following User Says Thank You to Octopus support For This Useful Post: |
08-09-2022, 21:46 | #4 (permalink) | |
No Life Poster Join Date: Aug 2012 Location: under pross
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,047 | Quote:
Huawei P40 Lite JNY-LX1 JNY-L21 hw eu JNY-L21 102.0.0.220(C432E5R6P2) Firmware EMUI12.0.0 05016PMS.zip Then try remove Huawei ID remove | |
The Following User Says Thank You to Pastime_GSM For This Useful Post: |
08-18-2022, 14:50 | #5 (permalink) |
Junior Member Join Date: May 2019 Location: sri lanka
Member: 2911336 Status: Offline Thanks Meter: 0 | reset huwawe id failed octopus Welcome to Octoplus Huawei Software v.1.3.2.3 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM16 HUAWEI USB COM 1.0 2: COM4 Intel(R) Active Management Technology - SOL Job ID: 00000000019C5953 2022-08-18 13:42:56 Starting Reset Huawei ID Selected phone model: JNY-LX2 Selected method: Reset Huawei Id (EMUI12/Harmony) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN810_V3... Initializing remote service connection... Writing XLOADER partition... Reset Huawei ID failed. Performed by 1.3.2.3 Software version. |
08-18-2022, 15:17 | #6 (permalink) | |
Member: 2891705 Status: Online Thanks Meter: 2,138 | Quote:
Please do Read info via fastboot mode and post here log. | |
08-19-2022, 13:00 | #7 (permalink) | |
Freak Poster Join Date: Feb 2017
Member: 2683817 Status: Offline Thanks Meter: 29 | Quote:
