Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus Huawei Tool
Old 10-10-2019, 17:41   #1 (permalink)
unlock in nepal's Avatar
Member: 1686564
Sonork: PM me
Thanks Meter: 155
LDN-LX2 Y7 Pro 2018 [Answered]
How flash phone not go in Fastboot moad always in recovery moad
Tray to flash in recovery modealways error
Selected firmware is not compatible with your device revision
Connecting to phone..
Phone connect successfully
Writing ‪SHA256RSA‬ partition..
‪SHA256RSA‬ partition has been written successfully
Writing ‪CRC‬ partition..
‪CRC‬ partition has been written successfully
Writing ‪AMSS_VERLIST‬ partition..
‪AMSS_VERLIST‬ partition has been written successfully
Writing ‪PACKAGE_TYPE‬ partition..
Error: Failed write ‪PACKAGE_TYPE‬ partition
Write Firmware failed.
Performed by ‪1.1.1.4‬ Software version.
In support this flash file not found tray with support flash file flashing error
LDN-LX2 8.0.0.158(C636) this file not in support
Old 10-11-2019, 08:22   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 25,957
We've added LDN-LX2 8.0.0.159 firmware into Support Area, please try to reflash it via Upgrade Mode, after post here full Software log
The Following User Says Thank You to Octopus box For This Useful Post:
Old 10-11-2019, 09:13   #3 (permalink)
Member: 1686564
Sonork: PM me
Thanks Meter: 155
File not found sir
Path: /Huawei/Huawei Update firmwares (Offilne)/L-series/Huawei Y7 Prime 2018 (LDN-LX2)/Downloaded today: 0 b (0/50 files) NameSizeDateHits LDN-LX2C636CUSTC636D1B144 (8.0.0.144).zip1.62 Gb2019-03-1245
Old 10-11-2019, 09:57   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
Please, follow this path at the Support Area: "/Huawei Update firmwares (Offilne)/L-series/LDN-LX2/" the file should be available there
Old 10-11-2019, 10:49   #5 (permalink)
Member: 1686564
Sonork: PM me
Thanks Meter: 155
Write Firmware done
Starting Write Firmware
Extracting firmware partitions...
Partition has been extract successfully
Checking firmware package type
Package type: offline update
‪PACKAGE_TYPE‬ partition has been written successfully
Writing ‪GPT‬ partition..
‪GPT‬ partition has been written successfully
Writing ‪RPM‬ partition..
‪RPM‬ partition has been written successfully
Writing ‪TZ‬ partition..
‪TZ‬ partition has been written successfully
Writing ‪SBL1‬ partition..
‪SBL1‬ partition has been written successfully
Writing ‪APDP‬ partition..
‪APDP‬ partition has been written successfully
Writing ‪MSADP‬ partition..
‪MSADP‬ partition has been written successfully
Writing ‪MODEM‬ partition..
‪MODEM‬ partition has been written successfully
Writing ‪AMSS_VER‬ partition..
‪AMSS_VER‬ partition has been written successfully
Writing ‪DSP‬ partition..
‪DSP‬ partition has been written successfully
Writing ‪CMNLIB‬ partition..
‪CMNLIB‬ partition has been written successfully
Writing ‪KEYMASTER‬ partition..
‪KEYMASTER‬ partition has been written successfully
Writing ‪CMNLIB64‬ partition..
‪CMNLIB64‬ partition has been written successfully
Writing ‪DEVCFG‬ partition..
‪DEVCFG‬ partition has been written successfully
Writing ‪LKSECAPP‬ partition..
‪LKSECAPP‬ partition has been written successfully
Writing ‪ABOOT‬ partition..
‪ABOOT‬ partition has been written successfully
Writing ‪KERNEL‬ partition..
‪KERNEL‬ partition has been written successfully
Writing ‪RAMDISK‬ partition..
‪RAMDISK‬ partition has been written successfully
Writing ‪RECOVERY_RAMDISK‬ partition..
‪RECOVERY_RAMDISK‬ partition has been written successfully
Writing ‪RECOVERY_VENDOR‬ partition..
‪RECOVERY_VENDOR‬ partition has been written successfully
Writing ‪ERECOVERY_KERNEL‬ partition..
‪ERECOVERY_KERNEL‬ partition has been written successfully
Writing ‪ERECOVERY_RAMDISK‬ partition..
‪ERECOVERY_RAMDISK‬ partition has been written successfully
Writing ‪ERECOVERY_VENDOR‬ partition..
‪ERECOVERY_VENDOR‬ partition has been written successfully
Writing ‪SYSTEM‬ partition..
‪SYSTEM‬ partition has been written successfully
Writing ‪CACHE‬ partition..
‪CACHE‬ partition has been written successfully
Writing ‪ODM‬ partition..
‪ODM‬ partition has been written successfully
Writing ‪VENDOR‬ partition..
‪VENDOR‬ partition has been written successfully
Writing ‪PRODUCT‬ partition..
‪PRODUCT‬ partition has been written successfully
Writing ‪USERDATA‬ partition..
‪USERDATA‬ partition has been written successfully
Firmware writing successfully completed
Write Firmware done.
Phone always in recovery moad
Old 10-11-2019, 11:49   #6 (permalink)
Member: 1686564
Sonork: PM me
Thanks Meter: 155
LDN-LX2_(V.8.0.0.158)_(C636) Firmware Nead
Nead this Firmware
Old 10-11-2019, 12:18   #7 (permalink)
Member: 1146942
Sonork: 100.1587278
As we can see from the Software log, Write Firmware operation was completed successfully, but most likely your device has HW issue, You can try to write board firmware and check whether device will boot normaly, etc
P.S We don't think that the problem is in firmware
Old 10-11-2019, 13:31   #8 (permalink)
Member: 1686564
Sonork: PM me
Thanks Meter: 155
How to write board firmware & how to know bord firmware & where to found board firmwer
Old 10-11-2019, 13:37   #9 (permalink)
Member: 1146942
Sonork: 100.1587278
Unfortunately, we don't have board firmware for your device, all instructions are available at the Software manual
Old 10-11-2019, 13:50   #10 (permalink)
Member: 1686564
Sonork: PM me
Thanks Meter: 155
Unfortunately, we don't have board firmware for your device, all instructins are available at the Software manual
Boot repair healp in this phone I have mdusa pro box also giad me
Old 10-12-2019, 07:01   #11 (permalink)
Moh3en.pc's Avatar
Member: 1712884
Sonork: 100,1648332/1625146
Thanks Meter: 647
Exclamation
hello
please test other battery my phone problem solved after change battery
http://forum.gsmhosting.com/vbb/f102...y-mod-2661294/
The Following User Says Thank You to Moh3en.pc For This Useful Post:
Old 10-12-2019, 10:27   #12 (permalink)
Member: 1686564
Sonork: PM me
Thanks Meter: 155
[QUOTE=Moh3en.pc;13857749]hello
http://forum.gsmhosting.com/vbb/f102...y-mod-2661294/[/QUOTE
I test by huawei another model battery problam is same
The Following User Says Thank You to unlock in nepal For This Useful Post:
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.20671 seconds with 8 queries
