01-13-2023, 13:37 | #1 (permalink) |
Freak Poster Join Date: Nov 2019 Location: Ghana
Member: 2938458 Status: Offline Thanks Meter: 59 | Med-l29 huawei id done 2023-01-13 12:14:08.749 Found COM ports: 2023-01-13 12:14:08.751 1: COM17 RIM Virtual Serial Port v2 2023-01-13 12:14:08.751 2: COM18 RIM Virtual Serial Port v2 2023-01-13 12:14:09.921 Welcome to Octoplus Huawei Software v.1.3.3 2023-01-13 12:14:09.922 2023-01-13 12:14:09.923 To enable 'Manufacture' mode dial 2023-01-13 12:14:09.923 - for Qualcomm and Hisilicon based models: *#*#2846579#*#* 2023-01-13 12:14:09.924 ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode 2023-01-13 12:14:09.924 - for MTK based models: *#*#14789632#*#* 2023-01-13 12:14:09.924 ProjectMenu > Background Settings > USB Port Settings > Debug Mode 2023-01-13 12:14:09.926 2023-01-13 12:14:09.926 To enable 'Fastboot' mode 2023-01-13 12:14:09.927 1. Power off the phone. Remove SD and SIM cards 2023-01-13 12:14:09.927 2. Press 'Vol-' and insert USB cable 2023-01-13 12:14:09.928 3. Wait until phone enters 'Fastboot' mode 2023-01-13 12:14:09.928 2023-01-13 12:14:09.929 To enable 'Upgrade' mode 2023-01-13 12:14:09.929 1. Power off the phone. Remove SD and SIM cards 2023-01-13 12:14:09.930 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 2023-01-13 12:14:09.930 3. Wait until phone enters 'Upgrade mode' 2023-01-13 12:14:12.151 Refreshing serial ports list 2023-01-13 12:14:12.156 Found COM ports: 2023-01-13 12:14:12.157 1: COM17 RIM Virtual Serial Port v2 2023-01-13 12:14:12.158 2: COM18 RIM Virtual Serial Port v2 2023-01-13 12:14:12.285 Init finished 2023-01-13 12:14:33.166 Job ID: 00000000019FB317 2023-01-13 12:14:34.109 2023-01-13 12:14:34 2023-01-13 12:14:34.123 Starting Reset Huawei ID 2023-01-13 12:14:34.156 Selected phone model: MED-LX9 2023-01-13 12:14:34.224 Please, put your device in Factory mode (use "ON/OFF Factory Mode" option or Hardware Test Point) and insert USB cable 2023-01-13 12:15:12.069 Detected MediaTek USB Port port 2023-01-13 12:15:12.086 Initializing... 2023-01-13 12:15:12.100 Get a list of available devices... 2023-01-13 12:15:12.108 Device list count = 5 2023-01-13 12:15:12.108 VID, PID found. Try to open device = 4 2023-01-13 12:15:12.109 Connecting to device... 2023-01-13 12:15:12.795 libusb_open_device_with_vid_pid success 2023-01-13 12:15:12.795 USB device is connected 2023-01-13 12:15:12.982 Handshake done 2023-01-13 12:15:13.045 Detecting Chip Version... 2023-01-13 12:15:13.242 HW Chip : MT6765 2023-01-13 12:15:13.318 HW Version : 8A00.CA00.0000.0000 2023-01-13 12:15:13.348 Initializing remote service connection... 2023-01-13 12:15:13.416 Downloading Mtk Loader... 2023-01-13 12:15:13.454 Writing loader... 2023-01-13 12:15:14.640 DA successfully sent 2023-01-13 12:15:16.080 Reconnecting... 2023-01-13 12:15:17.242 Detected MediaTek PreLoader USB VCOM (Android) port 2023-01-13 12:15:17.753 Writing special secure data... 2023-01-13 12:15:20.879 Reading secure data dump... 2023-01-13 12:15:23.661 Writing secure data dump... 2023-01-13 12:15:34.577 Resetting Huawei ID... 2023-01-13 12:15:42.572 Please perform "Factory reset" manually via Recovery Mode, if your device doesn`t work properly! 2023-01-13 12:15:42.590 Reset Huawei ID done. 2023-01-13 12:15:42.604 Performed by 1.3.3 Software version. |
The Following 2 Users Say Thank You to obimpena For This Useful Post: |
